Howto ingnore holes where pierce won't fit
Posted: Thu Sep 26, 2019 9:55 am
by Jolbas
Is there a way to ignore holes where the kerf fits but the damage from piercing will destroy the part? Somtimes when the hole is shaped so that two pierces is necessary there is no way to control them separately.
- Skärmavbild 2019-09-26 kl. 11.48.04.png (45.24 KiB) Viewed 2017 times
Re: Howto ingnore holes where pierce won't fit
Posted: Thu Sep 26, 2019 11:29 am
by mancavedweller
There certainly is.
Posted: Thu Sep 26, 2019 12:08 pm
by Jolbas
Great. But how?
Posted: Thu Sep 26, 2019 6:22 pm
About all you can do is move the troublesome outlines onto a different layer and not cut them. If you really want them cut you might be able to get away with cheating the kerf width. Define a tool with a small enough kerf to fit in them. Of course this will mean the holes come out over size but there isn't much you can do about that.
Posted: Fri Sep 27, 2019 8:35 pm
by Jolbas
Ok. Thanks for the kerf width workaround. In this case I edited the drawing to remove the most narrow bottlenecks.
Posted: Sat Sep 28, 2019 3:19 pm
That is the best solution.
