I have been using Sheet cam for a few years and love it....."all of a sudden" "for no apparent reason" LOL after importing dxf files and creating lead ins, each object has 3 start points created. The correct one, plus 2 little tiny triangles Files are attached to see what I mean. I am 99.999% sure it is not being exported from Corel X8. Any help to avoid the goblins is appreciated I never had this happen before
Marty
tiny wierd triangles created on import
- lucy and frank triangle error .job
- (103.75 KiB) Downloaded 76 times
- lucy and frank.tap
- (25.1 KiB) Downloaded 77 times
- lucy and frank triangle error .dxf
- (315.35 KiB) Downloaded 87 times
Re: tiny wierd triangles created on import
I don't know what those triangles are but they are definitley in the dxf file.
ok thanks Les I will put Coreldraw under the microscope and run some export tests
Appreciate the look see...possibly Corel is leaving some artifacts after copy/paste /trim of objects
Marty
Marty
