Moreposts plugin problem
mariusl
Post by mariusl » Thu Jul 26, 2018 10:14 am
Hi
I am trying to use the moreposts plugin but it will not execute any post except the first one. There is a message that flashes so fast that I cannot see what the problem is.
I did edit the macro to include the posts that I want but as I cannot see the error ....
Any ideas?
Re: Moreposts plugin problem
Post by Les Newell » Thu Jul 26, 2018 12:16 pm
Do you see anything in the log (Help->debug log)?
mariusl
Post by mariusl » Thu Jul 26, 2018 2:36 pm
Hi Les
No entries at all. At least from the post process.
Post by Les Newell » Thu Jul 26, 2018 2:39 pm
Just checking - you do have valid posts selected in Options->plugin options->moreposts don't you?
What version of SheetCam are you using and what operating system?
mariusl
Post by mariusl » Thu Jul 26, 2018 3:07 pm
The post I selected is a working post that I used on a customers machine. It works as the primary post. I tried several other posts.
I am on Windows 10 and the version is 6.0.26 (production)
Post by Les Newell » Thu Jul 26, 2018 3:41 pm
I suspect you have an old version of the plugin. I have attached the latest version. Don't edit the macro file to add posts. Instead go to Options->plugin options->moreposts and select the posts in there.
manyposts.zip
(3.05 KiB) Downloaded 17 times
mariusl
Post by mariusl » Fri Jul 27, 2018 7:37 am
Thanks Les. Are the plugins not updated with a new release? If not, how do I make sure my plugin stuff is up to date? I have several and some at customers.
Post by Les Newell » Fri Jul 27, 2018 8:24 am
6.0.26 doesn't come with the plugin so you must have installed it manually at some point. The dev version does come with the plugin.
mariusl
Post by mariusl » Fri Jul 27, 2018 1:18 pm
Ah ok that makes sense. Thanks.
