Reduced warping of sheer steel
R Shore
Post by R Shore » Thu Jul 12, 2018 11:20 pm
Am cutting a large number of 3/4in squares, much like welded wire mesh, with just 1/8th between squares. Was wondering if there is a way to set the cut order to bounce around the sheet and not build up heat (warping) so much. In the past the cut path tends to stay in the general area and add too much heat to a smaller area, this the warping. I keep the water level about 1/2in below the sheet, but still an some cuts O get some warping. This project needs to remain very flat. Any ideas? Thanks
Re: Reduced warping of sheer steel
Post by Les Newell » Fri Jul 13, 2018 11:10 am
In your jet cutting oeration go to the cut path tab. Set the optimisation to auto and the cutting rules to 'minimuse thermal distortion'. That should help.
R Shore
Post by R Shore » Fri Jul 13, 2018 2:22 pm
Thanks, I suspected there was a way. Your suggestion worked.
