Radius to end of arc differs from radius to startline
Ktown
Post by Ktown »
I am getting the following error when I try and run some DXF files "radius to the end of the arc differs from the radius to the start 2508. I did a search and most suggest ij mode incremental I did this but it than just moves to a different line with the same error. I am at a loss of how to fix this issue.
I have attach a copy of the G code I am running and the DXF file and the post processor I am running in sheetcam
thanks in advance for the help.
Mike
garage2.tap
(160.43 KiB) Downloaded 138 times
post.txt
(4.53 KiB) Downloaded 152 times
dads repair shop.dxf
(492.96 KiB) Downloaded 165 times
