Speed of Straight Cuts
m3customdesigns
Post by m3customdesigns »
I've noticed that cutting speeds up when the path is a straight line. This seems to be causing issues with many of my cuts. Is this a setting that can be adjusted?
Thanks!!
djreiswig
Re: Speed of Straight Cuts
Post by djreiswig »
Your machine is probably not capable of cutting the non straight areas at the programmed speed so it slows down in those areas. You can use cut rules to force a slow down in certain areas, but there isn't a way to slow down a straight path unless you just slow the feedrate in the tool.
m3customdesigns
This makes perfect sense, but is not something I had thought of. Thank you!
