Hole only cutting lead in
mono
Post by mono » Tue May 01, 2018 6:56 am
Hello
everyone I'm new to this forum and new to Sheetcam.
Maybe someone can help
I'm using a DIY plasma table with Mach3
I have attached 2 Job files, one called 'zbrackets' when I run it on the machine, it comes to cutting the hole it only cuts the lead in.
However the second file 'hole16thc' works perfectly.
I can't just see what is wrong.
hole16thc.txt
(666 Bytes) Downloaded 8 times
ZBRACKETS.txt
(3.79 KiB) Downloaded 12 times
hole.job
(5.53 KiB) Downloaded 9 times
mono
Re: Hole only cutting lead in
Post by mono » Wed May 09, 2018 7:42 am
I found that setting overcut to 0 stopped this happening.
I don't understand why though.
