Postprocessor for rotary plasma
Craig
Post by Craig » Mon May 18, 2020 6:13 pm
We are using GRBL1.1h with USB-CNC plasma.scpost. A friend set up a breadboard using an Arduino and drivers and it works! We have built a more permanent copy in a case using identical parts and software and it doesn't fire the plasma to cut-but the table and torch move correctly. We have recently tried adding S1000 to the M03 torch-on command lines and the torch cuts correctly. Can you tell us how to update the postprocessor code to include the S1000 command to the M03 command lines?
Re: Postprocessor for rotary plasma
Post by Les Newell » Tue May 19, 2020 4:36 pm
Do you need S1000 with the M3 or just at the start of the code?
Craig
Post by Craig » Tue Jun 30, 2020 10:31 pm
We need to S1000 command to appear on the same line as every M3 command
