Tolerance
Tolerance
Hello, i usually cut thick plate and with my tools i gets overall 1/16 tolerance and i think its fine for my use. I set my offset outside so i get 1/16 less for external side and it set automatique hole inside and its give me 1/16 smaller hole. But this time i would like to get tolerance reverse for the holes ..to make them bigger. So i tryed to set hole on a layer and set outside but the lead in is not in the right side . is it possible top reverse it ?
Re: Tolerance
in fact i just try to find a ways to make my hole bigger instead of smaller with my too .. when i put it on outside offset it give me the lead-ins in the wrong side. I can use no offset but i dont think its gonna make a good cut.
