Rehashing old hole not found problem
Posted: Mon Apr 22, 2019 1:42 pm
I know this has been gone over many times but I can't seem to get it fixed,
It only seems to happen if I try to drill twice with the same hole..
If I create a drill process for the hole say to do a spot drill, the drill bit is .125 and create it, I get no errors.
now if I pick the same hole and switch to a .250 to drill though the hole is when I get no holes found.
I have changed the min and max size but doesn't matter only seems to happen if I try to drill the same hole even
moved it to a different layer so spot and drill though have there own lay names..
I have created the dxf file with both solidworks and autocad no difference..
Any suggestions?
Also is there a way to edit the post process so all lines start with a G0 G00 G01 exc, I am using auggie for some projects and it doesn't seem to like any lines that don't start with a G command I looked though the G code and a lot of lines started with Z-.00 or X or Y but no G to start the line..
thanks gary
Any suggestions?
thanks gary
