Is there any way to force the cut sequence from "left" to "right" when using the rotary plugin?
I use the quick cut sequence and that works, but would be handy if it always cut from left end to right.
Dan
Rotary cut order
Re: Rotary cut order
In your cutting operation go to the cut path tab. Enable auto optimisation and set the start position to bottom left and the cut direction slider all the way to the left. That may help.
