Postprocessor for CNC controller SH 2012AH-QG
kuznetsoff
Post by kuznetsoff » Wed Aug 01, 2018 2:37 pm
Good afternoon, colleagues.
I purchased a Chinese air-plasma cutting machine.
with CNC controller SH 2012AH-QG and THC SH-HC30.
The Chinese manufacturer did not send anything from the manual and software.
Therefore, I drew attention to SHEETCAM.
I downloaded from you from the site a demo version, in order to try before you buy.
I was wondering if this program will work with the controller SH 2012AH-QG.
I tried the postprocessors which are built into the SHEETCAM program, but I did not find anything suitable.
I would like to contact the developers and friends on this forum.
Is there a postprocessor for such a controller?
Just in case, I give below the beginning and end of G-code:
G92X0Y0
G91
G41
M07
G1X-3,536Y3,536
G3I4,950J-4,950
G1X3,536Y-3,536
M08
G40
G0X74,000
G41
M07
G1X-3,536Y3,536
G3I4,950J-4,950
G1X3,536Y-3,536
M08
G40
G0X8,000Y112,115
G41
G41
M07
G1X5,000
X110,000
X130,000Y-115,615
Y-100,000
X-130,000Y-114,615
X-110,000
Y330,230
Y5,000
M08
G40
M02
I will be grateful if anyone helps me
Re: Postprocessor for CNC controller SH 2012AH-QG
Post by Les Newell » Wed Aug 01, 2018 3:54 pm
I think you need the START post processor. This comes with SheetCam.
kuznetsoff
Post by kuznetsoff » Wed Aug 01, 2018 7:07 pm
Dear Les, the first thing I saw was a post-processor start. But the code does not fit.
The nearest option is the postprocessor "Hiperterm eyge" in your program. This post creates a g-code similar. But the beginning of the code is not right .
When choosing a program, I wanted the postprocessor to work correctly and there was no need to manually correct the g-code.
This is the main thing that I wanted.
Post by Les Newell » Thu Aug 02, 2018 11:11 am
Could you generate some g-code with the Hyperthem Edge post then edit it to suit your machine. If you give me both files I'll modify a post to suit.
