I am sure this has been covered somewhere but the answer eludes me.
If I want to plasma cut a square for example from material that is too thick to pierce but not too thick to edge start, how can I configure sheetcam to not cut the edges which align with the edge of the material?
Thanks in advance,
Chris
edge starting a part.
Re: edge starting a part.
These are the two ways I would edge start, I'm not keen on starting from the edge of plate as you tend to get movement from the skeleton expanding.
It's worth drilling holes I think if you only have a few, doesn't take that long with hand drill.
Thanks for the response but not quite what I had in mind. I take your point though.
I'll try again.
Lets say I have a piece of 200mm wide flat bar which is coincidentally the same width of the part I wish to cut. So all I need to do is cut the ends.
How can I remove the 2 sides from the cut list without doing a new drawing?
I'll try again.
- sheetcam screenshot.png (66.95 KiB) Viewed 1602 times
I am afraid SheetCam doesn't let you do that. You need to modify the drawing.
