And as usual... I'm not disappointed.
Looks to be working right, so nice to have chain cutting on duplicates back!
Thanks again for your willingness to to make a good program GREAT!
Chain cutting question
Re: Chain cutting question
Either I have set something up wrong or it's still not quite right. The chain cutting tool path works with both copied and duplicated parts now but... It adds a pre-heat cycle to the tool path using a flame post and it adds a reference move when using the CandCTHC post. I have experimented with different posts but I can't seem to get it to leave them out.
I've attached a file with two parts chained together, on line 690 it has added the G28.1 reference move. Hope this helps!
Thanks again Les!
Thanks again Les!
- .250 chain tooth long.tap
- (2.82 KiB) Downloaded 91 times
I found the problem. It will be fixed in the next release.
Hi Les, not to be a pest... but how's the next release coming?
Thanks, Steve
Thanks, Steve
Hi Les, any update on the next release?
Thanks, Steve
Thanks, Steve
