torch not shutting off until it moves to home
SpoolnMS
Re: torch not shutting off until it moves to home
Post by SpoolnMS »
djreiswig wrote: Fri Feb 07, 2020 2:00 am Well, I'm confused. I took your job file and ran it through SheetCam with the Mach3 THC with scriber post (I had to edit the setting at the top to get the G31 probe) and my code looks totally different.
For one thing, my code has a lot less lines, and my code has an M05 at the bottom where you would expect it to be before the rapid moves.
I also noticed that the X,Y moves have different coordinates. I'm not sure if you changed your job file after you posted your code, but it looks like the drawing isn't in the same place on the material.
Here's what I get for code.
N0010 (Filename: PS help 2.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 06/02/2020)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: Trump punisher)
N0080 (Operation: Inside Offset, 1, T1: Plasma, 0.05 in kerf)
N0090 G00 X6.7282 Y6.0420
N0100 G31 Z -100 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.0591
N0130 G92 Z0.0
N0140 G00 Z0.1500
N0150 M03
N0160 G04 P0.4
N0170 G01 Z0.1150 F5.0
N0180 X6.8395 Y6.2082 F100.0
N0190 X6.8408 Y6.2070
N0200 G02 X6.8960 Y6.1459 I-0.2305 J-0.2635
N0210 X6.9638 Y5.9950 I-0.5199 J-0.3246
N0220 G03 X7.0890 Y5.7212 I1.0412 J0.3103
N0230 G01 X7.0896 Y5.7203
N0240 G03 X7.1993 Y5.5697 I3.6836 J2.5684
N0250 G02 X7.2864 Y5.3867 I-0.3761 J-0.2914
N0260 X7.2726 Y5.2264 I-0.2679 J-0.0576
N0270 X6.9407 Y4.6992 I-1.9889 J0.8841
N0280 G03 X6.9611 Y4.7786 I-0.7112 J0.2250
N0290 X6.9516 Y5.0776 I-0.5925 J0.1310
N0300 G01 X6.9513 Y5.0788
N0310 G03 X6.6837 Y5.6038 I-1.9643 J-0.6704
N0320 G02 X6.6810 Y6.3671 I14.9998 J0.4360
N0330 G01 X6.8395 Y6.2082
N0340 X6.6980 Y6.0669
N0350 M05
N0360 G00 Z1.0000
N0370 X6.0420 Y5.1849
N0380 Z0.1500
N0390 M03
N0400 G04 P0.4
N0410 G01 Z0.1150 F5.0
N0420 X6.2365 Y5.1385 F100.0
N0430 G03 X6.2137 Y4.7556 I1.0719 J-0.2558
N0440 X6.0825 Y4.9353 I-5.2836 J-3.7231
N0450 G02 X5.9868 Y5.0691 I2.0293 J1.5517
N0460 X5.8984 Y5.2990 I0.5251 J0.3339
N0470 G01 X5.8977 Y5.3048
N0480 X5.8976 Y5.3056
N0490 G02 X5.9315 Y5.4750 I0.2456 J0.0390
N0500 G03 X6.0319 Y5.6242 I-0.4658 J0.4219
N0510 G01 X6.0321 Y5.6246
N0520 G03 X6.1315 Y5.8900 I-1.7407 J0.8035
N0530 G01 X6.1317 Y5.8909
N0540 G02 X6.1646 Y5.9726 I0.3195 J-0.0813
N0550 X6.3117 Y6.1594 I0.7607 J-0.4476
N0560 G03 X6.4912 Y6.3411 I-1.0952 J1.2610
N0570 X6.4506 Y5.5745 I5.6158 J-0.6813
N0580 X6.2365 Y5.1385 I0.8578 J-0.6918
N0590 G01 X6.0420 Y5.1849
N0600 M05
N0610 G00 Z1.0000
N0620 X3.3105 Y8.0226
N0630 G31 Z -100 F19.685
N0640 G92 Z0.0
N0650 G00 Z0.0591
N0660 G92 Z0.0
N0670 G00 Z0.1500
N0680 M03
N0690 G04 P0.4
N0700 G01 Z0.1150 F5.0
N0710 X3.4085 Y8.1970 F100.0
N0720 X3.5796 Y8.1009
N0730 G03 X4.0460 Y7.8216 I10.7368 J17.3985
N0740 G01 X4.0471 Y7.8210
N0750 G02 X4.2722 Y7.6851 I-0.8875 J-1.7248
N0760 G03 X6.2882 Y6.6906 I3.5329 J4.6212
N0770 G02 X5.1617 Y6.3210 I-1.1748 J1.6792
N0780 X3.4226 Y6.5748 I0.2479 J7.7857
N0790 G01 X3.4219 Y6.5749
N0800 G02 X3.1741 Y6.6671 I0.2354 J1.0121
N0810 X2.8400 Y7.0153 I0.4387 J0.7555
N0820 G01 X2.8369 Y7.0213
N0830 X2.8366 Y7.0220
N0840 G02 X2.7855 Y7.1794 I0.4033 J0.2179
N0850 G01 X2.7853 Y7.1808
N0860 X2.7803 Y7.2064
N0870 X2.7801 Y7.2075
N0880 G03 X2.7013 Y7.4449 I-1.4317 J-0.3434
N0890 G02 X2.6260 Y7.7016 I1.0383 J0.4442
N0900 G01 X2.6255 Y7.7038
N0910 G02 X2.6015 Y7.8448 I0.7945 J0.2077
N0920 X2.6454 Y8.3836 I1.8075 J0.1238
N0930 G01 X2.6458 Y8.3853
N0940 G02 X2.6652 Y8.4479 I0.2316 J-0.0376
N0950 G01 X2.6658 Y8.4493
N0960 G02 X2.7338 Y8.4854 I0.0553 J-0.0222
N0970 X2.8450 Y8.4433 I-0.0812 J-0.3827
N0980 G03 X3.0011 Y8.3721 I0.5177 J0.9275
N0990 G01 X3.0056 Y8.3709
N1000 G02 X3.1328 Y8.3416 I-0.1588 J-0.9805
N1010 X3.2364 Y8.2936 I-0.1805 J-0.5257
N1020 G01 X3.2369 Y8.2933
N1030 X3.4085 Y8.1970
N1040 X3.3105 Y8.0226
N1050 M05
N1060 G00 Z1.0000
N1070 X2.2064 Y8.6543
N1080 G31 Z -100 F19.685
N1090 G92 Z0.0
N1100 G00 Z0.0591
N1110 G92 Z0.0
N1120 G00 Z0.1500
N1130 M03
N1140 G04 P0.4
N1150 G01 Z0.1150 F5.0
N1160 X2.3600 Y8.6991 F100.0
N1170 G02 X1.8918 Y8.1628 I-1.4551 J0.7979
N1180 X2.5604 Y9.3821 I14.4603 J-7.1369
N1190 X2.3600 Y8.6991 I-1.6555 J0.1149
N1200 G01 X2.3152 Y8.8527
N1210 M05
N1220 G00 Z1.0000
N1230 X1.6470 Y8.3776
N1240 Z0.1500
N1250 M03
N1260 G04 P0.4
N1270 G01 Z0.1150 F5.0
N1280 X1.5819 Y8.3849 F100.0
N1290 G03 X1.8043 Y8.6072 I-0.8914 J1.1142
N1300 G02 X1.3161 Y8.2167 I-0.4432 J0.0536
N1310 G03 X1.5819 Y8.3849 I-0.6256 J1.2824
N1320 G01 X1.5746 Y8.3197
N1330 M05
N1340 G00 Z1.0000
N1350 X1.6352 Y7.4713
N1360 Z0.1500
N1370 M03
N1380 G04 P0.4
N1390 G01 Z0.1150 F5.0
N1400 X1.6862 Y7.5124 F100.0
N1410 G02 X1.6378 Y7.1457 I-0.8431 J-0.0754
N1420 X1.5736 Y7.8647 I4.9059 J0.8009
N1430 X1.6862 Y7.5124 I-0.7305 J-0.4276
N1440 G01 X1.6287 Y7.5438
N1450 M05
N1460 G00 Z1.0000
N1470 X2.7347 Y9.9368
N1480 G31 Z -100 F19.685
N1490 G92 Z0.0
N1500 G00 Z0.0591
N1510 G92 Z0.0
N1520 G00 Z0.1500
N1530 M03
N1540 G04 P0.4
N1550 G01 Z0.1150 F5.0
N1560 X2.8070 Y9.7503 F100.0
N1570 G02 X1.8527 Y10.4196 I1.2077 J2.7368
N1580 G01 X1.6961 Y10.5838
N1590 X1.8846 Y10.4535
N1600 G03 X4.4117 Y9.5691 I2.8800 J4.1761
N1610 G01 X4.6404 Y9.5533
N1620 X4.4156 Y9.5226
N1630 G02 X2.8070 Y9.7503 I-0.4008 J2.9645
N1640 G01 X2.9935 Y9.8226
N1650 M05
N1660 G00 Z1.0000
N1670 X2.1276 Y11.1794
N1680 Z0.1500
N1690 M03
N1700 G04 P0.4
N1710 G01 Z0.1150 F5.0
N1720 X2.1832 Y11.1192 F100.0
N1730 G02 X1.5191 Y11.3153 I0.0545 J1.4071
N1740 G03 X2.8605 Y11.2634 I0.8037 J3.4082
N1750 G02 X2.1832 Y11.1192 I-0.6227 J1.2630
N1760 G01 X2.2433 Y11.1749
N1770 M05
N1780 G00 Z1.0000
N1790 X3.4339 Y11.3155
N1800 G31 Z -100 F19.685
N1810 G92 Z0.0
N1820 G00 Z0.0591
N1830 G92 Z0.0
N1840 G00 Z0.1500
N1850 M03
N1860 G04 P0.4
N1870 G01 Z0.1150 F5.0
N1880 G03 X3.4372 Y11.2881 I0.0224 J-0.0112 F100.0
N1890 X6.6879 Y9.9989 I2.8347 J2.4047
N1900 X6.6877 Y10.0486 I-0.0028 J0.0248
N1910 G02 X3.4714 Y11.3242 I0.6858 J6.4218
N1920 G03 X3.4339 Y11.3155 I-0.0151 J-0.0199
N1930 M05
N1940 G00 Z1.0000
N1950 X4.8579 Y11.3558
N1960 Z0.1500
N1970 M03
N1980 G04 P0.4
N1990 G01 Z0.1150 F5.0
N2000 X4.8909 Y11.2589 F100.0
N2010 G02 X3.9794 Y11.6713 I0.7911 J2.9618
N2020 G03 X5.8867 Y11.1619 I4.1224 J11.6085
N2030 G02 X4.8909 Y11.2589 I-0.2046 J3.0588
N2040 G01 X4.9679 Y11.3265
N2050 M05
N2060 G00 Z1.0000
N2070 X6.3952 Y11.5510
N2080 G31 Z -100 F19.685
N2090 G92 Z0.0
N2100 G00 Z0.0591
N2110 G92 Z0.0
N2120 G00 Z0.1500
N2130 M03
N2140 G04 P0.4
N2150 G01 Z0.1150 F5.0
N2160 X6.4011 Y11.7509 F100.0
N2170 G03 X7.9067 Y11.6288 I1.1702 J5.0867
N2180 G01 X7.9072 Y11.6289
N2190 G02 X9.9032 Y11.3217 I0.3699 J-4.2342
N2200 G03 X7.4610 Y11.3542 I-1.3710 J-11.2453
N2210 G02 X5.1649 Y12.2059 I-0.0489 J3.3891
N2220 G03 X6.4011 Y11.7509 I2.4064 J4.6317
N2230 G01 X6.2851 Y11.5880
N2240 M05
N2250 G00 Z1.0000
N2260 X7.0931 Y13.2192
N2270 G31 Z -100 F19.685
N2280 G92 Z0.0
N2290 G00 Z0.0591
N2300 G92 Z0.0
N2310 G00 Z0.1500
N2320 M03
N2330 G04 P0.4
N2340 G01 Z0.1150 F5.0
N2350 G02 X7.7702 Y13.2302 I0.3485 J-0.6056 F100.0
N2360 G03 X7.0931 Y13.2192 I-0.3078 J-1.8942
N2370 G01
N2380 M05
N2390 G00 Z1.0000
N2400 X5.5022 Y13.4045
N2410 Z0.1500
N2420 M03
N2430 G04 P0.4
N2440 G01 Z0.1150 F5.0
N2450 G02 X7.9423 Y13.9274 I2.4932 J-5.6797 F100.0
N2460 G03 X7.9470 Y13.9769 I-0.0002 J0.0250
N2470 X3.4260 Y11.9923 I-0.8540 J-4.1965
N2480 X3.4656 Y11.9623 I0.0214 J-0.0129
N2490 G02 X5.5022 Y13.4045 I4.5298 J-4.2375
N2500 M05
N2510 G00 Z1.0000
N2520 X6.5901 Y9.6523
N2530 G31 Z -100 F19.685
N2540 G92 Z0.0
N2550 G00 Z0.0591
N2560 G92 Z0.0
N2570 G00 Z0.1500
N2580 M03
N2590 G04 P0.4
N2600 G01 Z0.1150 F5.0
N2610 X6.7516 Y9.5344 F100.0
N2620 G02 X5.9262 Y9.4479 I-1.2658 J8.1011
N2630 X5.7721 Y9.4442 I-0.1383 J2.5616
N2640 G01 X5.7711
N2650 G02 X5.3707 Y9.4399 I-0.2965 J8.9126
N2660 G01 X5.3691
N2670 G02 X5.2137 Y9.4645 I-0.0205 J0.3728
N2680 G03 X6.1191 Y9.4934 I0.2146 J7.4863
N2690 G01 X6.1210 Y9.4936
N2700 G03 X6.3294 Y9.6136 I-0.0584 J0.3424
N2710 X6.3080 Y9.6546 I-0.0192 J0.0160
N2720 G02 X5.6358 Y9.6242 I-0.6968 J7.9622
N2730 G01 X5.6342 Y9.6241
N2740 G02 X5.4303 Y9.6601 I-0.0285 J0.4345
N2750 X5.4189 Y9.6658 I0.2092 J0.4286
N2760 G03 X5.9405 Y9.6674 I0.2368 J7.9900
N2770 G01 X5.9657 Y9.6678
N2780 X5.9661
N2790 G03 X7.8962 Y9.8219 I-0.7472 J21.5343
N2800 G01 X8.0252 Y9.8380
N2810 X7.8884 Y9.7960
N2820 G02 X6.7516 Y9.5344 I-2.4026 J7.8395
N2830 G01 X6.8695 Y9.6959
N2840 M05
N2850 G00 Z1.0000
N2860 X9.2388 Y10.4258
N2870 G31 Z -100 F19.685
N2880 G92 Z0.0
N2890 G00 Z0.0591
N2900 G92 Z0.0
N2910 G00 Z0.1500
N2920 M03
N2930 G04 P0.4
N2940 G01 Z0.1150 F5.0
N2950 X9.2810 Y10.3757 F100.0
N2960 G02 X8.7611 Y10.4085 I-0.1661 J1.5009
N2970 X9.7811 Y10.5214 I3.2990 J-25.1442
N2980 X9.2810 Y10.3757 I-0.6662 J1.3551
N2990 G01 X9.3112 Y10.4338
N3000 M05
N3010 G00 Z1.0000
N3020 X11.0891 Y9.5164
N3030 Z0.1500
N3040 M03
N3050 G04 P0.4
N3060 G01 Z0.1150 F5.0
N3070 X11.0077 Y9.4542 F100.0
N3080 G02 X11.0001 Y10.0528 I5.8797 J0.3738
N3090 X11.0760 Y8.8594 I-1.7553 J-0.7107
N3100 X11.0077 Y9.4542 I5.8114 J0.9685
N3110 G01 X11.0963 Y9.4028
N3120 M05
N3130 G00 Z1.0000
N3140 X11.6584 Y9.8511
N3150 Z0.1500
N3160 M03
N3170 G04 P0.4
N3180 G01 Z0.1150 F5.0
N3190 X11.6905 Y9.8781 F100.0
N3200 G02 X11.7093 Y9.7606 I-0.3844 J-0.1218
N3210 G01 X11.7094 Y9.7594
N3220 G02 X11.7157 Y9.4605 I-3.7784 J-0.2300
N3230 G03 X11.5468 Y10.0798 I-5.6795 J-1.2164
N3240 G02 X11.6905 Y9.8781 I-0.2407 J-0.3235
N3250 G01 X11.6487 Y9.8817
N3260 M05
N3270 G00 Z1.0000
N3280 X9.6548 Y12.3680
N3290 G31 Z -100 F19.685
N3300 G92 Z0.0
N3310 G00 Z0.0591
N3320 G92 Z0.0
N3330 G00 Z0.1500
N3340 M03
N3350 G04 P0.4
N3360 G01 Z0.1150 F5.0
N3370 G02 X10.6331 Y11.5694 I-2.5115 J-4.0753 F100.0
N3380 G03 X10.6738 Y11.5974 I0.0182 J0.0171
N3390 X8.5085 Y12.9319 I-2.1355 J-1.0411
N3400 X8.5017 Y12.8829 I0.0003 J-0.0250
N3410 G02 X9.6548 Y12.3680 I-1.3584 J-4.5903
N3420 M05
N3430 G00 Z1.0000
N3440 X10.0397 Y6.9894
N3450 G31 Z -100 F19.685
N3460 G92 Z0.0
N3470 G00 Z0.0591
N3480 G92 Z0.0
N3490 G00 Z0.1500
N3500 M03
N3510 G04 P0.4
N3520 G01 Z0.1150 F5.0
N3530 X10.1877 Y6.8549 F100.0
N3540 G02 X9.7858 Y6.5663 I-0.8768 J0.7971
N3550 X9.1157 Y6.3914 I-1.0413 J2.6182
N3560 G01 X9.1146 Y6.3913
N3570 G02 X6.8692 Y6.6764 I-0.6677 J3.7254
N3580 G03 X8.5652 Y7.4930 I-1.3763 J5.0279
N3590 G01 X8.5660 Y7.4937
N3600 G02 X10.6066 Y8.4940 I3.3023 J-4.1549
N3610 X10.4367 Y7.2824 I-4.2286 J-0.0249
N3620 X10.1877 Y6.8549 I-1.1259 J0.3696
N3630 G01 X10.0397 Y6.9894
N3640 (Operation: Outside Offset, 0, T1: Plasma, 0.05 in kerf)
N3650 M05
N3660 G00 Z1.0000
N3670 X1.6837 Y5.8498
N3680 G31 Z -100 F19.685
N3690 G92 Z0.0
N3700 G00 Z0.0591
N3710 G92 Z0.0
N3720 G00 Z0.1500
N3730 M03
N3740 G04 P0.4
N3750 G01 Z0.1150 F5.0
N3760 X1.5577 Y5.6945 F100.0
N3770 G02 X1.5281 Y5.7287 I0.0816 J0.1005
N3780 X1.4899 Y5.8657 I0.2938 J0.1557
N3790 X1.5061 Y6.1598 I1.1986 J0.0815
N3800 X1.5808 Y6.4233 I1.6113 J-0.3141
N3810 X1.6727 Y6.6297 I2.3097 J-0.9052
N3820 X1.8398 Y6.8762 I0.9543 J-0.4668
N3830 G03 X1.9760 Y7.0523 I-0.9065 J0.8419
N3840 X1.9797 Y7.0623 I-0.0211 J0.0135
N3850 G01 X1.9857 Y7.1041
N3860 X1.9858 Y7.1048
N3870 G02 X2.0082 Y7.2717 I3.8973 J-0.4389
N3880 X2.0119 Y7.2125 I-1.0385 J-0.0945
N3890 G03 X2.0584 Y6.9268 I1.0293 J0.0209
N3900 G01 X2.0585 Y6.9263
N3910 G03 X2.1578 Y6.6685 I3.0941 J1.0430
N3920 G01 X2.1581 Y6.6678
N3930 G03 X2.3963 Y6.2492 I2.8032 J1.3182
N3940 G01 X2.3971 Y6.2481
N3950 G03 X2.5670 Y6.0314 I6.6862 J5.0680
N3960 X2.8001 Y5.8386 I0.5356 J0.4100
N3970 G01 X2.8031 Y5.8373
N3980 G02 X2.8163 Y5.8303 I-0.0164 J-0.0471
N3990 X2.7691 Y5.8151 I-0.0708 J0.1382
N4000 G01 X2.7684 Y5.8149
N4010 G03 X2.5728 Y5.7756 I1.0619 J-5.7868
N4020 X2.4387 Y5.7118 I0.0531 J-0.2844
N4030 G01 X2.4374 Y5.7106
N4040 G03 X2.3677 Y5.5701 I0.1658 J-0.1698
N4050 X2.3941 Y5.2967 I0.5901 J-0.0810
N4060 G01 X2.3950 Y5.2945
N4070 G02 X2.4211 Y5.1718 I-0.2681 J-0.1212
N4080 X2.4029 Y5.1085 I-0.2278 J0.0311
N4090 G01 X2.3412 Y4.9825
N4100 G03 X2.3276 Y4.8004 I0.2220 J-0.1081
N4110 G01 X2.3286 Y4.7976
N4120 G03 X2.5541 Y4.3927 I2.4858 J1.1192
N4130 X2.6603 Y4.2546 I0.7843 J0.4929
N4140 X2.8403 Y4.1276 I0.3746 J0.3399
N4150 G01 X2.8413 Y4.1272
N4160 X2.8436 Y4.1264
N4170 G03 X2.9644 Y4.1155 I0.0777 J0.1865
N4180 X3.0983 Y4.2006 I-0.0525 J0.2306
N4190 G01 X3.0997 Y4.2026
N4200 G02 X3.1367 Y4.2472 I0.1897 J-0.1197
N4210 X3.2907 Y4.2947 I0.1381 J-0.1746
N4220 G01 X3.2921 Y4.2946
N4230 G02 X3.4605 Y4.2262 I-0.0043 J-0.2522
N4240 G03 X3.5551 Y4.1462 I0.2428 J0.1911
N4250 G01 X3.5564 Y4.1456
N4260 G03 X3.7895 Y4.1109 I0.1731 J0.3630
N4270 X4.0677 Y4.2738 I-0.0685 J0.4361
N4280 X4.0585 Y4.3684 I-0.0441 J0.0434
N4290 X3.9601 Y4.4076 I-0.1372 J-0.2013
N4300 X3.6971 Y4.4336 I-0.2864 J-1.5532
N4310 G01 X3.6954
N4320 G02 X3.6278 Y4.4430 I-0.0094 J0.1799
N4330 G01 X3.6250 Y4.4438
N4340 G02 X3.6185 Y4.4486 I0.0020 J0.0095
N4350 X3.6311 Y4.4720 I0.0410 J-0.0070
N4360 G01 X3.6318 Y4.4727
N4370 G02 X4.4615 Y5.0299 I1.7818 J-1.7567
N4380 G01 X4.4623 Y5.0303
N4390 G02 X4.7066 Y5.0911 I0.2857 J-0.6269
N4400 G01 X4.7079 Y5.0912
N4410 G02 X4.8413 Y5.0714 I0.0296 J-0.2595
N4420 G01 X4.8422 Y5.0710
N4430 G02 X4.9062 Y4.9759 I-0.0362 J-0.0934
N4440 X4.8738 Y4.8406 I-0.3530 J0.0130
N4450 G03 X4.8525 Y4.6744 I0.2216 J-0.1129
N4460 G01 X4.8527 Y4.6734
N4470 G03 X4.8792 Y4.6033 I0.3373 J0.0876
N4480 G02 X4.9230 Y4.4525 I-0.4510 J-0.2127
N4490 X4.8758 Y4.3381 I-0.1230 J-0.0161
N4500 G03 X4.8167 Y4.2291 I0.0601 J-0.1031
N4510 G01 X4.8172 Y4.2253
N4520 G03 X5.0385 Y3.3683 I8.3319 J1.6948
N4530 X5.1495 Y0.4986 I88.0661 J1.9673
N4540 X5.1578 Y0.4814 I0.0250 J0.0014
N4550 X5.5387 Y0.1477 I19.6378 J22.0345
N4560 X5.5485 Y0.1425 I0.0163 J0.0189
N4570 X5.7716 Y0.2971 I0.0464 J0.1713
N4580 G01 X5.7717 Y0.2993
N4590 G03 X5.7472 Y2.8460 I-91.6431 J0.3921
N4600 G01 Y2.8468
N4610 G02 X5.7241 Y3.4669 I20.6805 J1.0808
N4620 X5.7192 Y3.7185 I9.1087 J0.3036
N4630 G01 Y3.8851
N4640 X5.8336 Y3.9106
N4650 X5.8206 Y3.7081
N4660 G03 X5.8155 Y3.5499 I1.6253 J-0.1314
N4670 X5.8357 Y2.9846 I19.2282 J0.4053
N4680 G01 X5.8358 Y2.9837
N4690 G02 X5.8772 Y2.3595 I-16.2879 J-1.3936
N4700 G01 X5.8773 Y2.3583
N4710 X5.8915 Y2.2067
N4720 G02 X5.9188 Y1.7313 I-34.4469 J-2.2162
N4730 G01 X5.9191 Y1.6136
N4740 Y1.6132
N4750 X5.9299 Y1.0760
N4760 Y0.0443
N4770 G03 X5.9521 Y0.0195 I0.0250 J0.0000
N4780 X6.4786 Y0.0010 I0.3803 J3.3183
N4790 X6.5024 Y0.0244 I-0.0011 J0.0250
N4800 X6.5863 Y3.9362 I-49.7025 J3.0219
N4810 G02 X6.7169 Y3.9430 I0.1605 J-1.8076
N4820 G03 X6.7230 Y0.0012 I45.1420 J-1.9003
N4830 X6.7471 Y-0.0226 I0.0250 J0.0011
N4840 X7.0774 Y-0.0187 I0.1256 J3.3366
N4850 X7.0999 Y-0.0007 I-0.0015 J0.0250
N4860 G01 X7.1331 Y0.1147
N4870 G03 X7.2528 Y0.7113 I-3.5232 J1.0173
N4880 G01 X7.2529 Y0.7118
N4890 X7.2535 Y0.7188
N4900 X7.2536 Y0.7195
N4910 G03 X7.3358 Y3.9402 I-37.7556 J2.5754
N4920 G01 Y3.9412
N4930 G02 X7.3462 Y4.0238 I0.2253 J0.0136
N4940 G01 X7.3465 Y4.0251
N4950 G02 X7.4061 Y4.0795 I0.0718 J-0.0187
N4960 X7.5037 Y4.0695 I0.0250 J-0.2374
N4970 X7.7463 Y3.9509 I-0.4158 J-1.1582
N4980 X7.7328 Y3.9544 I0.0435 J0.1995
N4990 G03 X7.7248 Y3.9554 I-0.0070 J-0.0240
N5000 X7.5629 Y3.8933 I0.0105 J-0.2695
N5010 G01 X7.5619 Y3.8924
N5020 G03 X7.4695 Y3.7241 I0.2069 J-0.2231
N5030 G01 X7.4692 Y3.7213
N5040 G03 X7.4332 Y0.0396 I31.3076 J-2.1465
N5050 X7.4597 Y0.0159 I0.0250 J0.0012
N5060 X8.0163 Y0.0958 I-0.1946 J3.3355
N5070 X8.0354 Y0.1163 I-0.0056 J0.0244
N5080 X8.2572 Y3.1409 I-18.3399 J2.8656
N5090 G01 Y3.1418
N5100 G02 X8.3385 Y3.4742 I0.6119 J0.0265
N5110 G03 X8.5712 Y4.7240 I-1.3699 J0.9016
N5120 G01 X8.5706 Y4.7261
N5130 G02 X8.5695 Y4.8365 I0.1861 J0.0571
N5140 X8.6503 Y4.9241 I0.1498 J-0.0571
N5150 X9.3303 Y5.0504 I0.5993 J-1.3332
N5160 G01 X9.3313 Y5.0503
N5170 G02 X9.5154 Y5.0081 I-0.0055 J-0.4457
N5180 G01 X9.5159 Y5.0078
N5190 G02 X9.7024 Y4.7868 I-0.1322 J-0.3007
N5200 G01 X9.7027 Y4.7857
N5210 G02 X9.6898 Y4.6098 I-0.2376 J-0.0710
N5220 X9.6199 Y4.4866 I-1.3857 J0.7042
N5230 G03 X9.5848 Y4.3651 I0.1887 J-0.1204
N5240 G01 X9.5849 Y4.3625
N5250 G03 X9.7301 Y4.1817 I0.2147 J0.0237
N5260 G01 X9.7385 Y4.1785
N5270 X9.7397 Y4.1781
N5280 G03 X10.0908 Y4.1850 I0.1654 J0.5187
N5290 G01 X10.0919 Y4.1854
N5300 X10.0974 Y4.1877
N5310 X10.0997 Y4.1888
N5320 G03 X10.6809 Y4.6543 I-0.9934 J1.8359
N5330 X10.8120 Y4.8491 I-0.4975 J0.4763
N5340 G01 X10.8122 Y4.8497
N5350 G03 X10.8793 Y5.3303 I-0.8817 J0.3679
N5360 G01 X10.8792 Y5.3310
N5370 X10.8787 Y5.3339
N5380 G03 X10.8124 Y5.5130 I-0.3915 J-0.0434
N5390 G01 X10.8094 Y5.5165
N5400 G02 X10.7470 Y5.6302 I0.1633 J0.1636
N5410 X10.7511 Y5.7824 I0.4033 J0.0653
N5420 G03 X10.7913 Y6.0027 I-3.9071 J0.8272
N5430 G01 X10.7916 Y6.0058
N5440 G02 X10.8297 Y6.2765 I1.2213 J-0.0339
N5450 G03 X11.1600 Y7.7334 I-17.3354 J4.6967
N5460 X11.4503 Y7.3288 I0.8416 J0.2974
N5470 G01 X11.4513 Y7.3280
N5480 G02 X11.5763 Y7.2278 I-0.7377 J-1.0478
N5490 X11.9798 Y6.5793 I-1.1035 J-1.1363
N5500 G03 X12.0272 Y6.5788 I0.0238 J0.0077
N5510 G01 X12.0297 Y6.5861
N5520 X12.0307 Y6.5899
N5530 G02 X12.0790 Y6.8215 I3.8655 J-0.6861
N5540 G03 X12.1257 Y7.1608 I-1.5237 J0.3823
N5550 X12.1185 Y7.4287 I-1.0957 J0.1048
N5560 G01 X12.1184 Y7.4295
N5570 G03 X11.9078 Y7.8961 I-1.0476 J-0.1920
N5580 G01 X11.9056 Y7.8985
N5590 G02 X11.6835 Y8.2794 I0.5861 J0.5970
N5600 G03 X12.4493 Y8.2967 I0.3639 J0.8513
N5610 X12.4434 Y8.3437 I-0.0109 J0.0225
N5620 G02 X11.8192 Y8.9715 I0.1594 J0.7828
N5630 G03 X12.7996 Y8.7270 I0.7305 J0.8413
N5640 X12.8094 Y8.7711 I-0.0056 J0.0244
N5650 G02 X12.1494 Y9.8854 I1.0996 J1.4039
N5660 X12.1048 Y10.3173 I4.8918 J0.7237
N5670 G01 X12.1047 Y10.3204
N5680 Y10.3213
N5690 G03 X11.4786 Y11.9246 I-2.7287 J-0.1416
N5700 X11.1276 Y12.9646 I-2.9545 J-0.4181
N5710 G01 X11.1269 Y12.9658
N5720 G03 X10.0530 Y14.1444 I-3.9072 J-2.4815
N5730 X10.0137 Y14.1177 I-0.0153 J-0.0198
N5740 G02 X10.0489 Y13.7664 I-0.9286 J-0.2704
N5750 G03 X9.4260 Y14.1991 I-2.0468 J-2.2819
N5760 X9.2045 Y14.3131 I-1.4748 J-2.5935
N5770 X8.9326 Y14.4444 I-1.6085 J-2.9837
N5780 X8.6534 Y14.5560 I-1.7105 J-3.8741
N5790 X6.5864 Y14.7033 I-1.2840 J-3.4420
N5800 X6.5829 Y14.6555 I0.0053 J-0.0244
N5810 G02 X6.7899 Y14.5451 I-0.3215 J-0.8522
N5820 G03 X6.5147 Y14.4972 I0.9199 J-6.1007
N5830 G01 X6.5138 Y14.4971
N5840 G03 X4.0150 Y13.2584 I1.3988 J-5.9620
N5850 G01 X4.0143 Y13.2579
N5860 G02 X3.6601 Y13.0266 I-0.9723 J1.1021
N5870 X2.2897 Y12.9099 I-0.8797 J2.2263
N5880 G03 X2.2663 Y12.8683 I-0.0051 J-0.0245
N5890 X2.7773 Y12.5332 I0.9533 J0.8966
N5900 G01 X2.6068 Y12.5166
N5910 X2.6063
N5920 G02 X1.3913 Y12.8933 I-0.1814 J1.5627
N5930 G03 X1.3506 Y12.8685 I-0.0164 J-0.0188
N5940 X1.7533 Y12.1897 I1.3246 J0.3271
N5950 G01 X1.7545 Y12.1887
N5960 G03 X2.2436 Y11.9429 I0.8124 J1.0070
N5970 G02 X1.2250 Y12.1276 I-0.2685 J1.4203
N5980 X0.9415 Y12.3554 I0.6750 J1.1303
N5990 G01 X0.9399 Y12.3572
N6000 G02 X0.7308 Y12.6942 I0.9588 J0.8285
N6010 G01 X0.7296 Y12.6966
N6020 G02 X0.6748 Y12.8120 I0.9028 J0.4996
N6030 X0.5753 Y13.1838 I1.8475 J0.6932
N6040 X0.5669 Y13.2998 I1.2451 J0.1494
N6050 G01 X0.5668 Y13.3005
N6060 G02 X0.5917 Y13.5698 I0.9198 J0.0509
N6070 G03 X0.5500 Y13.5936 I-0.0243 J0.0059
N6080 X0.4452 Y13.4769 I0.8311 J-0.8515
N6090 X0.2888 Y13.2330 I1.4315 J-1.0899
N6100 G01 X0.2885 Y13.2325
N6110 G03 X0.1091 Y12.7977 I2.8329 J-1.4238
N6120 G01 X0.1088 Y12.7970
N6130 G03 X0.0083 Y12.3674 I3.6524 J-1.0817
N6140 X1.1569 Y9.9037 I2.3633 J-0.3978
N6150 G01 X1.1583 Y9.9029
N6160 G02 X1.2151 Y9.8683 I-0.1952 J-0.3852
N6170 G01 X1.2161 Y9.8677
N6180 G02 X1.2901 Y9.7501 I-0.0904 J-0.1390
N6190 X1.2589 Y9.4364 I-1.1313 J-0.0456
N6200 G01 X1.2587 Y9.4359
N6210 G02 X1.1166 Y9.1146 I-0.8686 J0.1923
N6220 G01 X1.1163 Y9.1141
N6230 G02 X0.7472 Y8.7833 I-0.8426 J0.5686
N6240 G03 X0.7584 Y8.7361 I0.0116 J-0.0221
N6250 X1.4023 Y8.9258 I0.0223 J1.1128
N6260 G02 X1.0638 Y8.3448 I-1.5650 J0.5229
N6270 X0.6831 Y8.0417 I-1.0294 J0.9023
N6280 G01 X0.6817 Y8.0409
N6290 G02 X0.4890 Y7.9429 I-0.6561 J1.0518
N6300 X0.1786 Y7.9132 I-0.2043 J0.4991
N6310 G03 X0.1617 Y7.8668 I-0.0049 J-0.0245
N6320 X0.5227 Y7.7082 I1.1068 J2.0290
N6330 G01 X0.5238 Y7.7078
N6340 G03 X1.1921 Y7.6137 I0.6647 J2.2994
N6350 G02 X1.2268 Y7.5311 I-0.1918 J-0.1292
N6360 X1.2311 Y7.3300 I-0.6183 J-0.1139
N6370 X1.1166 Y6.6726 I-22.2872 J3.5423
N6380 G03 X1.5282 Y5.6542 I0.9382 J-0.2132
N6390 G01 X1.4188 Y5.4868
N6400 M05
N6410 G00 Z1.0000
N6420 X0.0000 Y0.0000
N6430 M05 M30
The last two lines are the issue. Its moving the torch to home before turning the torch off. So it scores the material. If I manually switch the last two lines it will turn the torch off and NOT go back to home (which is ultimately what I want). But in this form, with those last two lines it returns to home THEN turns the torch off.
djreiswig
Post by djreiswig »
The code I posted is what I got from the job you posted and the post as it comes with SheetCam with the one modification to get g31 instead of g28.1.
My code should work correctly since the M05 is before the rapid at the end.
I'm not sure why yours is different unless your post has been modified or there's some other setting in SheetCam that is different. I can't duplicate your problem.
Maybe you should post your post processor.
SpoolnMS
Post by SpoolnMS »
Oh, I see now. Weird how certain dxf files are giving different gcodes. . .
Attached are two dxf's. BOTH from the same machine, same settings. One has the m05 before rapid move at the end and the other dosnt.
Should also add that the same file (bullet bill) does the same thing on all my computers, does not have the m05 command before rapid move). Same version of sheetcam, post processor, etc.
Weird how some files get it and others do not
bullet bill regular.dxf
(16.45 KiB) Downloaded 91 times
Trump punisher.dxf
(20.35 KiB) Downloaded 80 times
djreiswig
Post by djreiswig »
I didn't open the dxf. I just opened the job file you posted. Is this the same job file that your code came from, because the coordinates are different than what is in my code?
SpoolnMS
Post by SpoolnMS »
Should have been. I just did 6 other dxf files and they all put the m05 before rapid move. Maybe that one dxf is tainted some how?
djreiswig
Post by djreiswig »
And if you download the job file from here and repost it in SheetCam you still get bad code?
I also can't figure out why my code is much shorter than yours.
SpoolnMS
Post by SpoolnMS »
djreiswig wrote: Fri Feb 07, 2020 3:10 am And if you download the job file from here and repost it in SheetCam you still get bad code?
Yes its still missing the m05 command before rapid move at the end.
And no clue.
djreiswig
Post by djreiswig »
I'm baffled. Hopefully Les can provide some insight.
That bullet bill regular file was done with a rapid clearance of 0.06", which is below your cut height.
SpoolnMS
Post by SpoolnMS »
Wanted to update, it was the rapid clearance that was the issue. I was playing with the rapid clearance settings and lower then the cut height would not produce the M05 command. This issue is fixed. Thanks everyone for the help!
djreiswig
Post by djreiswig »
I guess that explains why no OnPenUp. It didn't need to move the Z since the height was lower.
I wonder what application one would ever set the rapid clearance lower than the cut height. With all of the confusion caused by this small oversight, maybe it would be a good place for a warning message in the software.
