angle
tony
angle
Post by tony »
test arc.jpg (139.83 KiB) Viewed 6653 times
test arc.tap
(907 Bytes) Downloaded 165 times
Here is an example of what i am facing a problem in some arcs angle, in this example the axe A turn from 270 into 8 instead of 182 during cutting in others cases the cutter go height of material & turn. Donno if i should edit the post processor or there is an option in the sheetcam can fix this, specially there is no 4 axis simulation so the problem only appear during work
