Page 1 of 2
Odd behaviour on first job loading
Posted: Thu May 09, 2019 9:44 am
by Davek0974
Hi all,
I have an issue when starting sheet cam up, maybe 75% of the time when i open the first job, it loads up as a garbled mess as shown in the pic attached..
- Screen Shot 2019-05-09 at 08.58.51.png (534.35 KiB) Viewed 4455 times
The parts are correct but there are two overlapping sheets and some parts are shifted or piled up in the lower left corner?
The only thing to do is shut the job and re-open it or open a different job - it only ever affects the first job opened.
Anyone else see this?
Re: Odd behaviour on first job loading
Posted: Thu May 09, 2019 10:11 am
That strikes me as an odd graphics issue. When it does that try disabling then enabling one of the parts. Do the oddities go away?
Posted: Thu May 09, 2019 11:56 am
by Davek0974
Les Newell wrote: ↑Thu May 09, 2019 10:11 am
I've never tried that, just done it many wierd things happen...
the material image/background disappeared
disabling and enabling different parts make things 'move' about, mostly even worse than 1st load.
- Screen Shot 2019-05-09 at 12.54.05.png (389.06 KiB) Viewed 4450 times
That was after disabling and enabling one of the large cockerels !
Posted: Thu May 09, 2019 12:48 pm
OK, this is definitely a graphics issue. Are you using Windows or Linux?
Posted: Thu May 09, 2019 1:27 pm
by Davek0974
Hmm, thought it might be or the forum would be buzzing
I am running Windows 7 in a virtual machine (parallels) on a Mac
Is there a specific setting maybe i should be looking at?
Dave
Posted: Fri May 10, 2019 8:21 am
I'd suggest trying the development version of SheetCam. It does a few things to try to work around issues like this.
Posted: Mon Jul 15, 2019 7:20 am
by Davek0974
Les Newell wrote: ↑Fri May 10, 2019 8:21 am
Hi again,
can i run both on one PC?
I don't want to risk upsetting my normal install but really need to find a fix for this trouble.
Yesterday it was really playing up and was loading jobs with parts missing and corrupted etc, now I know its doing it I can get out by closing and re-starting it, if i save the job it saves the corrupt version! Surely if it was graphics it wouldn't do that?
Posted: Mon Jul 15, 2019 11:46 am
Yes you can. The dev version installs independently of the stable version. You will need to install your license on the dev version as it won't see the stable version's license. It is fine to use the same license on both as long as they are both on the same computer.
That is odd. I have no explanation for that one.
Posted: Mon Jul 15, 2019 3:23 pm
by Davek0974
got it installed and set up. Will do some tests on it and see if the issue happens again.
Posted: Tue Jul 16, 2019 7:11 am
by Davek0974
Hi again
It seems ok so far, only issue i have is that when i imported my tool box, it changed all the names?
I used to have "T100 3mm Mild Steel 45A"
Now I have "T100 Plasma 1mm Kerf"
Can i change something and re-import???
Also is it ok to use my existing JOB files etc if i might want to go back to the stable version later?
Dave
Posted: Tue Jul 16, 2019 10:45 am
by Davek0974
Fixed the tools - uncheck "Automatically generate name" in the tool table and re-import
So last question is are the job files usable between dev and stable versions?
Posted: Tue Jul 16, 2019 11:31 am
I have been very careful to maintain job file compatibility between versions. If you load a newer job file into an older version of SheetCam any new features will be ignored but the rest should load correctly. Newer versions of SheetCam should of course load older job files with no issues.
Posted: Tue Jul 16, 2019 1:04 pm
by Davek0974
Ok thanks
i was a bit concerned as I store my jobs as steel sheet numbers - i never use a whole sheet in one go so the job gets stored and built up etc until the sheet is done then i start a new file.
I didn't want to continue on the DEV version if would alter my files in a way the regular app could not read.
Posted: Tue Jul 16, 2019 2:10 pm
by djreiswig
Davek0974 wrote: ↑Tue Jul 16, 2019 10:45 am
This threw me once too. It seems odd to have an obscure setting that changes the names of all of your already created tools when you open the toolset. I get generating a name for a new tool automatically, but having that setting sticky and causing existing tool names to be changed seems weird.
Posted: Sat Jul 20, 2019 9:06 am
by Davek0974
Ok so the DEV version certainly
does seem to have fixed my issues, works perfectly every time and I have tried to make it fail but no luck
I will stick with the DEV version now.
The only oddity i can see is where you have a part on a job highlighted, then select "New Part", the part that was highlighted is copied to the home location - very odd and it disappears once the new part is imported, it does not have any detrimental effect on the sheet which is good.
Any ideas?
