Scriber settings
Scriber settings
How are you Les , i am running Candcnc's commandcnc and i was wondering if you could help me set up my scribe so the cylinder would stay down and the scribe stay on the entire scribe cycle and only the z axis move up and down .This is how Wolfsmetalfab has his set up and seems to work the best that I have seen. He has a video on Yootube if you would like to view for a better explanation of the process,thanks for your time.
Scriber settins
CandCNCPlasmallcnc-23(Edited)
Scriber settings
CandCNCPlasmaLLCNC-rev23(Edited)
Here you go Les ,thanks
- CandCNCPlasmaLLCNC-rev23.scpost
- (34.61 KiB) Downloaded 100 times
- (34.61 KiB) Downloaded 78 times
Give this a try. I hate messing with CandCNC posts. They are very complicated and it is difficult to make changes and be sure you aren't affecting some other part of the code.
- CandCNCPlasmaLLCNC-rev23-marker on.scpost
- (34.7 KiB) Downloaded 133 times
Scriber settings
Sure will , i will let you know how it goes , thanks
Scriber settings
I just tried it Les and it doesn't seem to be adding the offsets to the code
