Loop inner corners
Re: Loop inner corners
Looks good Les, I'll let you know how it works out! Thanks again.
Working for me. Thanks a lot.
For some reason no matter what options I fiddle with, I cannot get SheetCam to loop inside corners... any thoughts? (I'm assuming this was an added feature due to the previous replies on this thread)
This is only in the development version. Dev gets the new toys as they are developed. Stable only gets them once they have been thoroughly tested and there is a new major release (V7.x).
Look for the 'overcut internal corners' option.
It seems this feature activates sometimes on small arcs too. I think it wold be better if it happens only if there is a corner on the actual drawing.
- Skärmavbild 2020-06-12 kl. 08.40.23.png (63.56 KiB) Viewed 3597 times
If you look at the tool path slight errors in the positioning of the arcs on the outline mean that the tool paths don't form perfect tangential arcs. You are ending up with corners so SheetCam adds the overcut. You should be able to dial that out by increasing the angle threshold.
Does anyone know if this feature got added to sheetcam after? Would be very handy for me with tab and slot work instead of drawing the dogbones on the cad file manually?
Yes, look for the 'Overcut internal corners' settings in your cut operation.
