6.1.59 Problems
- Contact:
6.1.59 Problems
Here are a few issues ive noticed already with the latest version:
1. The shape library is missing all the shapes. The directory is empty.
2. When opening the tool table editor, the table opens in a corner of the window and it cannot be expanded.
See attached photos for reference.
- 2.JPG (118.28 KiB) Viewed 10933 times
- 1.JPG (48.33 KiB) Viewed 10933 times
Re: 6.1.59 Problems
Sorry about that. I'll release an update shortly.
- Contact:
Re: 6.1.59 Problems
No problem, just letting you know
- Contact:
Re: 6.1.59 Problems
Found another bug Les... when the overcut in the operation is specified to be anything other than 0, the lead out is not shown regardless of type of length of leadout.
And while we're on the subject of the overcut, in the properties for each start point, would it be possible to specify a different overcut value instead of only disabling the overcut?
Re: 6.1.59 Problems
This will be fixed in the next release. I'll also add overcut length.
- Contact:
Re: 6.1.59 Problems
Awesome Les, thank you so much!!
One last thing i just found now, perhaps i'm being picky... When the new override overcut is checked and set to 0 and start point is a square corner, tangent leadins are not truly tangent. When the operation overcut is 0 and the override overcut is disabled, it works as i would expect. see the attached screenshots.
- without overcut.JPG (47.79 KiB) Viewed 10893 times
- with overcut.JPG (58.12 KiB) Viewed 10893 times
Re: 6.1.59 Problems
Huh, that shouldn't happen. I'll look into it.
Re: 6.1.59 Problems
Did you get a chance to look at this as well Les?
https://www.forum.sheetcam.com/viewtopi ... 055#p26152
Re: 6.1.59 Problems
I can't replicate that fault. I will run some more tests.
Re: 6.1.59 Problems
It does it on both my win 7 machines, I can open a job file from sheetcam no problem, its when you open a job file from outside sheetcam the problem is, it opens the job file but it seem to be a copy, says untitled in the title bar.
Many thanks
Many thanks
Re: 6.1.59 Problems
Hello
Problem with Rules if I do not want to run it and put none then executed the postprocessor insert the rules in the G code
- 2.png (26.95 KiB) Viewed 10872 times
- 1.png (48.3 KiB) Viewed 10872 times
- MDG.job
- (95.08 KiB) Downloaded 68 times
Re: 6.1.59 Problems
This is the postprocessor that I am using
- Mach3 THC M25 y Marcador de chapa.scpost
- (10.1 KiB) Downloaded 71 times
Re: 6.1.59 Problems
I have already solved it was postprocessor problem
- Contact:
Re: 6.1.59 Problems
Hey Les,
I'm not sure if the .63 update was supposed to fix the issue with the overcut on the corners, but if it was, the problem still exists on mine.
Re: 6.1.59 Problems
Could you send me a job file that demonstrates the problem.
