As per the title: Kerf Width, is it available to the post processor / code snippets?
say I want to do something via a path rule (before end), is it possible to enter a variable in the distance such as kerf width?
Or is it possible to use a mathermatical expression such as kerf width + leadout?
Rob
Re: Kerf Width, is it available to the post processor / code snippets?
Kerf width isn't available to path rules. It is available to the post processor as the variable 'toolDia' but that means you need to edit the post processor to use the variable.
That'll probably do that its available for the post processor.
