Thanks Les
g-codes won't load to mach3
Re: g-codes won't load to mach3
I am having the same problem as Ivan. I can download art and import the dxf file into sheetcam. I can save the job BUT when I run the post processor it is not creating a valid tap file. When I try to open the G code in Mach 3 it only have a few lines of code. I have attached the job file and tap file. ANY help would be greatly appreciated. I should note that this just started and only on new downloads. It will open previously save tap files no problem. Also I do have a license with both sheetcam and mach 3. Thanks!
- 3Gnomes with Hearts.tap
- (208 Bytes) Downloaded 51 times
- 3Gnomes with Hearts.job
- (97.36 KiB) Downloaded 57 times
