Grbl problems
polemidis
Grbl problems
Post by polemidis »
Hello, I just bought the sheetcam and along other minor problems (frequent freezes) on Linux I have one that looks serious.
I use the Grbl THC with scriber post processor, but the g-code it generates, has lines without any G command , just X and Y lines with values. No G01 G00 or anything like that in the beginning, so the grbl sender throughs errors. Can you help me? Because without that I cannot use the program.
What do yuou need to debug it? I am uploading the .job and the .gcode
The only edit I did on the post processor is that I changed the setting on the Z axis after the probe from 1.5mm to 5mm
grapple.job
(71.4 KiB) Downloaded 213 times
N0010 G20
N0020 F1
N0030 G53 G90 G40
N0040 G00 X1.2251 Y0.9985
N0050 G38.2 z-1.969 F19.685
N0060 G92 Z0.0
N0070 G00 Z0.1969
N0080 G92 Z0.0
N0090 G00 Z0.2000
N0100 M03
N0110 G04 P1.0
N0120 G02 X1.3139 Y1.0386 Z0.1000 I0.0931 J-0.0879 F600.0
N0130 X1.4060 Y1.0037 I0.0042 J-0.1279 F45.0
N0140 G01 X1.4758 Y0.9378
N0150 X1.5749 Y0.7743
N0160 X1.6332 Y0.5820
N0170 G03 X1.6615 Y0.5610 I0.0283 J0.0086
N0180 G01 X1.8819
N0190 G03 X1.9114 Y0.5906 I0.0000 J0.0296
N0200 G01 Y3.5906
N0210 G03 X1.8819 Y3.6201 I-0.0296 J0.0000
N0220 G01 X0.1319
N0230 G03 X0.1023 Y3.5906 I0.0000 J-0.0296
N0240 G01 Y0.5906
N0250 G03 X0.1319 Y0.5610 I0.0295 J0.0000
N0260 G01 X0.3726
N0270 G03 X0.4009 Y0.5820 I0.0000 J0.0296
N0280 G01 X0.4592 Y0.7743
N0290 X0.5583 Y0.9378
N0300 X0.6914 Y1.0635
N0310 X0.8482 Y1.1425
N0320 X1.0170 Y1.1694
N0330 X1.1859 Y1.1425
N0340 X1.3427 Y1.0635
N0350 X1.4060 Y1.0037
N0360 G02 X1.4086 Y0.9132 I-0.0439 J-0.0465
N0370 M05
N0380 G04 P0.3
N0390 G00 Z1.0000
N0400 X12.3400 Y1.8274
N0410 G38.2 z-1.969 F19.685
N0420 G92 Z0.0
N0430 G00 Z0.1969
N0440 G92 Z0.0
N0450 G00 Z0.2000
N0460 M03
N0470 G04 P1.0
N0480 G02 X12.2499 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N0490 X12.2120 Y1.9554 I0.0901 J0.0909 F45.0
N0500 I0.7205 J0.0000
N0510 X12.2760 Y2.0194 I0.0640 J0.0000
N0520 M05
N0530 G04 P0.3
N0540 G00 Z1.0000
N0550 X1.7800 Y7.3657
N0560 G38.2 z-1.969 F19.685
N0570 G92 Z0.0
N0580 G00 Z0.1969
N0590 G92 Z0.0
N0600 G00 Z0.2000
N0610 M03
N0620 G04 P1.0
N0630 G02 X1.6899 Y7.4028 Z0.1000 I0.0000 J0.1280 F600.0
N0640 X1.6520 Y7.4937 I0.0901 J0.0909 F45.0
N0650 I1.4704 J0.0000
N0660 X1.7160 Y7.5577 I0.0640 J0.0000
N0670 M05
N0680 G04 P0.3
N0690 G00 Z1.0000
N0700 X4.4545 Y18.2808
N0710 G38.2 z-1.969 F19.685
N0720 G92 Z0.0
N0730 G00 Z0.1969
N0740 G92 Z0.0
N0750 G00 Z0.2000
N0760 M03
N0770 G04 P1.0
N0780 G02 X4.3643 Y18.3179 Z0.1000 I0.0000 J0.1280 F600.0
N0790 X4.3265 Y18.4088 I0.0901 J0.0909 F45.0
N0800 I0.7205 J0.0000
N0810 X4.3905 Y18.4728 I0.0640 J0.0000
N0820 M05
N0830 G04 P0.3
N0840 G00 Z1.0000
N0850 X4.1884 Y3.5787
N0860 G38.2 z-1.969 F19.685
N0870 G92 Z0.0
N0880 G00 Z0.1969
N0890 G92 Z0.0
N0900 G00 Z0.2000
N0910 M03
N0920 G04 P1.0
N0930 G02 X4.0982 Y3.6158 Z0.1000 I0.0000 J0.1280 F600.0
N0940 X4.0604 Y3.7067 I0.0901 J0.0909 F45.0
N0950 I1.4705 J0.0000
N0960 X4.1244 Y3.7707 I0.0640 J0.0000
N0970 M05
N0980 G04 P0.3
N0990 G00 Z1.0000
N1000 X3.7712 Y15.7308
N1010 G38.2 z-1.969 F19.685
N1020 G92 Z0.0
N1030 G00 Z0.1969
N1040 G92 Z0.0
N1050 G00 Z0.2000
N1060 M03
N1070 G04 P1.0
N1080 G02 X3.6810 Y15.7679 Z0.1000 I0.0000 J0.1280 F600.0
N1090 X3.6432 Y15.8588 I0.0901 J0.0909 F45.0
N1100 I0.7205 J0.0000
N1110 X3.7072 Y15.9228 I0.0640 J0.0000
N1120 M05
N1130 G04 P0.3
N1140 G00 Z1.0000
N1150 X8.8140 Y2.1283
N1160 G38.2 z-1.969 F19.685
N1170 G92 Z0.0
N1180 G00 Z0.1969
N1190 G92 Z0.0
N1200 G00 Z0.2000
N1210 M03
N1220 G04 P1.0
N1230 G02 X8.7239 Y2.1655 Z0.1000 I0.0000 J0.1280 F600.0
N1240 X8.6860 Y2.2563 I0.0901 J0.0909 F45.0
N1250 I0.7204 J-0.0000
N1260 X8.7500 Y2.3203 I0.0640 J0.0000
N1270 M05
N1280 G04 P0.3
N1290 G00 Z1.0000
N1300 X3.0879 Y13.1807
N1310 G38.2 z-1.969 F19.685
N1320 G92 Z0.0
N1330 G00 Z0.1969
N1340 G92 Z0.0
N1350 G00 Z0.2000
N1360 M03
N1370 G04 P1.0
N1380 G02 X2.9977 Y13.2178 Z0.1000 I0.0000 J0.1280 F600.0
N1390 X2.9599 Y13.3087 I0.0901 J0.0909 F45.0
N1400 I0.7205 J0.0000
N1410 X3.0239 Y13.3727 I0.0640 J0.0000
N1420 M05
N1430 G04 P0.3
N1440 G00 Z1.0000
N1450 X2.5497 Y10.6131
N1460 Z0.2000
N1470 M03
N1480 G04 P1.0
N1490 G02 X2.4596 Y10.6503 Z0.1000 I0.0000 J0.1280 F600.0
N1500 X2.4217 Y10.7411 I0.0901 J0.0909 F45.0
N1510 I0.9112 J-0.0000
N1520 X2.4857 Y10.8051 I0.0640 J0.0000
N1530 M05
N1540 G04 P0.3
N1550 G00 Z1.0000
N1560 X15.5038 Y1.8274
N1570 G38.2 z-1.969 F19.685
N1580 G92 Z0.0
N1590 G00 Z0.1969
N1600 G92 Z0.0
N1610 G00 Z0.2000
N1620 M03
N1630 G04 P1.0
N1640 G02 X15.4137 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N1650 X15.3758 Y1.9554 I0.0901 J0.0909 F45.0
N1660 I1.0954 J0.0000
N1670 X15.4398 Y2.0194 I0.0640 J0.0000
N1680 M05
N1690 G04 P0.3
N1700 G00 Z1.0000
N1710 X26.1203 Y1.8274
N1720 G38.2 z-1.969 F19.685
N1730 G92 Z0.0
N1740 G00 Z0.1969
N1750 G92 Z0.0
N1760 G00 Z0.2000
N1770 M03
N1780 G04 P1.0
N1790 G02 X26.0301 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N1800 X25.9923 Y1.9554 I0.0901 J0.0909 F45.0
N1810 I1.0955 J-0.0000
N1820 X26.0563 Y2.0194 I0.0640 J0.0000
N1830 M05
N1840 G04 P0.3
N1850 G00 Z1.0000
N1860 X19.0426 Y1.8274
N1870 G38.2 z-1.969 F19.685
N1880 G92 Z0.0
N1890 G00 Z0.1969
N1900 G92 Z0.0
N1910 G00 Z0.2000
N1920 M03
N1930 G04 P1.0
N1940 G02 X18.9525 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N1950 X18.9146 Y1.9554 I0.0901 J0.0909 F45.0
N1960 I1.0955 J0.0000
N1970 X18.9786 Y2.0194 I0.0640 J0.0000
N1980 M05
N1990 G04 P0.3
N2000 G00 Z1.0000
N2010 X29.8097 Y1.8274
N2020 G38.2 z-1.969 F19.685
N2030 G92 Z0.0
N2040 G00 Z0.1969
N2050 G92 Z0.0
N2060 G00 Z0.2000
N2070 M03
N2080 G04 P1.0
N2090 G02 X29.7196 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N2100 X29.6817 Y1.9554 I0.0901 J0.0909 F45.0
N2110 I0.6279 J0.0000
N2120 X29.7457 Y2.0194 I0.0640 J0.0000
N2130 M05
N2140 G04 P0.3
N2150 G00 Z1.0000
N2160 X22.5815 Y1.8274
N2170 G38.2 z-1.969 F19.685
N2180 G92 Z0.0
N2190 G00 Z0.1969
N2200 G92 Z0.0
N2210 G00 Z0.2000
N2220 M03
N2230 G04 P1.0
N2240 G02 X22.4913 Y1.8645 Z0.1000 I0.0000 J0.1280 F600.0
N2250 X22.4535 Y1.9554 I0.0901 J0.0909 F45.0
N2260 I1.0955 J0.0000
N2270 X22.5175 Y2.0194 I0.0640 J0.0000
N2280 M05
N2290 G04 P0.3
N2300 G00 Z1.0000
N2310 X6.1918 Y7.5659
N2320 G38.2 z-1.969 F19.685
N2330 G92 Z0.0
N2340 G00 Z0.1969
N2350 G92 Z0.0
N2360 G00 Z0.2000
N2370 M03
N2380 G04 P1.0
N2390 G02 X6.0952 Y7.5534 Z0.1000 I-0.0635 J0.1111 F600.0
N2400 X6.0172 Y7.6135 I0.0332 J0.1236 F45.0
N2410 X5.3146 Y13.0475 I6.2514 J3.5707
N2420 G01 X7.1264 Y19.8090
N2430 G03 X7.1055 Y19.8452 I-0.0285 J0.0076
N2440 G01 X4.2077 Y20.6217
N2450 G03 X4.1715 Y20.6008 I-0.0076 J-0.0285
N2460 G01 X0.1598 Y5.6289
N2470 G03 X0.1807 Y5.5927 I0.0285 J-0.0076
N2480 G01 X3.0499 Y4.8239
N2490 X2.2811 Y1.9547
N2500 G03 X2.3020 Y1.9185 I0.0285 J-0.0076
N2510 G01 X8.8020 Y0.1768
N2520 X8.8097 Y0.1758
N2530 X33.8097
N2540 G03 X33.8251 Y0.1802 I0.0000 J0.0295
N2550 G01 X38.3251 Y2.9302
N2560 G03 X38.3229 Y2.9818 I-0.0154 J0.0252
N2570 G01 X36.3229 Y3.9818
N2580 G03 X36.2801 Y3.9554 I-0.0132 J-0.0264
N2590 G01 Y3.2532
N2600 X34.8229 Y3.9818
N2610 G03 X34.7801 Y3.9554 I-0.0132 J-0.0264
N2620 G01 Y3.2532
N2630 X33.3229 Y3.9818
N2640 G03 X33.2801 Y3.9554 I-0.0132 J-0.0264
N2650 G01 Y3.2532
N2660 X31.8229 Y3.9818
N2670 G03 X31.8097 Y3.9849 I-0.0132 J-0.0264
N2680 G01 X12.2686
N2690 G02 X6.0172 Y7.6135 I0.0000 J7.1993
N2700 X6.0410 Y7.7009 I0.0556 J0.0317
N2710 M05
N2720 G04 P0.3
N2730 G00 Z1.0000
N2740 X1.2034 Y13.4001
N2750 G38.2 z-1.969 F19.685
N2760 G92 Z0.0
N2770 G00 Z0.1969
N2780 G92 Z0.0
N2790 G00 Z0.2000
N2800 M03
N2810 G04 P1.0
N2820 G02 X1.2923 Y13.4401 Z0.1000 I0.0931 J-0.0879 F600.0
N2830 X1.3844 Y13.4053 I0.0042 J-0.1279 F45.0
N2840 G01 X1.4542 Y13.3393
N2850 X1.5533 Y13.1759
N2860 X1.6116 Y12.9836
N2870 G03 X1.6398 Y12.9626 I0.0283 J0.0086
N2880 G01 X1.8602
N2890 G03 X1.8898 Y12.9921 I0.0000 J0.0295
N2900 G01 Y15.9921
N2910 G03 X1.8602 Y16.0217 I-0.0296 J0.0000
N2920 G01 X0.1102
N2930 G03 X0.0807 Y15.9921 I0.0000 J-0.0295
N2940 G01 Y12.9921
N2950 G03 X0.1102 Y12.9626 I0.0295 J0.0000
N2960 G01 X0.3509
N2970 G03 X0.3792 Y12.9836 I0.0000 J0.0295
N2980 G01 X0.4375 Y13.1759
N2990 X0.5366 Y13.3393
N3000 X0.6697 Y13.4650
N3010 X0.8265 Y13.5440
N3020 X0.9954 Y13.5709
N3030 X1.1643 Y13.5440
N3040 X1.3211 Y13.4650
N3050 X1.3844 Y13.4053
N3060 G02 X1.3869 Y13.3148 I-0.0439 J-0.0465
N3070 M05
N3080 G04 P0.3
N3090 G00 Z1.0000
N3100 X1.5122 Y17.5590
N3110 G38.2 z-1.969 F19.685
N3120 G92 Z0.0
N3130 G00 Z0.1969
N3140 G92 Z0.0
N3150 G00 Z0.2000
N3160 M03
N3170 G04 P1.0
N3180 G02 X1.4167 Y17.5844 Z0.1000 I0.0000 J0.1920 F600.0
N3190 X1.3202 Y17.7510 I0.0955 J0.1665 F45.0
N3200 I0.5017 J0.0000
N3210 X1.3842 Y17.8150 I0.0640 J0.0000
N3220 M05
N3230 G04 P0.3
N3240 G00 Z1.0000
N3250 X1.9666 Y19.6812
N3260 Z0.2000
N3270 M03
N3280 G04 P1.0
N3290 G02 X1.8694 Y19.6826 Z0.1000 I-0.0470 J0.1135 F600.0
N3300 X1.8061 Y19.7477 I0.0502 J0.1121 F45.0
N3310 I0.1305 J0.0000
N3320 X1.8596 Y19.7699 I0.0378 J-0.0157
N3330 M05
N3340 G04 P0.3
N3350 G00 Z1.0000
N3360 X0.8152 Y24.4593
N3370 G38.2 z-1.969 F19.685
N3380 G92 Z0.0
N3390 G00 Z0.1969
N3400 G92 Z0.0
N3410 G00 Z0.2000
N3420 M03
N3430 G04 P1.0
N3440 G02 X0.8688 Y24.3762 Z0.1000 I-0.1291 J-0.1421 F600.0
N3450 X0.8282 Y24.1881 I-0.1827 J-0.0590 F45.0
N3460 G03 X0.5424 Y23.4485 I0.8140 J-0.7396
N3470 G01 Y17.7510
N3480 G03 X3.0680 Y17.4604 I1.2795 J0.0000
N3490 G01 X3.6007 Y19.7443
N3500 X3.6015 Y19.7510
N3510 Y22.7214
N3520 X5.5719
N3530 G03 X5.5928 Y22.7301 I0.0000 J0.0296
N3540 G01 X7.3606 Y24.4979
N3550 G03 X7.3397 Y24.5483 I-0.0209 J0.0209
N3560 G01 X1.6422
N3570 G03 X0.8282 Y24.1881 I-0.0000 J-1.0998
N3580 G02 X0.7378 Y24.1838 I-0.0474 J0.0430
N3590 M05
N3600 G04 P0.3
N3610 G00 Z1.0000
N3620 X1.5105 Y28.3607
N3630 G38.2 z-1.969 F19.685
N3640 G92 Z0.0
N3650 G00 Z0.1969
N3660 G92 Z0.0
N3670 G00 Z0.2000
N3680 M03
N3690 G04 P1.0
N3700 G02 X1.5994 Y28.4008 Z0.1000 I0.0931 J-0.0879 F600.0
N3710 X1.6914 Y28.3659 I0.0042 J-0.1279 F45.0
N3720 G01 X1.7612 Y28.3000
N3730 X1.8604 Y28.1365
N3740 X1.9187 Y27.9442
N3750 G03 X1.9469 Y27.9232 I0.0283 J0.0086
N3760 G01 X2.1673
N3770 G03 X2.1969 Y27.9528 I0.0000 J0.0296
N3780 G01 Y30.9528
N3790 G03 X2.1673 Y30.9823 I-0.0296 J0.0000
N3800 G01 X0.4173
N3810 G03 X0.3878 Y30.9528 I0.0000 J-0.0296
N3820 G01 Y27.9528
N3830 G03 X0.4173 Y27.9232 I0.0295 J0.0000
N3840 G01 X0.6580
N3850 G03 X0.6863 Y27.9442 I0.0000 J0.0296
N3860 G01 X0.7446 Y28.1365
N3870 X0.8437 Y28.3000
N3880 X0.9768 Y28.4257
N3890 X1.1336 Y28.5047
N3900 X1.3025 Y28.5316
N3910 X1.4714 Y28.5047
N3920 X1.6282 Y28.4257
N3930 X1.6914 Y28.3659
N3940 G02 X1.6940 Y28.2754 I-0.0439 J-0.0465
N3950 M05
N3960 G04 P0.3
N3970 G00 Z1.0000
N3980 X3.1183 Y29.2679
N3990 G38.2 z-1.969 F19.685
N4000 G92 Z0.0
N4010 G00 Z0.1969
N4020 G92 Z0.0
N4030 G00 Z0.2000
N4040 M03
N4050 G04 P1.0
N4060 G02 X3.1864 Y29.1981 Z0.1000 I-0.0508 J-0.1175 F600.0
N4070 X3.1851 Y29.0997 I-0.1188 J-0.0477 F45.0
N4080 G01 X3.1470 Y29.0115
N4090 X3.0273 Y28.8625
N4100 X2.8665 Y28.7419
N4110 G03 X2.8565 Y28.7082 I0.0177 J-0.0236
N4120 G01 X2.9318 Y28.5011
N4130 G03 X2.9697 Y28.4834 I0.0278 J0.0101
N4140 G01 X5.7888 Y29.5095
N4150 G03 X5.8065 Y29.5474 I-0.0101 J0.0278
N4160 G01 X5.2079 Y31.1918
N4170 G03 X5.1700 Y31.2095 I-0.0278 J-0.0101
N4180 G01 X2.3510 Y30.1834
N4190 G03 X2.3333 Y30.1456 I0.0101 J-0.0278
N4200 G01 X2.4156 Y29.9194
N4210 G03 X2.4450 Y29.9000 I0.0278 J0.0101
N4220 G01 X2.6457 Y29.9110
N4230 X2.8332 Y29.8737
N4240 X2.9968 Y29.7917
N4250 X3.1247 Y29.6713
N4260 X3.2077 Y29.5219
N4270 X3.2402 Y29.3540
N4280 X3.2196 Y29.1796
N4290 X3.1851 Y29.0997
N4300 G02 X3.1009 Y29.0663 I-0.0588 J0.0254
N4310 M05
N4320 G04 P0.3
N4330 G00 Z1.0000
N4340 X0.7847 Y34.2598
N4350 G38.2 z-1.969 F19.685
N4360 G92 Z0.0
N4370 G00 Z0.1969
N4380 G92 Z0.0
N4390 G00 Z0.2000
N4400 M03
N4410 G04 P1.0
N4420 G02 X0.8786 Y34.2860 Z0.1000 I0.0787 J-0.1010 F600.0
N4430 X0.9644 Y34.2376 I-0.0152 J-0.1271 F45.0
N4440 X0.3066 Y33.2450 I-0.4953 J-0.3860
N4450 G03 X0.2704 Y33.2241 I-0.0076 J-0.0285
N4460 G01 X0.0763 Y32.4997
N4470 G03 X0.0883 Y32.4675 I0.0285 J-0.0076
N4480 G01 X0.9656 Y31.8778
N4490 G03 X0.9744 Y31.8738 I0.0165 J0.0245
N4500 G01 X3.3893 Y31.2268
N4510 G03 X3.4053 Y31.2270 I0.0076 J0.0285
N4520 G01 X8.4637 Y32.7186
N4530 G03 X8.4749 Y32.7690 I-0.0084 J0.0283
N4540 G01 X6.8019 Y34.2526
N4550 G03 X6.7538 Y34.2381 I-0.0196 J-0.0221
N4560 G01 X6.5720 Y33.5599
N4570 X5.3530 Y34.6408
N4580 G03 X5.3049 Y34.6264 I-0.0196 J-0.0221
N4590 G01 X5.1231 Y33.9481
N4600 X3.9041 Y35.0290
N4610 G03 X3.8560 Y35.0146 I-0.0196 J-0.0221
N4620 G01 X3.6742 Y34.3363
N4630 X2.4552 Y35.4173
N4640 G03 X2.4323 Y35.4245 I-0.0196 J-0.0221
N4650 G01 X0.8300 Y35.2404
N4660 G03 X0.8048 Y35.2187 I0.0034 J-0.0294
N4670 G01 X0.6107 Y34.4943
N4680 G03 X0.6316 Y34.4581 I0.0285 J-0.0076
N4690 G02 X0.9644 Y34.2376 I-0.1625 J-0.6066
N4700 X0.9532 Y34.1478 I-0.0505 J-0.0393
N4710 M05
N4720 G04 P0.3
N4730 G00 Z1.0000
N4740 X1.3570 Y43.3214
N4750 G38.2 z-1.969 F19.685
N4760 G92 Z0.0
N4770 G00 Z0.1969
N4780 G92 Z0.0
N4790 G00 Z0.2000
N4800 M03
N4810 G04 P1.0
N4820 G02 X1.4458 Y43.3614 Z0.1000 I0.0931 J-0.0879 F600.0
N4830 X1.5379 Y43.3265 I0.0042 J-0.1279 F45.0
N4840 G01 X1.6077 Y43.2606
N4850 X1.7068 Y43.0972
N4860 X1.7651 Y42.9048
N4870 G03 X1.7934 Y42.8838 I0.0283 J0.0086
N4880 G01 X2.0138
N4890 G03 X2.0433 Y42.9134 I0.0000 J0.0296
N4900 G01 Y45.9134
N4910 G03 X2.0138 Y45.9429 I-0.0296 J0.0000
N4920 G01 X0.2638
N4930 G03 X0.2342 Y45.9134 I0.0000 J-0.0296
N4940 G01 Y42.9134
N4950 G03 X0.2638 Y42.8838 I0.0295 J0.0000
N4960 G01 X0.5045
N4970 G03 X0.5328 Y42.9048 I0.0000 J0.0296
N4980 G01 X0.5911 Y43.0972
N4990 X0.6902 Y43.2606
N5000 X0.8233 Y43.3863
N5010 X0.9801 Y43.4653
N5020 X1.1489 Y43.4922
N5030 X1.3178 Y43.4653
N5040 X1.4746 Y43.3863
N5050 X1.5379 Y43.3265
N5060 G02 X1.5405 Y43.2360 I-0.0439 J-0.0465
N5070 M05
N5080 G04 P0.3
N5090 G00 Z1.0000
N5100 X3.7645 Y53.3759
N5110 G38.2 z-1.969 F19.685
N5120 G92 Z0.0
N5130 G00 Z0.1969
N5140 G92 Z0.0
N5150 G00 Z0.2000
N5160 M03
N5170 G04 P1.0
N5180 G02 X3.7654 Y53.2784 Z0.1000 I-0.1179 J-0.0499 F600.0
N5190 X3.6965 Y53.2081 I-0.1188 J0.0476 F45.0
N5200 X2.9080 Y54.1004 I-0.2447 J0.5783
N5210 G03 X2.8971 Y54.1408 I-0.0256 J0.0148
N5220 G01 X2.2476 Y54.5158
N5230 G03 X2.2134 Y54.5125 I-0.0148 J-0.0256
N5240 G01 X1.4168 Y53.8177
N5250 G03 X1.4107 Y53.8102 I0.0194 J-0.0223
N5260 G01 X0.1607 Y51.6451
N5270 G03 X0.1567 Y51.6296 I0.0256 J-0.0148
N5280 G01 X0.2883 Y46.3575
N5290 G03 X0.3341 Y46.3336 I0.0295 J0.0007
N5300 G01 X2.2001 Y47.5656
N5310 G03 X2.1986 Y47.6159 I-0.0163 J0.0247
N5320 G01 X1.5905 Y47.9670
N5330 X2.9501 Y48.8647
N5340 G03 X2.9486 Y48.9149 I-0.0163 J0.0247
N5350 G01 X2.3405 Y49.2660
N5360 X3.7001 Y50.1637
N5370 G03 X3.6986 Y50.2140 I-0.0163 J0.0247
N5380 G01 X3.0905 Y50.5651
N5390 X4.4501 Y51.4627
N5400 G03 X4.4631 Y51.4831 I-0.0163 J0.0247
N5410 G01 X4.6999 Y53.0784
N5420 G03 X4.6855 Y53.1083 I-0.0292 J0.0043
N5430 G01 X4.0360 Y53.4833
N5440 G03 X3.9956 Y53.4725 I-0.0148 J-0.0256
N5450 G02 X3.6965 Y53.2081 I-0.5438 J0.3140
N5460 X3.6126 Y53.2421 I-0.0249 J0.0589
N5470 M05
N5480 G04 P0.3
N5490 G00 Z1.0000
N5500 X2.3108 Y56.2976
N5510 G38.2 z-1.969 F19.685
N5520 G92 Z0.0
N5530 G00 Z0.1969
N5540 G92 Z0.0
N5550 G00 Z0.2000
N5560 M03
N5570 G04 P1.0
N5580 G02 X2.2736 Y56.2074 Z0.1000 I-0.1280 J0.0000 F600.0
N5590 X2.1828 Y56.1696 I-0.0909 J0.0901 F45.0
N5600 I-0.0000 J0.7517
N5610 X2.1188 Y56.2336 I0.0000 J0.0640
N5620 M05
N5630 G04 P0.3
N5640 G00 Z1.0000
N5650 X0.5666 Y55.4862
N5660 Z0.2000
N5670 M03
N5680 G04 P1.0
N5690 G02 X0.6566 Y55.5236 Z0.1000 I0.0905 J-0.0905 F600.0
N5700 X0.7476 Y55.4862 I0.0005 J-0.1280 F45.0
N5710 G03 X2.6131 Y54.9379 I1.4351 J1.4351
N5720 G01 X5.1032 Y55.4782
N5730 G03 X5.1179 Y55.5279 I-0.0063 J0.0289
N5740 G01 X3.7245 Y56.9213
N5750 X5.1179 Y58.3146
N5760 G03 X5.1032 Y58.3644 I-0.0209 J0.0209
N5770 G01 X2.6131 Y58.9047
N5780 G03 X0.7476 Y55.4862 I-0.4304 J-1.9834
N5790 G02 Y55.3956 I-0.0453 J-0.0453
N5800 M05
N5810 G04 P0.3
N5820 G00 Z1.0000
N5830 X7.5940 Y57.7779
N5840 G38.2 z-1.969 F19.685
N5850 G92 Z0.0
N5860 G00 Z0.1969
N5870 G92 Z0.0
N5880 G00 Z0.2000
N5890 M03
N5900 G04 P1.0
N5910 G02 X7.6340 Y57.6890 Z0.1000 I-0.0879 J-0.0931 F600.0
N5920 X7.5992 Y57.5969 I-0.1279 J-0.0042 F45.0
N5930 G01 X7.5332 Y57.5271
N5940 X7.3698 Y57.4280
N5950 X7.1775 Y57.3697
N5960 G03 X7.1565 Y57.3415 I0.0086 J-0.0283
N5970 G01 Y57.1211
N5980 G03 X7.1860 Y57.0915 I0.0296 J0.0000
N5990 G01 X10.1860
N6000 G03 X10.2156 Y57.1211 I0.0000 J0.0296
N6010 G01 Y58.8711
N6020 G03 X10.1860 Y58.9006 I-0.0296 J0.0000
N6030 G01 X7.1860
N6040 G03 X7.1565 Y58.8711 I0.0000 J-0.0296
N6050 G01 Y58.6304
N6060 G03 X7.1775 Y58.6021 I0.0295 J0.0000
N6070 G01 X7.3698 Y58.5438
N6080 X7.5332 Y58.4447
N6090 X7.6589 Y58.3116
N6100 X7.7379 Y58.1548
N6110 X7.7648 Y57.9859
N6120 X7.7379 Y57.8170
N6130 X7.6589 Y57.6602
N6140 X7.5992 Y57.5969
N6150 G02 X7.5087 Y57.5944 I-0.0465 J0.0439
N6160 M05
N6170 G04 P0.3
N6180 G00 Z1.0000
N6190 X14.8705 Y55.6501
N6200 G38.2 z-1.969 F19.685
N6210 G92 Z0.0
N6220 G00 Z0.1969
N6230 G92 Z0.0
N6240 G00 Z0.2000
N6250 M03
N6260 G04 P1.0
N6270 G02 X14.7739 Y55.6372 Z0.1000 I-0.0640 J0.1109 F600.0
N6280 X14.6956 Y55.6969 I0.0326 J0.1238 F45.0
N6290 I0.6510 J0.3759
N6300 X14.7190 Y55.7844 I0.0554 J0.0320
N6310 M05
N6320 G04 P0.3
N6330 G00 Z1.0000
N6340 X15.8034 Y46.3967
N6350 G38.2 z-1.969 F19.685
N6360 G92 Z0.0
N6370 G00 Z0.1969
N6380 G92 Z0.0
N6390 G00 Z0.2000
N6400 M03
N6410 G04 P1.0
N6420 G02 X15.7068 Y46.3838 Z0.1000 I-0.0640 J0.1109 F600.0
N6430 X15.6286 Y46.4435 I0.0326 J0.1238 F45.0
N6440 G01 X15.4783 Y46.7039
N6450 X18.0507 Y48.1891
N6460 G03 X18.0653 Y48.2181 I-0.0148 J0.0256
N6470 G01 X17.1139 Y56.2813
N6480 G03 X13.6052 Y56.4393 I-1.7673 J-0.2085
N6490 G01 X12.0429 Y49.0155
N6500 G03 X12.0462 Y48.9946 I0.0289 J-0.0061
N6510 G01 X15.7653 Y42.5530
N6520 G03 X15.8194 Y42.5602 I0.0256 J0.0148
N6530 G01 X16.4664 Y44.9750
N6540 G03 X16.4635 Y44.9974 I-0.0285 J0.0076
N6550 G01 X15.6286 Y46.4435
N6560 G02 X15.6520 Y46.5310 I0.0554 J0.0320
N6570 M05
N6580 G04 P0.3
N6590 G00 Z1.0000
N6600 X18.1649 Y45.0456
N6610 G38.2 z-1.969 F19.685
N6620 G92 Z0.0
N6630 G00 Z0.1969
N6640 G92 Z0.0
N6650 G00 Z0.2000
N6660 M03
N6670 G04 P1.0
N6680 G02 X18.0748 Y45.0828 Z0.1000 I0.0000 J0.1280 F600.0
N6690 X18.0369 Y45.1736 I0.0901 J0.0909 F45.0
N6700 I0.7517 J0.0000
N6710 X18.1009 Y45.2376 I0.0640 J0.0000
N6720 M05
N6730 G04 P0.3
N6740 G00 Z1.0000
N6750 X17.3535 Y46.7898
N6760 Z0.2000
N6770 M03
N6780 G04 P1.0
N6790 G02 X17.3910 Y46.6998 Z0.1000 I-0.0905 J-0.0905 F600.0
N6800 X17.3535 Y46.6088 I-0.1280 J-0.0005 F45.0
N6810 G03 X16.8052 Y44.7433 I1.4351 J-1.4351
N6820 G01 X17.3456 Y42.2532
N6830 G03 X17.3953 Y42.2385 I0.0289 J0.0063
N6840 G01 X18.7886 Y43.6319
N6850 X20.1820 Y42.2385
N6860 G03 X20.2317 Y42.2532 I0.0209 J0.0209
N6870 G01 X20.7720 Y44.7433
N6880 G03 X17.3535 Y46.6088 I-1.9834 J0.4304
N6890 G02 X17.2630 I-0.0453 J0.0453
N6900 M05
N6910 G04 P0.3
N6920 G00 Z1.0000
N6930 X18.8361 Y39.6226
N6940 G38.2 z-1.969 F19.685
N6950 G92 Z0.0
N6960 G00 Z0.1969
N6970 G92 Z0.0
N6980 G00 Z0.2000
N6990 M03
N7000 G04 P1.0
N7010 G02 X18.7459 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N7020 X18.7081 Y39.7506 I0.0901 J0.0909 F45.0
N7030 I0.7205 J0.0000
N7040 X18.7721 Y39.8146 I0.0640 J0.0000
N7050 M05
N7060 G04 P0.3
N7070 G00 Z1.0000
N7080 X8.2761 Y45.1609
N7090 G38.2 z-1.969 F19.685
N7100 G92 Z0.0
N7110 G00 Z0.1969
N7120 G92 Z0.0
N7130 G00 Z0.2000
N7140 M03
N7150 G04 P1.0
N7160 G02 X8.1859 Y45.1980 Z0.1000 I0.0000 J0.1280 F600.0
N7170 X8.1481 Y45.2889 I0.0901 J0.0909 F45.0
N7180 I1.4704 J0.0000
N7190 X8.2121 Y45.3529 I0.0640 J0.0000
N7200 M05
N7210 G04 P0.3
N7220 G00 Z1.0000
N7230 X10.9505 Y56.0761
N7240 G38.2 z-1.969 F19.685
N7250 G92 Z0.0
N7260 G00 Z0.1969
N7270 G92 Z0.0
N7280 G00 Z0.2000
N7290 M03
N7300 G04 P1.0
N7310 G02 X10.8604 Y56.1132 Z0.1000 I0.0000 J0.1280 F600.0
N7320 X10.8225 Y56.2041 I0.0901 J0.0909 F45.0
N7330 I0.7205 J0.0000
N7340 X10.8865 Y56.2681 I0.0640 J0.0000
N7350 M05
N7360 G04 P0.3
N7370 G00 Z1.0000
N7380 X10.6844 Y41.3739
N7390 G38.2 z-1.969 F19.685
N7400 G92 Z0.0
N7410 G00 Z0.1969
N7420 G92 Z0.0
N7430 G00 Z0.2000
N7440 M03
N7450 G04 P1.0
N7460 G02 X10.5943 Y41.4110 Z0.1000 I0.0000 J0.1280 F600.0
N7470 X10.5564 Y41.5019 I0.0901 J0.0909 F45.0
N7480 I1.4705 J0.0000
N7490 X10.6204 Y41.5659 I0.0640 J0.0000
N7500 M05
N7510 G04 P0.3
N7520 G00 Z1.0000
N7530 X10.2672 Y53.5260
N7540 G38.2 z-1.969 F19.685
N7550 G92 Z0.0
N7560 G00 Z0.1969
N7570 G92 Z0.0
N7580 G00 Z0.2000
N7590 M03
N7600 G04 P1.0
N7610 G02 X10.1771 Y53.5632 Z0.1000 I0.0000 J0.1280 F600.0
N7620 X10.1392 Y53.6540 I0.0901 J0.0909 F45.0
N7630 I0.7205 J0.0000
N7640 X10.2032 Y53.7180 I0.0640 J0.0000
N7650 M05
N7660 G04 P0.3
N7670 G00 Z1.0000
N7680 X15.3101 Y39.9236
N7690 G38.2 z-1.969 F19.685
N7700 G92 Z0.0
N7710 G00 Z0.1969
N7720 G92 Z0.0
N7730 G00 Z0.2000
N7740 M03
N7750 G04 P1.0
N7760 G02 X15.2200 Y39.9607 Z0.1000 I0.0000 J0.1280 F600.0
N7770 X15.1821 Y40.0516 I0.0901 J0.0909 F45.0
N7780 I0.7204 J0.0000
N7790 X15.2461 Y40.1156 I0.0640 J0.0000
N7800 M05
N7810 G04 P0.3
N7820 G00 Z1.0000
N7830 X9.5839 Y50.9760
N7840 G38.2 z-1.969 F19.685
N7850 G92 Z0.0
N7860 G00 Z0.1969
N7870 G92 Z0.0
N7880 G00 Z0.2000
N7890 M03
N7900 G04 P1.0
N7910 G02 X9.4938 Y51.0131 Z0.1000 I0.0000 J0.1280 F600.0
N7920 X9.4559 Y51.1040 I0.0901 J0.0909 F45.0
N7930 I0.7205 J0.0000
N7940 X9.5199 Y51.1680 I0.0640 J0.0000
N7950 M05
N7960 G04 P0.3
N7970 G00 Z1.0000
N7980 X9.0458 Y48.4084
N7990 Z0.2000
N8000 M03
N8010 G04 P1.0
N8020 G02 X8.9557 Y48.4455 Z0.1000 I0.0000 J0.1280 F600.0
N8030 X8.9178 Y48.5364 I0.0901 J0.0909 F45.0
N8040 I0.9112 J-0.0000
N8050 X8.9818 Y48.6004 I0.0640 J0.0000
N8060 M05
N8070 G04 P0.3
N8080 G00 Z1.0000
N8090 X21.9999 Y39.6226
N8100 G38.2 z-1.969 F19.685
N8110 G92 Z0.0
N8120 G00 Z0.1969
N8130 G92 Z0.0
N8140 G00 Z0.2000
N8150 M03
N8160 G04 P1.0
N8170 G02 X21.9098 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N8180 X21.8719 Y39.7506 I0.0901 J0.0909 F45.0
N8190 I1.0955 J0.0000
N8200 X21.9359 Y39.8146 I0.0640 J0.0000
N8210 M05
N8220 G04 P0.3
N8230 G00 Z1.0000
N8240 X32.6163 Y39.6226
N8250 G38.2 z-1.969 F19.685
N8260 G92 Z0.0
N8270 G00 Z0.1969
N8280 G92 Z0.0
N8290 G00 Z0.2000
N8300 M03
N8310 G04 P1.0
N8320 G02 X32.5262 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N8330 X32.4883 Y39.7506 I0.0901 J0.0909 F45.0
N8340 I1.0955 J0.0000
N8350 X32.5523 Y39.8146 I0.0640 J0.0000
N8360 M05
N8370 G04 P0.3
N8380 G00 Z1.0000
N8390 X25.5387 Y39.6226
N8400 G38.2 z-1.969 F19.685
N8410 G92 Z0.0
N8420 G00 Z0.1969
N8430 G92 Z0.0
N8440 G00 Z0.2000
N8450 M03
N8460 G04 P1.0
N8470 G02 X25.4486 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N8480 X25.4107 Y39.7506 I0.0901 J0.0909 F45.0
N8490 I1.0955 J0.0000
N8500 X25.4747 Y39.8146 I0.0640 J0.0000
N8510 M05
N8520 G04 P0.3
N8530 G00 Z1.0000
N8540 X36.3058 Y39.6226
N8550 G38.2 z-1.969 F19.685
N8560 G92 Z0.0
N8570 G00 Z0.1969
N8580 G92 Z0.0
N8590 G00 Z0.2000
N8600 M03
N8610 G04 P1.0
N8620 G02 X36.2156 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N8630 X36.1778 Y39.7506 I0.0901 J0.0909 F45.0
N8640 I0.6279 J0.0000
N8650 X36.2418 Y39.8146 I0.0640 J0.0000
N8660 M05
N8670 G04 P0.3
N8680 G00 Z1.0000
N8690 X29.0775 Y39.6226
N8700 G38.2 z-1.969 F19.685
N8710 G92 Z0.0
N8720 G00 Z0.1969
N8730 G92 Z0.0
N8740 G00 Z0.2000
N8750 M03
N8760 G04 P1.0
N8770 G02 X28.9874 Y39.6598 Z0.1000 I0.0000 J0.1280 F600.0
N8780 X28.9495 Y39.7506 I0.0901 J0.0909 F45.0
N8790 I1.0955 J0.0000
N8800 X29.0135 Y39.8146 I0.0640 J0.0000
N8810 M05
N8820 G04 P0.3
N8830 G00 Z1.0000
N8840 X12.6879 Y45.3611
N8850 G38.2 z-1.969 F19.685
N8860 G92 Z0.0
N8870 G00 Z0.1969
N8880 G92 Z0.0
N8890 G00 Z0.2000
N8900 M03
N8910 G04 P1.0
N8920 G02 X12.5912 Y45.3487 Z0.1000 I-0.0635 J0.1111 F600.0
N8930 X12.5133 Y45.4088 I0.0332 J0.1236 F45.0
N8940 X11.8107 Y50.8428 I6.2514 J3.5707
N8950 G01 X13.6224 Y57.6043
N8960 G03 X13.6015 Y57.6405 I-0.0285 J0.0076
N8970 G01 X10.7037 Y58.4169
N8980 G03 X10.6676 Y58.3960 I-0.0076 J-0.0285
N8990 G01 X6.6559 Y43.4242
N9000 G03 X6.6768 Y43.3880 I0.0285 J-0.0076
N9010 G01 X9.5460 Y42.6192
N9020 X8.7772 Y39.7500
N9030 G03 X8.7981 Y39.7138 I0.0285 J-0.0076
N9040 G01 X15.2981 Y37.9721
N9050 X15.3057 Y37.9711
N9060 X40.3057
N9070 G03 X40.3211 Y37.9754 I0.0000 J0.0295
N9080 G01 X44.8211 Y40.7254
N9090 G03 X44.8189 Y40.7771 I-0.0154 J0.0252
N9100 G01 X42.8189 Y41.7771
N9110 G03 X42.7762 Y41.7506 I-0.0132 J-0.0264
N9120 G01 Y41.0485
N9130 X41.3189 Y41.7771
N9140 G03 X41.2762 Y41.7506 I-0.0132 J-0.0264
N9150 G01 Y41.0485
N9160 X39.8189 Y41.7771
N9170 G03 X39.7762 Y41.7506 I-0.0132 J-0.0264
N9180 G01 Y41.0485
N9190 X38.3189 Y41.7771
N9200 G03 X38.3057 Y41.7802 I-0.0132 J-0.0264
N9210 G01 X18.7647
N9220 G02 X12.5133 Y45.4088 I0.0000 J7.1993
N9230 X12.5371 Y45.4961 I0.0556 J0.0317
N9240 M05
N9250 G04 P0.3
N9260 G00 Z1.0000
N9270 X13.5097 Y35.4124
N9280 G38.2 z-1.969 F19.685
N9290 G92 Z0.0
N9300 G00 Z0.1969
N9310 G92 Z0.0
N9320 G00 Z0.2000
N9330 M03
N9340 G04 P1.0
N9350 G02 X13.4196 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N9360 X13.3817 Y35.5404 I0.0901 J0.0909 F45.0
N9370 I0.6004 J0.0000
N9380 X13.4457 Y35.6044 I0.0640 J0.0000
N9390 M05
N9400 G04 P0.3
N9410 G00 Z1.0000
N9420 X3.6997 Y40.9507
N9430 G38.2 z-1.969 F19.685
N9440 G92 Z0.0
N9450 G00 Z0.1969
N9460 G92 Z0.0
N9470 G00 Z0.2000
N9480 M03
N9490 G04 P1.0
N9500 G02 X3.6096 Y40.9878 Z0.1000 I0.0000 J0.1280 F600.0
N9510 X3.5717 Y41.0787 I0.0901 J0.0909 F45.0
N9520 I0.6005 J0.0000
N9530 X3.6357 Y41.1427 I0.0640 J0.0000
N9540 M05
N9550 G04 P0.3
N9560 G00 Z1.0000
N9570 X5.6242 Y51.8658
N9580 G38.2 z-1.969 F19.685
N9590 G92 Z0.0
N9600 G00 Z0.1969
N9610 G92 Z0.0
N9620 G00 Z0.2000
N9630 M03
N9640 G04 P1.0
N9650 G02 X5.5340 Y51.9029 Z0.1000 I0.0000 J0.1280 F600.0
N9660 X5.4962 Y51.9938 I0.0901 J0.0909 F45.0
N9670 I0.6004 J0.0000
N9680 X5.5602 Y52.0578 I0.0640 J0.0000
N9690 M05
N9700 G04 P0.3
N9710 G00 Z1.0000
N9720 X6.1081 Y37.1637
N9730 G38.2 z-1.969 F19.685
N9740 G92 Z0.0
N9750 G00 Z0.1969
N9760 G92 Z0.0
N9770 G00 Z0.2000
N9780 M03
N9790 G04 P1.0
N9800 G02 X6.0180 Y37.2008 Z0.1000 I0.0000 J0.1280 F600.0
N9810 X5.9801 Y37.2917 I0.0901 J0.0909 F45.0
N9820 I0.6005 J0.0000
N9830 X6.0441 Y37.3557 I0.0640 J0.0000
N9840 M05
N9850 G04 P0.3
N9860 G00 Z1.0000
N9870 X4.9409 Y49.3158
N9880 G38.2 z-1.969 F19.685
N9890 G92 Z0.0
N9900 G00 Z0.1969
N9910 G92 Z0.0
N9920 G00 Z0.2000
N9930 M03
N9940 G04 P1.0
N9950 G02 X4.8507 Y49.3529 Z0.1000 I0.0000 J0.1280 F600.0
N9960 X4.8129 Y49.4438 I0.0901 J0.0909 F45.0
N9970 I0.6005 J0.0000
N9980 X4.8769 Y49.5078 I0.0640 J0.0000
N9990 M05
N10000 G04 P0.3
N10010 G00 Z1.0000
N10020 X9.9837 Y35.7133
N10030 G38.2 z-1.969 F19.685
N10040 G92 Z0.0
N10050 G00 Z0.1969
N10060 G92 Z0.0
N10070 G00 Z0.2000
N10080 M03
N10090 G04 P1.0
N10100 G02 X9.8936 Y35.7505 Z0.1000 I0.0000 J0.1280 F600.0
N10110 X9.8557 Y35.8413 I0.0901 J0.0909 F45.0
N10120 I0.6004 J0.0000
N10130 X9.9197 Y35.9053 I0.0640 J0.0000
N10140 M05
N10150 G04 P0.3
N10160 G00 Z1.0000
N10170 X4.2576 Y46.7657
N10180 G38.2 z-1.969 F19.685
N10190 G92 Z0.0
N10200 G00 Z0.1969
N10210 G92 Z0.0
N10220 G00 Z0.2000
N10230 M03
N10240 G04 P1.0
N10250 G02 X4.1675 Y46.8028 Z0.1000 I0.0000 J0.1280 F600.0
N10260 X4.1296 Y46.8937 I0.0901 J0.0909 F45.0
N10270 I0.6005 J0.0000
N10280 X4.1936 Y46.9577 I0.0640 J0.0000
N10290 M05
N10300 G04 P0.3
N10310 G00 Z1.0000
N10320 X3.9102 Y44.1982
N10330 Z0.2000
N10340 M03
N10350 G04 P1.0
N10360 G02 X3.8201 Y44.2353 Z0.1000 I0.0000 J0.1280 F600.0
N10370 X3.7822 Y44.3262 I0.0901 J0.0909 F45.0
N10380 I0.6005 J-0.0000
N10390 X3.8462 Y44.3902 I0.0640 J0.0000
N10400 M05
N10410 G04 P0.3
N10420 G00 Z1.0000
N10430 X17.0485 Y35.4124
N10440 G38.2 z-1.969 F19.685
N10450 G92 Z0.0
N10460 G00 Z0.1969
N10470 G92 Z0.0
N10480 G00 Z0.2000
N10490 M03
N10500 G04 P1.0
N10510 G02 X16.9584 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N10520 X16.9205 Y35.5404 I0.0901 J0.0909 F45.0
N10530 I0.6004 J0.0000
N10540 X16.9845 Y35.6044 I0.0640 J0.0000
N10550 M05
N10560 G04 P0.3
N10570 G00 Z1.0000
N10580 X27.6650 Y35.4124
N10590 G38.2 z-1.969 F19.685
N10600 G92 Z0.0
N10610 G00 Z0.1969
N10620 G92 Z0.0
N10630 G00 Z0.2000
N10640 M03
N10650 G04 P1.0
N10660 G02 X27.5749 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N10670 X27.5370 Y35.5404 I0.0901 J0.0909 F45.0
N10680 I0.6005 J0.0000
N10690 X27.6010 Y35.6044 I0.0640 J0.0000
N10700 M05
N10710 G04 P0.3
N10720 G00 Z1.0000
N10730 X20.5874 Y35.4124
N10740 G38.2 z-1.969 F19.685
N10750 G92 Z0.0
N10760 G00 Z0.1969
N10770 G92 Z0.0
N10780 G00 Z0.2000
N10790 M03
N10800 G04 P1.0
N10810 G02 X20.4972 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N10820 X20.4594 Y35.5404 I0.0901 J0.0909 F45.0
N10830 I0.6005 J0.0000
N10840 X20.5234 Y35.6044 I0.0640 J0.0000
N10850 M05
N10860 G04 P0.3
N10870 G00 Z1.0000
N10880 X30.8594 Y35.4124
N10890 G38.2 z-1.969 F19.685
N10900 G92 Z0.0
N10910 G00 Z0.1969
N10920 G92 Z0.0
N10930 G00 Z0.2000
N10940 M03
N10950 G04 P1.0
N10960 G02 X30.7693 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N10970 X30.7314 Y35.5404 I0.0901 J0.0909 F45.0
N10980 I0.6280 J0.0000
N10990 X30.7954 Y35.6044 I0.0640 J0.0000
N11000 M05
N11010 G04 P0.3
N11020 G00 Z1.0000
N11030 X24.1262 Y35.4124
N11040 G38.2 z-1.969 F19.685
N11050 G92 Z0.0
N11060 G00 Z0.1969
N11070 G92 Z0.0
N11080 G00 Z0.2000
N11090 M03
N11100 G04 P1.0
N11110 G02 X24.0360 Y35.4495 Z0.1000 I0.0000 J0.1280 F600.0
N11120 X23.9982 Y35.5404 I0.0901 J0.0909 F45.0
N11130 I0.6005 J-0.0000
N11140 X24.0622 Y35.6044 I0.0640 J0.0000
N11150 M05
N11160 G04 P0.3
N11170 G00 Z1.0000
N11180 X9.7314 Y33.6328
N11190 G38.2 z-1.969 F19.685
N11200 G92 Z0.0
N11210 G00 Z0.1969
N11220 G92 Z0.0
N11230 G00 Z0.2000
N11240 M03
N11250 G04 P1.0
N11260 G02 X9.7685 Y33.7230 Z0.1000 I0.1280 J0.0000 F600.0
N11270 X9.8594 Y33.7608 I0.0909 J-0.0901 F45.0
N11280 G01 X34.8594
N11290 G03 X34.8748 Y33.7652 I0.0000 J0.0295
N11300 G01 X39.3748 Y36.5152
N11310 G03 X39.3726 Y36.5668 I-0.0154 J0.0252
N11320 G01 X37.3726 Y37.5668
N11330 G03 X37.3298 Y37.5404 I-0.0132 J-0.0264
N11340 G01 Y36.8382
N11350 X35.8726 Y37.5668
N11360 G03 X35.8298 Y37.5404 I-0.0132 J-0.0264
N11370 G01 Y36.8382
N11380 X34.3726 Y37.5668
N11390 G03 X34.3298 Y37.5404 I-0.0132 J-0.0264
N11400 G01 Y36.8382
N11410 X32.8726 Y37.5668
N11420 G03 X32.8594 Y37.5699 I-0.0132 J-0.0264
N11430 G01 X13.3183
N11440 G02 X6.3643 Y46.6325 I0.0000 J7.1993
N11450 G01 X8.9525 Y56.2918
N11460 G03 X8.9316 Y56.3280 I-0.0285 J0.0076
N11470 G01 X6.0339 Y57.1044
N11480 G03 X5.9977 Y57.0836 I-0.0076 J-0.0285
N11490 G01 X0.4331 Y36.3161
N11500 G03 X0.4539 Y36.2800 I0.0285 J-0.0076
N11510 G01 X9.8517 Y33.7618
N11520 G02 X9.8970 Y33.6834 I-0.0166 J-0.0618
N11530 M05
N11540 G04 P0.3
N11550 G00 Z1.0000
N11560 X7.0943 Y20.8717
N11570 G38.2 z-1.969 F19.685
N11580 G92 Z0.0
N11590 G00 Z0.1969
N11600 G92 Z0.0
N11610 G00 Z0.2000
N11620 M03
N11630 G04 P1.0
N11640 G02 X7.1915 Y20.8789 Z0.1000 I0.0574 J-0.1144 F600.0
N11650 X7.2661 Y20.8146 I-0.0398 J-0.1216 F45.0
N11660 G01 X7.3092 Y20.7288
N11670 X7.3464 Y20.5413
N11680 X7.3354 Y20.3406
N11690 G03 X7.3548 Y20.3112 I0.0295 J-0.0016
N11700 G01 X7.5619 Y20.2359
N11710 G03 X7.5998 Y20.2535 I0.0101 J0.0278
N11720 G01 X8.6258 Y23.0726
N11730 G03 X8.6082 Y23.1105 I-0.0278 J0.0101
N11740 G01 X6.9637 Y23.7090
N11750 G03 X6.9258 Y23.6914 I-0.0101 J-0.0278
N11760 G01 X5.8998 Y20.8723
N11770 G03 X5.9174 Y20.8344 I0.0278 J-0.0101
N11780 G01 X6.1436 Y20.7521
N11790 G03 X6.1774 Y20.7621 I0.0101 J0.0278
N11800 G01 X6.2979 Y20.9229
N11810 X6.4470 Y21.0426
N11820 X6.6150 Y21.1152
N11830 X6.7894 Y21.1358
N11840 X6.9573 Y21.1033
N11850 X7.1068 Y21.0203
N11860 X7.2271 Y20.8924
N11870 X7.2661 Y20.8146
N11880 G02 X7.2376 Y20.7287 I-0.0572 J-0.0287
N11890 M05
N11900 G04 P0.3
N11910 G00 Z1.0000
N11920 X17.4581 Y5.9612
N11930 G38.2 z-1.969 F19.685
N11940 G92 Z0.0
N11950 G00 Z0.1969
N11960 G92 Z0.0
N11970 G00 Z0.2000
N11980 M03
N11990 G04 P1.0
N12000 G02 X17.3680 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N12010 X17.3301 Y6.0892 I0.0901 J0.0909 F45.0
N12020 I0.7205 J0.0000
N12030 X17.3941 Y6.1532 I0.0640 J0.0000
N12040 M05
N12050 G04 P0.3
N12060 G00 Z1.0000
N12070 X6.8981 Y11.4995
N12080 G38.2 z-1.969 F19.685
N12090 G92 Z0.0
N12100 G00 Z0.1969
N12110 G92 Z0.0
N12120 G00 Z0.2000
N12130 M03
N12140 G04 P1.0
N12150 G02 X6.8080 Y11.5366 Z0.1000 I0.0000 J0.1280 F600.0
N12160 X6.7701 Y11.6275 I0.0901 J0.0909 F45.0
N12170 I1.4704 J0.0000
N12180 X6.8341 Y11.6915 I0.0640 J0.0000
N12190 M05
N12200 G04 P0.3
N12210 G00 Z1.0000
N12220 X9.5726 Y22.4147
N12230 G38.2 z-1.969 F19.685
N12240 G92 Z0.0
N12250 G00 Z0.1969
N12260 G92 Z0.0
N12270 G00 Z0.2000
N12280 M03
N12290 G04 P1.0
N12300 G02 X9.4824 Y22.4518 Z0.1000 I0.0000 J0.1280 F600.0
N12310 X9.4446 Y22.5427 I0.0901 J0.0909 F45.0
N12320 I0.7205 J0.0000
N12330 X9.5086 Y22.6067 I0.0640 J0.0000
N12340 M05
N12350 G04 P0.3
N12360 G00 Z1.0000
N12370 X9.3065 Y7.7125
N12380 G38.2 z-1.969 F19.685
N12390 G92 Z0.0
N12400 G00 Z0.1969
N12410 G92 Z0.0
N12420 G00 Z0.2000
N12430 M03
N12440 G04 P1.0
N12450 G02 X9.2163 Y7.7496 Z0.1000 I0.0000 J0.1280 F600.0
N12460 X9.1785 Y7.8405 I0.0901 J0.0909 F45.0
N12470 I1.4705 J0.0000
N12480 X9.2425 Y7.9045 I0.0640 J0.0000
N12490 M05
N12500 G04 P0.3
N12510 G00 Z1.0000
N12520 X8.8893 Y19.8646
N12530 G38.2 z-1.969 F19.685
N12540 G92 Z0.0
N12550 G00 Z0.1969
N12560 G92 Z0.0
N12570 G00 Z0.2000
N12580 M03
N12590 G04 P1.0
N12600 G02 X8.7991 Y19.9017 Z0.1000 I0.0000 J0.1280 F600.0
N12610 X8.7613 Y19.9926 I0.0901 J0.0909 F45.0
N12620 I0.7205 J0.0000
N12630 X8.8253 Y20.0566 I0.0640 J0.0000
N12640 M05
N12650 G04 P0.3
N12660 G00 Z1.0000
N12670 X13.9321 Y6.2622
N12680 G38.2 z-1.969 F19.685
N12690 G92 Z0.0
N12700 G00 Z0.1969
N12710 G92 Z0.0
N12720 G00 Z0.2000
N12730 M03
N12740 G04 P1.0
N12750 G02 X13.8420 Y6.2993 Z0.1000 I0.0000 J0.1280 F600.0
N12760 X13.8041 Y6.3902 I0.0901 J0.0909 F45.0
N12770 I0.7204 J-0.0000
N12780 X13.8681 Y6.4542 I0.0640 J0.0000
N12790 M05
N12800 G04 P0.3
N12810 G00 Z1.0000
N12820 X8.2060 Y17.3146
N12830 G38.2 z-1.969 F19.685
N12840 G92 Z0.0
N12850 G00 Z0.1969
N12860 G92 Z0.0
N12870 G00 Z0.2000
N12880 M03
N12890 G04 P1.0
N12900 G02 X8.1159 Y17.3517 Z0.1000 I0.0000 J0.1280 F600.0
N12910 X8.0780 Y17.4426 I0.0901 J0.0909 F45.0
N12920 I0.7205 J0.0000
N12930 X8.1420 Y17.5066 I0.0640 J0.0000
N12940 M05
N12950 G04 P0.3
N12960 G00 Z1.0000
N12970 X7.6678 Y14.7470
N12980 Z0.2000
N12990 M03
N13000 G04 P1.0
N13010 G02 X7.5777 Y14.7841 Z0.1000 I0.0000 J0.1280 F600.0
N13020 X7.5398 Y14.8750 I0.0901 J0.0909 F45.0
N13030 I0.9112 J-0.0000
N13040 X7.6038 Y14.9390 I0.0640 J0.0000
N13050 M05
N13060 G04 P0.3
N13070 G00 Z1.0000
N13080 X20.6219 Y5.9612
N13090 G38.2 z-1.969 F19.685
N13100 G92 Z0.0
N13110 G00 Z0.1969
N13120 G92 Z0.0
N13130 G00 Z0.2000
N13140 M03
N13150 G04 P1.0
N13160 G02 X20.5318 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N13170 X20.4939 Y6.0892 I0.0901 J0.0909 F45.0
N13180 I1.0955 J0.0000
N13190 X20.5579 Y6.1532 I0.0640 J0.0000
N13200 M05
N13210 G04 P0.3
N13220 G00 Z1.0000
N13230 X31.2384 Y5.9612
N13240 G38.2 z-1.969 F19.685
N13250 G92 Z0.0
N13260 G00 Z0.1969
N13270 G92 Z0.0
N13280 G00 Z0.2000
N13290 M03
N13300 G04 P1.0
N13310 G02 X31.1482 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N13320 X31.1104 Y6.0892 I0.0901 J0.0909 F45.0
N13330 I1.0955 J-0.0000
N13340 X31.1744 Y6.1532 I0.0640 J0.0000
N13350 M05
N13360 G04 P0.3
N13370 G00 Z1.0000
N13380 X24.1608 Y5.9612
N13390 G38.2 z-1.969 F19.685
N13400 G92 Z0.0
N13410 G00 Z0.1969
N13420 G92 Z0.0
N13430 G00 Z0.2000
N13440 M03
N13450 G04 P1.0
N13460 G02 X24.0706 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N13470 X24.0328 Y6.0892 I0.0901 J0.0909 F45.0
N13480 I1.0955 J0.0000
N13490 X24.0968 Y6.1532 I0.0640 J0.0000
N13500 M05
N13510 G04 P0.3
N13520 G00 Z1.0000
N13530 X34.9278 Y5.9612
N13540 G38.2 z-1.969 F19.685
N13550 G92 Z0.0
N13560 G00 Z0.1969
N13570 G92 Z0.0
N13580 G00 Z0.2000
N13590 M03
N13600 G04 P1.0
N13610 G02 X34.8377 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N13620 X34.7998 Y6.0892 I0.0901 J0.0909 F45.0
N13630 I0.6279 J0.0000
N13640 X34.8638 Y6.1532 I0.0640 J0.0000
N13650 M05
N13660 G04 P0.3
N13670 G00 Z1.0000
N13680 X27.6996 Y5.9612
N13690 G38.2 z-1.969 F19.685
N13700 G92 Z0.0
N13710 G00 Z0.1969
N13720 G92 Z0.0
N13730 G00 Z0.2000
N13740 M03
N13750 G04 P1.0
N13760 G02 X27.6094 Y5.9983 Z0.1000 I0.0000 J0.1280 F600.0
N13770 X27.5716 Y6.0892 I0.0901 J0.0909 F45.0
N13780 I1.0955 J0.0000
N13790 X27.6356 Y6.1532 I0.0640 J0.0000
N13800 M05
N13810 G04 P0.3
N13820 G00 Z1.0000
N13830 X11.3099 Y11.6997
N13840 G38.2 z-1.969 F19.685
N13850 G92 Z0.0
N13860 G00 Z0.1969
N13870 G92 Z0.0
N13880 G00 Z0.2000
N13890 M03
N13900 G04 P1.0
N13910 G02 X11.2133 Y11.6873 Z0.1000 I-0.0635 J0.1111 F600.0
N13920 X11.1353 Y11.7474 I0.0332 J0.1236 F45.0
N13930 X10.4327 Y17.1814 I6.2514 J3.5707
N13940 G01 X12.2445 Y23.9429
N13950 G03 X12.2236 Y23.9791 I-0.0285 J0.0076
N13960 G01 X9.3258 Y24.7555
N13970 G03 X9.2896 Y24.7346 I-0.0076 J-0.0285
N13980 G01 X5.2779 Y9.7628
N13990 G03 X5.2988 Y9.7266 I0.0285 J-0.0076
N14000 G01 X8.1680 Y8.9578
N14010 X7.3992 Y6.0885
N14020 G03 X7.4201 Y6.0524 I0.0285 J-0.0076
N14030 G01 X13.9201 Y4.3107
N14040 X13.9278 Y4.3097
N14050 X38.9278
N14060 G03 X38.9432 Y4.3140 I0.0000 J0.0295
N14070 G01 X43.4432 Y7.0640
N14080 G03 X43.4410 Y7.1157 I-0.0154 J0.0252
N14090 G01 X41.4410 Y8.1157
N14100 G03 X41.3982 Y8.0892 I-0.0132 J-0.0264
N14110 G01 Y7.3870
N14120 X39.9410 Y8.1157
N14130 G03 X39.8982 Y8.0892 I-0.0132 J-0.0264
N14140 G01 Y7.3870
N14150 X38.4410 Y8.1157
N14160 G03 X38.3982 Y8.0892 I-0.0132 J-0.0264
N14170 G01 Y7.3870
N14180 X36.9410 Y8.1157
N14190 G03 X36.9278 Y8.1188 I-0.0132 J-0.0264
N14200 G01 X17.3867
N14210 G02 X11.1353 Y11.7474 I0.0000 J7.1993
N14220 X11.1591 Y11.8347 I0.0556 J0.0317
N14230 M05
N14240 G04 P0.3
N14250 G00 Z1.0000
N14260 X26.3548 Y27.4357
N14270 G38.2 z-1.969 F19.685
N14280 G92 Z0.0
N14290 G00 Z0.1969
N14300 G92 Z0.0
N14310 G00 Z0.2000
N14320 M03
N14330 G04 P1.0
N14340 G02 X26.4450 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N14350 X26.4828 Y27.3077 I-0.0901 J-0.0909 F45.0
N14360 I-0.7204 J0.0000
N14370 X26.4188 Y27.2437 I-0.0640 J0.0000
N14380 M05
N14390 G04 P0.3
N14400 G00 Z1.0000
N14410 X36.9148 Y21.8974
N14420 G38.2 z-1.969 F19.685
N14430 G92 Z0.0
N14440 G00 Z0.1969
N14450 G92 Z0.0
N14460 G00 Z0.2000
N14470 M03
N14480 G04 P1.0
N14490 G02 X37.0050 Y21.8603 Z0.1000 I0.0000 J-0.1280 F600.0
N14500 X37.0428 Y21.7694 I-0.0901 J-0.0909 F45.0
N14510 I-1.4704 J-0.0000
N14520 X36.9788 Y21.7054 I-0.0640 J0.0000
N14530 M05
N14540 G04 P0.3
N14550 G00 Z1.0000
N14560 X34.2404 Y10.9822
N14570 G38.2 z-1.969 F19.685
N14580 G92 Z0.0
N14590 G00 Z0.1969
N14600 G92 Z0.0
N14610 G00 Z0.2000
N14620 M03
N14630 G04 P1.0
N14640 G02 X34.3305 Y10.9451 Z0.1000 I0.0000 J-0.1280 F600.0
N14650 X34.3684 Y10.8542 I-0.0901 J-0.0909 F45.0
N14660 I-0.7205 J0.0000
N14670 X34.3044 Y10.7902 I-0.0640 J0.0000
N14680 M05
N14690 G04 P0.3
N14700 G00 Z1.0000
N14710 X34.5065 Y25.6844
N14720 G38.2 z-1.969 F19.685
N14730 G92 Z0.0
N14740 G00 Z0.1969
N14750 G92 Z0.0
N14760 G00 Z0.2000
N14770 M03
N14780 G04 P1.0
N14790 G02 X34.5966 Y25.6473 Z0.1000 I0.0000 J-0.1280 F600.0
N14800 X34.6345 Y25.5564 I-0.0901 J-0.0909 F45.0
N14810 I-1.4705 J0.0000
N14820 X34.5705 Y25.4924 I-0.0640 J0.0000
N14830 M05
N14840 G04 P0.3
N14850 G00 Z1.0000
N14860 X34.9237 Y13.5323
N14870 G38.2 z-1.969 F19.685
N14880 G92 Z0.0
N14890 G00 Z0.1969
N14900 G92 Z0.0
N14910 G00 Z0.2000
N14920 M03
N14930 G04 P1.0
N14940 G02 X35.0138 Y13.4952 Z0.1000 I0.0000 J-0.1280 F600.0
N14950 X35.0517 Y13.4043 I-0.0901 J-0.0909 F45.0
N14960 I-0.7205 J0.0000
N14970 X34.9877 Y13.3403 I-0.0640 J0.0000
N14980 M05
N14990 G04 P0.3
N15000 G00 Z1.0000
N15010 X29.8808 Y27.1347
N15020 G38.2 z-1.969 F19.685
N15030 G92 Z0.0
N15040 G00 Z0.1969
N15050 G92 Z0.0
N15060 G00 Z0.2000
N15070 M03
N15080 G04 P1.0
N15090 G02 X29.9710 Y27.0976 Z0.1000 I0.0000 J-0.1280 F600.0
N15100 X30.0088 Y27.0067 I-0.0901 J-0.0909 F45.0
N15110 I-0.7205 J-0.0000
N15120 X29.9448 Y26.9427 I-0.0640 J0.0000
N15130 M05
N15140 G04 P0.3
N15150 G00 Z1.0000
N15160 X35.6070 Y16.0824
N15170 G38.2 z-1.969 F19.685
N15180 G92 Z0.0
N15190 G00 Z0.1969
N15200 G92 Z0.0
N15210 G00 Z0.2000
N15220 M03
N15230 G04 P1.0
N15240 G02 X35.6971 Y16.0452 Z0.1000 I0.0000 J-0.1280 F600.0
N15250 X35.7350 Y15.9544 I-0.0901 J-0.0909 F45.0
N15260 I-0.7205 J0.0000
N15270 X35.6710 Y15.8904 I-0.0640 J0.0000
N15280 M05
N15290 G04 P0.3
N15300 G00 Z1.0000
N15310 X36.1451 Y18.6499
N15320 Z0.2000
N15330 M03
N15340 G04 P1.0
N15350 G02 X36.2353 Y18.6128 Z0.1000 I0.0000 J-0.1280 F600.0
N15360 X36.2731 Y18.5219 I-0.0901 J-0.0909 F45.0
N15370 I-0.9112 J0.0000
N15380 X36.2091 Y18.4579 I-0.0640 J0.0000
N15390 M05
N15400 G04 P0.3
N15410 G00 Z1.0000
N15420 X23.1910 Y27.4357
N15430 G38.2 z-1.969 F19.685
N15440 G92 Z0.0
N15450 G00 Z0.1969
N15460 G92 Z0.0
N15470 G00 Z0.2000
N15480 M03
N15490 G04 P1.0
N15500 G02 X23.2811 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N15510 X23.3190 Y27.3077 I-0.0901 J-0.0909 F45.0
N15520 I-1.0955 J0.0000
N15530 X23.2550 Y27.2437 I-0.0640 J0.0000
N15540 M05
N15550 G04 P0.3
N15560 G00 Z1.0000
N15570 X12.5746 Y27.4357
N15580 G38.2 z-1.969 F19.685
N15590 G92 Z0.0
N15600 G00 Z0.1969
N15610 G92 Z0.0
N15620 G00 Z0.2000
N15630 M03
N15640 G04 P1.0
N15650 G02 X12.6647 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N15660 X12.7026 Y27.3077 I-0.0901 J-0.0909 F45.0
N15670 I-1.0955 J0.0000
N15680 X12.6386 Y27.2437 I-0.0640 J0.0000
N15690 M05
N15700 G04 P0.3
N15710 G00 Z1.0000
N15720 X19.6522 Y27.4357
N15730 G38.2 z-1.969 F19.685
N15740 G92 Z0.0
N15750 G00 Z0.1969
N15760 G92 Z0.0
N15770 G00 Z0.2000
N15780 M03
N15790 G04 P1.0
N15800 G02 X19.7423 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N15810 X19.7802 Y27.3077 I-0.0901 J-0.0909 F45.0
N15820 I-1.0954 J0.0000
N15830 X19.7162 Y27.2437 I-0.0640 J0.0000
N15840 M05
N15850 G04 P0.3
N15860 G00 Z1.0000
N15870 X8.8851 Y27.4357
N15880 G38.2 z-1.969 F19.685
N15890 G92 Z0.0
N15900 G00 Z0.1969
N15910 G92 Z0.0
N15920 G00 Z0.2000
N15930 M03
N15940 G04 P1.0
N15950 G02 X8.9753 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N15960 X9.0131 Y27.3077 I-0.0901 J-0.0909 F45.0
N15970 I-0.6279 J0.0000
N15980 X8.9491 Y27.2437 I-0.0640 J0.0000
N15990 M05
N16000 G04 P0.3
N16010 G00 Z1.0000
N16020 X16.1134 Y27.4357
N16030 G38.2 z-1.969 F19.685
N16040 G92 Z0.0
N16050 G00 Z0.1969
N16060 G92 Z0.0
N16070 G00 Z0.2000
N16080 M03
N16090 G04 P1.0
N16100 G02 X16.2035 Y27.3986 Z0.1000 I0.0000 J-0.1280 F600.0
N16110 X16.2414 Y27.3077 I-0.0901 J-0.0909 F45.0
N16120 I-1.0955 J0.0000
N16130 X16.1774 Y27.2437 I-0.0640 J0.0000
N16140 M05
N16150 G04 P0.3
N16160 G00 Z1.0000
N16170 X32.5030 Y21.6972
N16180 G38.2 z-1.969 F19.685
N16190 G92 Z0.0
N16200 G00 Z0.1969
N16210 G92 Z0.0
N16220 G00 Z0.2000
N16230 M03
N16240 G04 P1.0
N16250 G02 X32.5997 Y21.7097 Z0.1000 I0.0635 J-0.1111 F600.0
N16260 X32.6776 Y21.6495 I-0.0332 J-0.1236 F45.0
N16270 X33.3802 Y16.2155 I-6.2514 J-3.5707
N16280 G01 X31.5685 Y9.4540
N16290 G03 X31.5894 Y9.4178 I0.0285 J-0.0076
N16300 G01 X34.4872 Y8.6414
N16310 G03 X34.5234 Y8.6623 I0.0076 J0.0285
N16320 G01 X38.5350 Y23.6341
N16330 G03 X38.5142 Y23.6703 I-0.0285 J0.0076
N16340 G01 X35.6449 Y24.4391
N16350 X36.4137 Y27.3084
N16360 G03 X36.3928 Y27.3446 I-0.0285 J0.0076
N16370 G01 X29.8928 Y29.0862
N16380 X29.8852 Y29.0872
N16390 X4.8852
N16400 G03 X4.8698 Y29.0829 I0.0000 J-0.0295
N16410 G01 X0.3698 Y26.3329
N16420 G03 X0.3720 Y26.2813 I0.0154 J-0.0252
N16430 G01 X2.3720 Y25.2813
N16440 G03 X2.4147 Y25.3077 I0.0132 J0.0264
N16450 G01 Y26.0099
N16460 X3.8720 Y25.2813
N16470 G03 X3.9147 Y25.3077 I0.0132 J0.0264
N16480 G01 Y26.0099
N16490 X5.3720 Y25.2813
N16500 G03 X5.4147 Y25.3077 I0.0132 J0.0264
N16510 G01 Y26.0099
N16520 X6.8720 Y25.2813
N16530 G03 X6.8852 Y25.2781 I0.0132 J0.0264
N16540 G01 X26.4262
N16550 G02 X32.6776 Y21.6495 I0.0000 J-7.1993
N16560 X32.6538 Y21.5622 I-0.0556 J-0.0317
N16570 M05
N16580 G04 P0.3
N16590 G00 Z1.0000
N16600 X31.8666 Y31.5695
N16610 G38.2 z-1.969 F19.685
N16620 G92 Z0.0
N16630 G00 Z0.1969
N16640 G92 Z0.0
N16650 G00 Z0.2000
N16660 M03
N16670 G04 P1.0
N16680 G02 X31.9568 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N16690 X31.9946 Y31.4415 I-0.0901 J-0.0909 F45.0
N16700 I-0.7204 J0.0000
N16710 X31.9306 Y31.3775 I-0.0640 J0.0000
N16720 M05
N16730 G04 P0.3
N16740 G00 Z1.0000
N16750 X42.4266 Y26.0313
N16760 G38.2 z-1.969 F19.685
N16770 G92 Z0.0
N16780 G00 Z0.1969
N16790 G92 Z0.0
N16800 G00 Z0.2000
N16810 M03
N16820 G04 P1.0
N16830 G02 X42.5168 Y25.9941 Z0.1000 I0.0000 J-0.1280 F600.0
N16840 X42.5546 Y25.9033 I-0.0901 J-0.0909 F45.0
N16850 I-1.4704 J-0.0000
N16860 X42.4906 Y25.8393 I-0.0640 J0.0000
N16870 M05
N16880 G04 P0.3
N16890 G00 Z1.0000
N16900 X39.7522 Y15.1161
N16910 G38.2 z-1.969 F19.685
N16920 G92 Z0.0
N16930 G00 Z0.1969
N16940 G92 Z0.0
N16950 G00 Z0.2000
N16960 M03
N16970 G04 P1.0
N16980 G02 X39.8423 Y15.0790 Z0.1000 I0.0000 J-0.1280 F600.0
N16990 X39.8802 Y14.9881 I-0.0901 J-0.0909 F45.0
N17000 I-0.7205 J0.0000
N17010 X39.8162 Y14.9241 I-0.0640 J0.0000
N17020 M05
N17030 G04 P0.3
N17040 G00 Z1.0000
N17050 X40.0183 Y29.8183
N17060 G38.2 z-1.969 F19.685
N17070 G92 Z0.0
N17080 G00 Z0.1969
N17090 G92 Z0.0
N17100 G00 Z0.2000
N17110 M03
N17120 G04 P1.0
N17130 G02 X40.1084 Y29.7811 Z0.1000 I0.0000 J-0.1280 F600.0
N17140 X40.1463 Y29.6903 I-0.0901 J-0.0909 F45.0
N17150 I-1.4705 J0.0000
N17160 X40.0823 Y29.6263 I-0.0640 J0.0000
N17170 M05
N17180 G04 P0.3
N17190 G00 Z1.0000
N17200 X40.4355 Y17.6661
N17210 G38.2 z-1.969 F19.685
N17220 G92 Z0.0
N17230 G00 Z0.1969
N17240 G92 Z0.0
N17250 G00 Z0.2000
N17260 M03
N17270 G04 P1.0
N17280 G02 X40.5256 Y17.6290 Z0.1000 I0.0000 J-0.1280 F600.0
N17290 X40.5635 Y17.5381 I-0.0901 J-0.0909 F45.0
N17300 I-0.7205 J0.0000
N17310 X40.4995 Y17.4741 I-0.0640 J0.0000
N17320 M05
N17330 G04 P0.3
N17340 G00 Z1.0000
N17350 X35.3926 Y31.2686
N17360 G38.2 z-1.969 F19.685
N17370 G92 Z0.0
N17380 G00 Z0.1969
N17390 G92 Z0.0
N17400 G00 Z0.2000
N17410 M03
N17420 G04 P1.0
N17430 G02 X35.4828 Y31.2315 Z0.1000 I0.0000 J-0.1280 F600.0
N17440 X35.5206 Y31.1406 I-0.0901 J-0.0909 F45.0
N17450 I-0.7205 J-0.0000
N17460 X35.4566 Y31.0766 I-0.0640 J0.0000
N17470 M05
N17480 G04 P0.3
N17490 G00 Z1.0000
N17500 X41.1188 Y20.2162
N17510 G38.2 z-1.969 F19.685
N17520 G92 Z0.0
N17530 G00 Z0.1969
N17540 G92 Z0.0
N17550 G00 Z0.2000
N17560 M03
N17570 G04 P1.0
N17580 G02 X41.2089 Y20.1791 Z0.1000 I0.0000 J-0.1280 F600.0
N17590 X41.2468 Y20.0882 I-0.0901 J-0.0909 F45.0
N17600 I-0.7205 J0.0000
N17610 X41.1828 Y20.0242 I-0.0640 J0.0000
N17620 M05
N17630 G04 P0.3
N17640 G00 Z1.0000
N17650 X41.6569 Y22.7838
N17660 Z0.2000
N17670 M03
N17680 G04 P1.0
N17690 G02 X41.7471 Y22.7467 Z0.1000 I0.0000 J-0.1280 F600.0
N17700 X41.7849 Y22.6558 I-0.0901 J-0.0909 F45.0
N17710 I-0.9112 J0.0000
N17720 X41.7209 Y22.5918 I-0.0640 J0.0000
N17730 M05
N17740 G04 P0.3
N17750 G00 Z1.0000
N17760 X28.7028 Y31.5695
N17770 G38.2 z-1.969 F19.685
N17780 G92 Z0.0
N17790 G00 Z0.1969
N17800 G92 Z0.0
N17810 G00 Z0.2000
N17820 M03
N17830 G04 P1.0
N17840 G02 X28.7930 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N17850 X28.8308 Y31.4415 I-0.0901 J-0.0909 F45.0
N17860 I-1.0955 J0.0000
N17870 X28.7668 Y31.3775 I-0.0640 J0.0000
N17880 M05
N17890 G04 P0.3
N17900 G00 Z1.0000
N17910 X18.0864 Y31.5695
N17920 G38.2 z-1.969 F19.685
N17930 G92 Z0.0
N17940 G00 Z0.1969
N17950 G92 Z0.0
N17960 G00 Z0.2000
N17970 M03
N17980 G04 P1.0
N17990 G02 X18.1765 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N18000 X18.2144 Y31.4415 I-0.0901 J-0.0909 F45.0
N18010 I-1.0955 J0.0000
N18020 X18.1504 Y31.3775 I-0.0640 J0.0000
N18030 M05
N18040 G04 P0.3
N18050 G00 Z1.0000
N18060 X25.1640 Y31.5695
N18070 G38.2 z-1.969 F19.685
N18080 G92 Z0.0
N18090 G00 Z0.1969
N18100 G92 Z0.0
N18110 G00 Z0.2000
N18120 M03
N18130 G04 P1.0
N18140 G02 X25.2541 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N18150 X25.2920 Y31.4415 I-0.0901 J-0.0909 F45.0
N18160 I-1.0955 J0.0000
N18170 X25.2280 Y31.3775 I-0.0640 J0.0000
N18180 M05
N18190 G04 P0.3
N18200 G00 Z1.0000
N18210 X14.3969 Y31.5695
N18220 G38.2 z-1.969 F19.685
N18230 G92 Z0.0
N18240 G00 Z0.1969
N18250 G92 Z0.0
N18260 G00 Z0.2000
N18270 M03
N18280 G04 P1.0
N18290 G02 X14.4871 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N18300 X14.5249 Y31.4415 I-0.0901 J-0.0909 F45.0
N18310 I-0.6279 J0.0000
N18320 X14.4609 Y31.3775 I-0.0640 J0.0000
N18330 M05
N18340 G04 P0.3
N18350 G00 Z1.0000
N18360 X21.6252 Y31.5695
N18370 G38.2 z-1.969 F19.685
N18380 G92 Z0.0
N18390 G00 Z0.1969
N18400 G92 Z0.0
N18410 G00 Z0.2000
N18420 M03
N18430 G04 P1.0
N18440 G02 X21.7153 Y31.5324 Z0.1000 I0.0000 J-0.1280 F600.0
N18450 X21.7532 Y31.4415 I-0.0901 J-0.0909 F45.0
N18460 I-1.0955 J0.0000
N18470 X21.6892 Y31.3775 I-0.0640 J0.0000
N18480 M05
N18490 G04 P0.3
N18500 G00 Z1.0000
N18510 X38.0148 Y25.8310
N18520 G38.2 z-1.969 F19.685
N18530 G92 Z0.0
N18540 G00 Z0.1969
N18550 G92 Z0.0
N18560 G00 Z0.2000
N18570 M03
N18580 G04 P1.0
N18590 G02 X38.1115 Y25.8435 Z0.1000 I0.0635 J-0.1111 F600.0
N18600 X38.1895 Y25.7834 I-0.0332 J-0.1236 F45.0
N18610 X38.8920 Y20.3494 I-6.2514 J-3.5707
N18620 G01 X37.0803 Y13.5879
N18630 G03 X37.1012 Y13.5517 I0.0285 J-0.0076
N18640 G01 X39.9990 Y12.7752
N18650 G03 X40.0352 Y12.7961 I0.0076 J0.0285
N18660 G01 X44.0469 Y27.7680
N18670 G03 X44.0260 Y27.8042 I-0.0285 J0.0076
N18680 G01 X41.1567 Y28.5730
N18690 X41.9255 Y31.4422
N18700 G03 X41.9046 Y31.4784 I-0.0285 J0.0076
N18710 G01 X35.4046 Y33.2201
N18720 X35.3970 Y33.2211
N18730 X10.3970
N18740 G03 X10.3816 Y33.2168 I0.0000 J-0.0295
N18750 G01 X5.8816 Y30.4668
N18760 G03 X5.8838 Y30.4151 I0.0154 J-0.0252
N18770 G01 X7.8838 Y29.4151
N18780 G03 X7.9265 Y29.4415 I0.0132 J0.0264
N18790 G01 Y30.1437
N18800 X9.3838 Y29.4151
N18810 G03 X9.4265 Y29.4415 I0.0132 J0.0264
N18820 G01 Y30.1437
N18830 X10.8838 Y29.4151
N18840 G03 X10.9265 Y29.4415 I0.0132 J0.0264
N18850 G01 Y30.1437
N18860 X12.3838 Y29.4151
N18870 G03 X12.3970 Y29.4120 I0.0132 J0.0264
N18880 G01 X31.9380
N18890 G02 X38.1895 Y25.7834 I0.0000 J-7.1993
N18900 X38.1656 Y25.6961 I-0.0556 J-0.0317
N18910 M05
N18920 G04 P0.3
N18930 G00 Z1.0000
N18940 X42.8716 Y29.8251
N18950 G38.2 z-1.969 F19.685
N18960 G92 Z0.0
N18970 G00 Z0.1969
N18980 G92 Z0.0
N18990 G00 Z0.2000
N19000 M03
N19010 G04 P1.0
N19020 G02 X42.9116 Y29.7363 Z0.1000 I-0.0879 J-0.0931 F600.0
N19030 X42.8767 Y29.6442 I-0.1279 J-0.0042 F45.0
N19040 G01 X42.8108 Y29.5744
N19050 X42.6474 Y29.4753
N19060 X42.4550 Y29.4170
N19070 G03 X42.4340 Y29.3887 I0.0086 J-0.0283
N19080 G01 Y29.1683
N19090 G03 X42.4636 Y29.1388 I0.0295 J0.0000
N19100 G01 X45.4636
N19110 G03 X45.4931 Y29.1683 I0.0000 J0.0296
N19120 G01 Y30.9183
N19130 G03 X45.4636 Y30.9479 I-0.0295 J0.0000
N19140 G01 X42.4636
N19150 G03 X42.4340 Y30.9183 I0.0000 J-0.0296
N19160 G01 Y30.6776
N19170 G03 X42.4550 Y30.6493 I0.0296 J0.0000
N19180 G01 X42.6474 Y30.5910
N19190 X42.8108 Y30.4919
N19200 X42.9365 Y30.3588
N19210 X43.0155 Y30.2020
N19220 X43.0424 Y30.0332
N19230 X43.0155 Y29.8643
N19240 X42.9365 Y29.7075
N19250 X42.8767 Y29.6442
N19260 G02 X42.7862 Y29.6416 I-0.0465 J0.0439
N19270 M05
N19280 G04 P0.3
N19290 G00 Z1.0000
N19300 X45.4411 Y27.0113
N19310 G38.2 z-1.969 F19.685
N19320 G92 Z0.0
N19330 G00 Z0.1969
N19340 G92 Z0.0
N19350 G00 Z0.2000
N19360 M03
N19370 G04 P1.0
N19380 G02 X45.3438 Y27.0068 Z0.1000 I-0.0541 J0.1160 F600.0
N19390 X45.2710 Y27.0732 I0.0433 J0.1205 F45.0
N19400 I0.6813 J0.3177
N19410 X45.3020 Y27.1582 I0.0580 J0.0270
N19420 M05
N19430 G04 P0.3
N19440 G00 Z1.0000
N19450 X46.2697 Y16.1984
N19460 G38.2 z-1.969 F19.685
N19470 G92 Z0.0
N19480 G00 Z0.1969
N19490 G92 Z0.0
N19500 G00 Z0.2000
N19510 M03
N19520 G04 P1.0
N19530 G02 X46.1724 Y16.1939 Z0.1000 I-0.0541 J0.1160 F600.0
N19540 X46.0996 Y16.2603 I0.0433 J0.1205 F45.0
N19550 G01 X45.2669 Y18.0461
N19560 X47.7325 Y19.1958
N19570 G03 X47.7495 Y19.2236 I-0.0125 J0.0268
N19580 G01 X47.4810 Y27.4408
N19590 G03 X44.4887 Y27.8351 I-1.5287 J-0.0499
N19600 G01 X42.2812 Y20.5624
N19610 G03 X42.2827 Y20.5413 I0.0283 J-0.0086
N19620 G01 X45.2765 Y14.1210
N19630 G03 X45.3311 Y14.1234 I0.0268 J0.0125
N19640 G01 X46.1006 Y16.2377
N19650 G02 X46.1827 Y16.2760 I0.0601 J-0.0219
N19660 M05
N19670 G04 P0.3
N19680 G00 Z1.0000
N19690 X46.3304 Y13.5095
N19700 G38.2 z-1.969 F19.685
N19710 G92 Z0.0
N19720 G00 Z0.1969
N19730 G92 Z0.0
N19740 G00 Z0.2000
N19750 M03
N19760 G04 P1.0
N19770 G02 X46.3800 Y13.4255 Z0.1000 I-0.0772 J-0.1021 F600.0
N19780 X46.3554 Y13.3302 I-0.1267 J-0.0182 F45.0
N19790 X45.2264 Y13.7087 I-0.5011 J0.3785
N19800 G03 X45.1968 Y13.7382 I-0.0296 J0.0000
N19810 G01 X44.4468
N19820 G03 X44.4189 Y13.7182 I-0.0000 J-0.0295
N19830 G01 X44.0764 Y12.7182
N19840 G03 X44.0748 Y12.7087 I0.0280 J-0.0096
N19850 G01 Y10.2087
N19860 G03 X44.0791 Y10.1933 I0.0295 J0.0000
N19870 G01 X46.8291 Y5.6933
N19880 G03 X46.8808 Y5.6954 I0.0252 J0.0154
N19890 G01 X47.8808 Y7.6954
N19900 G03 X47.8543 Y7.7382 I-0.0264 J0.0132
N19910 G01 X47.1521
N19920 X47.8808 Y9.1954
N19930 G03 X47.8543 Y9.2382 I-0.0264 J0.0132
N19940 G01 X47.1521
N19950 X47.8808 Y10.6954
N19960 G03 X47.8543 Y10.7382 I-0.0264 J0.0132
N19970 G01 X47.1521
N19980 X47.8808 Y12.1954
N19990 G03 X47.8818 Y12.2195 I-0.0264 J0.0132
N20000 G01 X47.2893 Y13.7195
N20010 G03 X47.2618 Y13.7382 I-0.0275 J-0.0109
N20020 G01 X46.5118
N20030 G03 X46.4823 Y13.7087 I0.0000 J-0.0295
N20040 G02 X46.3554 Y13.3302 I-0.6279 J0.0000
N20050 X46.2658 Y13.3177 I-0.0511 J0.0386
N20060 M05
N20070 G04 P0.3
N20080 G00 Z1.0000
N20090 X41.3199 Y11.4432
N20100 G38.2 z-1.969 F19.685
N20110 G92 Z0.0
N20120 G00 Z0.1969
N20130 G92 Z0.0
N20140 G00 Z0.2000
N20150 M03
N20160 G04 P1.0
N20170 G02 X41.2937 Y11.5371 Z0.1000 I0.1010 J0.0787 F600.0
N20180 X41.3421 Y11.6228 I0.1271 J-0.0152 F45.0
N20190 X42.3347 Y10.9650 I0.3860 J-0.4953
N20200 G03 X42.3556 Y10.9288 I0.0285 J-0.0076
N20210 G01 X43.0801 Y10.7347
N20220 G03 X43.1122 Y10.7468 I0.0076 J0.0285
N20230 G01 X43.7019 Y11.6241
N20240 G03 X43.7059 Y11.6329 I-0.0245 J0.0165
N20250 G01 X44.3530 Y14.0477
N20260 G03 X44.3528 Y14.0637 I-0.0285 J0.0076
N20270 G01 X42.8612 Y19.1221
N20280 G03 X42.8107 Y19.1334 I-0.0283 J-0.0084
N20290 G01 X41.3271 Y17.4604
N20300 G03 X41.3416 Y17.4122 I0.0221 J-0.0196
N20310 G01 X42.0199 Y17.2305
N20320 X40.9389 Y16.0115
N20330 G03 X40.9534 Y15.9633 I0.0221 J-0.0196
N20340 G01 X41.6316 Y15.7816
N20350 X40.5507 Y14.5626
N20360 G03 X40.5651 Y14.5144 I0.0221 J-0.0196
N20370 G01 X41.2434 Y14.3327
N20380 X40.1624 Y13.1137
N20390 G03 X40.1552 Y13.0907 I0.0221 J-0.0196
N20400 G01 X40.3393 Y11.4885
N20410 G03 X40.3610 Y11.4633 I0.0294 J0.0034
N20420 G01 X41.0854 Y11.2692
N20430 G03 X41.1216 Y11.2901 I0.0076 J0.0285
N20440 G02 X41.3421 Y11.6228 I0.6066 J-0.1625
N20450 X41.4320 Y11.6117 I0.0393 J-0.0505
N20460 M05
N20470 G04 P0.3
N20480 G00 Z1.0000
N20490 X41.2558 Y9.4459
N20500 G38.2 z-1.969 F19.685
N20510 G92 Z0.0
N20520 G00 Z0.1969
N20530 G92 Z0.0
N20540 G00 Z0.2000
N20550 M03
N20560 G04 P1.0
N20570 G02 X41.2715 Y9.3497 Z0.1000 I-0.1090 J-0.0671 F600.0
N20580 X41.2140 Y9.2698 I-0.1247 J0.0291 F45.0
N20590 G01 X41.1322 Y9.2194
N20600 X40.9487 Y9.1660
N20610 X40.7479 Y9.1595
N20620 G03 X40.7203 Y9.1376 I0.0010 J-0.0295
N20630 G01 X40.6632 Y8.9247
N20640 G03 X40.6841 Y8.8885 I0.0285 J-0.0076
N20650 G01 X43.5819 Y8.1121
N20660 G03 X43.6181 Y8.1330 I0.0076 J0.0285
N20670 G01 X44.0710 Y9.8233
N20680 G03 X44.0501 Y9.8595 I-0.0285 J0.0076
N20690 G01 X41.1524 Y10.6360
N20700 G03 X41.1162 Y10.6151 I-0.0076 J-0.0285
N20710 G01 X41.0539 Y10.3826
N20720 G03 X41.0668 Y10.3498 I0.0285 J-0.0076
N20730 G01 X41.2375 Y10.2437
N20740 X41.3697 Y10.1057
N20750 X41.4567 Y9.9446
N20760 X41.4924 Y9.7727
N20770 X41.4747 Y9.6026
N20780 X41.4050 Y9.4465
N20790 X41.2881 Y9.3155
N20800 X41.2140 Y9.2698
N20810 G02 X41.1259 Y9.2907 I-0.0336 J0.0545
N20820 M05
N20830 G04 P0.3
N20840 G00 Z1.0000
N20850 X37.3642 Y9.8409
N20860 G38.2 z-1.969 F19.685
N20870 G92 Z0.0
N20880 G00 Z0.1969
N20890 G92 Z0.0
N20900 G00 Z0.2000
N20910 M03
N20920 G04 P1.0
N20930 G02 X37.3271 Y9.7507 Z0.1000 I-0.1280 J0.0000 F600.0
N20940 X37.2362 Y9.7129 I-0.0909 J0.0901 F45.0
N20950 I0.0000 J0.7517
N20960 X37.1722 Y9.7769 I0.0000 J0.0640
N20970 M05
N20980 G04 P0.3
N20990 G00 Z1.0000
N21000 X35.6201 Y9.0295
N21010 Z0.2000
N21020 M03
N21030 G04 P1.0
N21040 G02 X35.7101 Y9.0669 Z0.1000 I0.0905 J-0.0905 F600.0
N21050 X35.8011 Y9.0295 I0.0005 J-0.1280 F45.0
N21060 G03 X37.6666 Y8.4812 I1.4351 J1.4351
N21070 G01 X40.1567 Y9.0215
N21080 G03 X40.1713 Y9.0712 I-0.0063 J0.0289
I am cutting the text here due to limitations on the size of a new post
N41810 M05 M30
Thank you!
WyoGreen
Re: Grbl problems
Post by WyoGreen »
If I remember right, the lines without the G commands normally use the last G command issued.
polemidis
Re: Grbl problems
Post by polemidis »
WyoGreen wrote: Tue May 22, 2018 11:14 pm If I remember right, the lines without the G commands normally use the last G command issued.
Maybe but the wrkflow of adding manually the G command is far from ideal.
So, after more digging I found out that in Linux, only the development version is available for download. I managed to kind of install the stable version through wine, which exported the correct G commands. It needs a little work because there is no grbl post processor in the stable version, but anyway its good for no,w I may have some functional gcode even through the wine
So resume is, that in the development version for linux (which looks very nice! btw) there is a bug that keeps the head of some G commands to show up, no matter which post processor you use. Hopefully that post will be useful to the developer(s) in order to correct that problem.
djreiswig
Re: Grbl problems
Post by djreiswig »
If you edit your post and search for the lines that have the G commands (G0, G1, etc.) and change the ModalText to just Text, it will always output those lines.
So
post.ModalText (" G00")
would be
post.Text (" G00")
polemidis
Re: Grbl problems
Post by polemidis »
Thank you!!!!!!!!!!!!! That worked!!!!!!!!!!!!!!!!!!!
polemidis
Re: Grbl problems
Post by polemidis »
Now I have problem on the N500 line. It shows the "G02", misses the X, Y, but shows the I,J offset. :( :(
djreiswig
Re: Grbl problems
Post by djreiswig »
If you want all of the moves output even if they are the same then change the modalnumber lines to nonmodalnumber. The modal command just says that if the coordinate is the same as last time then don't ouput it again.
Read through the post documentation file, it's pretty informative.
polemidis
Re: Grbl problems
Post by polemidis »
Djreiswig thank you for replying to me, I appreciate it. I am sorry if I ask some dumb questions
About the post documentation file, is it a separate file, where can I find it? The description on each post is limited.
What is the process to change the modalnumber lines to nonmodal ones?
I tried to change this function
unction OnArc()
   local radius = math.hypot(currentX - arcCentreX, currentY - arcCentreY)
   dist = dist + radius * math.abs(arcAngle)
   if(arcAngle <0) then
      post.Text (" G03")
   else
      post.Text (" G02")
   post.ModalNumber (" X", (endX + offX) * scale, "0.0000")
   post.ModalNumber (" Y", (endY + offY) * scale, "0.0000")
   if(offZ) then
      post.ModalNumber (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
   post.Text (" I")
   post.Text (" J")
   post.Eol()
to this
function OnArc()
      post.Text (" G03")
   else
      post.Text (" G02")
   post.Number (" X", (endX + offX) * scale, "0.0000")
   post.Number (" Y", (endY + offY) * scale, "0.0000")
   if(offZ) then
      post.Number (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
   post.Text (" I")
   post.Text (" J")
   post.Eol()
but the post processor throws error
Screenshot from 2018-05-23 09-19-10.png (319.78 KiB) Viewed 8051 times
Any ideas plz?
djreiswig
Re: Grbl problems
Post by djreiswig »
Only dumb question is the one that isn't asked.
Change them to nonmodalnumber not number.
The documentation is in SheetCam next to the edit post button in machine options. It is the right button on the bottom. Can't recall what it says.
polemidis
Re: Grbl problems
Post by polemidis »
still same error :(
Screenshot from 2018-05-23 11-23-59.png (201.14 KiB) Viewed 8046 times
polemidis
Re: Grbl problems
Post by polemidis »
Ok, I solved it. Thank you for the help. The problem now was that the "NonModalNumber" has to be like this, and not "nonModalNumber", be aware of the upper case.
The complications arose because
a) in the stable version there is no "grbl post processor"
b) in the Linux development version which I use, and where thjere is grbl post processor, the post processor documentation is not working.
My workaround was to open the stable version through wine, choose the "LinuxCNC" post processor, and read that documentation. Even though maybe its not the perfect match, I was able to resolve the problem.
Thank you again
djreiswig
Re: Grbl problems
Post by djreiswig »
Yeah, sorry about that. Typing on my phone and didn't get the capitalization correct. SheetCam is picky about that. Glad you got it.
Ernesto
Re: Grbl problems
Post by Ernesto »
Thanks so much for posting this! I've been fighting the exact same thing for days!
I'm running the linux version too and attempting to use the grbl thc with scriber post too. I had to modify it to add M08/09 commands to control my thc but it's been fighting me with mystery code that locks up grbl.
Are you having any problems with arcs looking blocky once the tap file is opened in bCNC and grbl locking up when asked to punch a 6mm diameter hole with a plasma cutter with a kerf of .125?
Re: Grbl problems
Do you know what code is locking up GRBL? Could you post a copy of the g-code here or in a PM to me. If you know roughly where in the file it is choking, that would help.
Ernesto
Re: Grbl problems
Post by Ernesto »
I thought I was using the linux version of sheetcam but on the machine I've been working on, I've been using the windows version in wine, with a grbl with scriber post that I found posted here on the forum. I'll see if the other machine outputs the same stuff.
Line N0130 is the first place that this code locks up, throwing different errors but usually 26. The program just stops, sits at idle, and the 26, 33, and 35 errors show up in terminal.
N0010 G20
N0020 F1
N0030 G53 G90 G40
N0040 G00 X2.5591 Y5.0231
N0050 G38.2 z-1.969 F19.685
N0060 G92 Z0.0
N0070 G00 Z0.0591
N0080 G92 Z0.0
N0090 G00 Z0.2500
N0100 M03 S1000
N0110 G04 P0.5
N0120 G01 Z0.1125 F3.937
N0130 G02 I0.0000 J0.0950 F35.0
N0140 M05
N0150 G00 Z0.3937
N0160 X2.7528 Y7.7998
N0170 Z0.2500
N0180 M03 S1000
N0190 G04 P0.5
N0200 G01 Z0.1125 F3.937
N0210 G02 X2.8384 Y7.6611 I-0.0266 J-0.1121 F65.0
N0220 X2.7751 Y7.5448 I-0.2457 J0.0582
N0230 G03 X2.2823 Y6.3362 I1.2833 J-1.2281
N0240 G02 X2.0298 Y6.0861 I-0.2526 J0.0026
N0250 G01 X1.4961
N0260 G02 X1.2436 Y6.3386 I0.0000 J0.2525
N0270 G01 Y9.1566
N0280 G02 X1.3008 Y9.2437 I0.0950 J0.0000
N0290 G01 X2.1581 Y9.6152
N0300 G02 X2.2576 Y9.6002 I0.0378 J-0.0871
N0310 G01 X2.9042 Y9.0459
N0320 G02 X2.9373 Y8.9784 I-0.0618 J-0.0721
N0330 G01 X2.9374 Y8.9763
N0340 G02 X2.8384 Y7.6611 I-4.1920 J-0.3455
N0350 G01
N0360 M05
N0370 G38.2 z-1.969 F19.685
N0380 G92 Z0.0
N0390 G00 Z0.0591
N0400 G92 Z0.0
N0410 G00 Z0.3937
N0420 X1.3632 Y10.3907
N0430 Z0.2500
N0440 M03
N0450 G04 P0.5
N0460 G01 Z0.1125 F3.937
N0470 G02 X1.3033 Y10.2392 I-0.1057 J-0.0458 F65.0
N0480 G01 X1.2207 Y10.2034
N0490 G02 X1.2011 Y10.2087 I-0.0065 J0.0149
N0500 G03 X1.0236 Y10.2987 I-0.1775 J-0.1299
N0510 X0.9843 Y10.2848 I-0.0000 J-0.0625
N0520 G02 X0.3936 I-0.2954 J0.3653
N0530 G03 X0.3543 Y10.2987 I-0.0393 J-0.0486
N0540 X0.1344 Y10.0787 I0.0000 J-0.2200
N0550 G01 Y0.3543
N0560 G03 X0.3543 Y0.1344 I0.2200 J-0.0000
N0570 G01 X1.0236
N0580 G03 X1.2436 Y0.3543 I0.0000 J0.2200
N0590 G01 Y5.1181
N0600 G02 X1.3386 Y5.2131 I0.0950 J0.0000
N0610 G01 X2.0866
N0620 G02 X2.1816 Y5.1181 I0.0000 J-0.0950
N0630 G03 X2.8095 Y4.8357 I0.3775 J-0.0000
N0640 G01 X3.0732 Y5.0715
N0650 G03 X3.0804 Y5.0793 I-0.0417 J0.0466
N0660 G02 X3.5683 Y5.4545 I0.9970 J-0.7914
N0670 G03 Y5.5691 I-0.0250 J0.0573
N0680 G02 X3.0846 Y5.9392 I0.5092 J1.1667
N0690 X3.3331 Y7.0000 I0.7769 J0.3775
N0700 G03 X3.4379 Y7.1261 I-0.2309 J0.2986
N0710 X3.8112 Y9.3997 I-3.3367 J1.7153
N0720 X3.7369 Y9.5340 I-0.2175 J-0.0327
N0730 G01 X2.4029 Y10.6774
N0740 G03 X2.3374 Y10.6873 I-0.0407 J-0.0475
N0750 G01 X1.3033 Y10.2392
N0760 G02 X1.1862 Y10.3525 I-0.0019 J0.1152
N0770 M05
N0780 G38.2 z-1.969 F19.685
N0790 G92 Z0.0
N0800 G00 Z0.0591
N0810 G92 Z0.0
N0820 G00 Z3.0000
N0830 X2.0000 Y2.0000
N0840 Z0.3937
N0850 X0.0000 Y0.0000
N0860 M05 M30
I think that the last x y coordinates being way back before the probe cycle is making them inaccessible for grbl to read/remember as the G02 arc start location.
Also, line N0350 locks things up as well, but only sometimes. It throws grbl error 33 or 35.
If I add xy data from line N0040 to N0130, erase N0350, and fix one other spot that I can't remember, the code runs fine.
I'm not sure it this related to the issue but bCNC is also showing the arcs as chunky lines in the display. It seems like the cutter may follow a smoother path though, just from watching the motors. This may be a Sheetcam setting that I fat fingered though. I'll double check that today.
The only other thing I need to figure out is how to add an M08 after the z descents to cut height and M09's right before the M05 command. These will turn on/off my standalone THC, I hope, by breaking the divided arc signal. I've tried adding them to the post processor myself but they never pop up in the right spot in the code.
