drawing's
drawing's
I have several drawings that were drawn in HYCAD and exported as a DXF in a Burn Tables setup. I switched to CandCNC electronics with a Linux computer. I have the latest version of Sheetcam. When I import into Sheetcam some lines are duplicated and some arc's are broke. Not all files but 3 out of 4. I am real green at this. When I try to export them as a SVG it ask me for the width and height. Not sure what to put there. Any help is much appreaceated.
drawings
When 2 arcs are connected in the drawing and when I import to sheetcam there is space between them.
- hook train 6 cars.dxf
- I have cut this several times in my old Burn tables setup with no issues. I switched to CandCNC with Linux computer and the latest version of Sheetcam.
- (38.95 KiB) Downloaded 127 times
There is a few gaps in the drawing, I was using Solidworks which has a sketch check tool, there was 8 errors - slight gaps or overlap
Try this file.
Try this file.
- Hook train fixed.DXF
- (77.63 KiB) Downloaded 130 times
