German Translation
This is the place for any plugins, posts or other useful tools you have created.
hans
Re: German Translation
Post by hans »
Hmm yes then we have to edit all other translations. I think that's not worth it.
Ok then the tool would have the name of the operation. The user would understand that though.
hans
Post by hans »
In the dialog 'New thread mill' the parameter 'Thread depth' - is this the maximum depth that the mill is able to mill?
(This parameter is not described in the manual)
And something about thread milling I wondered.
Why is the thread diameter determined by the tool and not by the drawing hole size?
I think thread milling is comparable to pocket operation where pocket size is determined by the drawing. The thread mill is capable of milling different thread sizes, so if I want to do that I have to define multiple tools for the same tool...
hans
Post by hans »
Les Newell wrote: Fri Jan 22, 2021 1:07 pm I can but the problem is that it would break all of the other translations. Is it possible for you to work around it?
Hmm but not really nice. if you add something or change the translations, please add that and let me know.
Edit: the same with 'drill'
In which context appears
'Cannot cut on the edge of a flange'
and
'Flange thickness' ?
hans wrote: Fri Jan 22, 2021 2:02 pm In the dialog 'New thread mill' the parameter 'Thread depth' - is this the maximum depth that the mill is able to mill?
It is the distance from the peak of the thread to the root of the thread. See https://slideplayer.com/slide/15209113/
The circle is the drill size. The outside diameter of the thread would be the hole size plus twice the thread depth.
The diameter in the tool definition is the diameter of the thread mill, not the diameter of the finished thread. This must be less than the drill size.
This is used by the rotary plugin when cutting I beams. The flange of an I beam is the top or bottom.
hans
Post by hans »
Les Newell wrote: Fri Jan 22, 2021 3:19 pm
Is this the value called 17/24H resp. 5/8H or H ?
Maybe you could add an image like for the other values.
hans wrote: Fri Jan 22, 2021 2:02 pm Why is the thread diameter determined by the tool and not by the drawing hole size?
That what I expected. But actually it looks like this (all the same operation):
Les Newell wrote: Fri Jan 22, 2021 3:19 pm This is used by the rotary plugin when cutting I beams. The flange of an I beam is the top or bottom.
With the "Rotary pipe cutting" plugin?
hans
Post by hans »
Can you say weather this single 'an' appears on another positions in your code, or can I make the translation suitable only for this?
hans wrote: Fri Jan 22, 2021 3:42 pm Is this the value called 17/24H resp. 5/8H or H ?
it's 17/24H or 5/8H depending on the thread type.
Yes. I need to add that image.
Sorry, my mistake. It's a while since I last looked at threading.
Yes.
Can you say weather this single 'at' appears on another positions in your code, or can I make the translation suitable only for this?
It only appears in the move operation. The way it builds up the position string is a bit ugly but I can't think of a better way.
hans
Post by hans »
Les Newell wrote: Fri Jan 22, 2021 4:38 pm
So another tool definition is needed for another thread size with the same tool?
Its ok so...
hans
Post by hans »
After spending a final day on the translation I can proudly present you the german translation 2.0. I reviewed all fields so the big number of spelling errors is away now :-). With the fields I have knowledge of where they belong to I tried to to the best fitted translation.
de.zip
(102.81 KiB) Downloaded 233 times
hans
Post by hans »
While reviewing I came across this field:
What is this about? It looks like a nice feature that I don't know...
hans wrote: Fri Jan 22, 2021 5:47 pm So another tool definition is needed for another thread size with the same tool?
You define the thread size in the threading operation, not the tool.
I'm not sure where your translation got those from. They were part of a feature I was developing a long while back but they are no longer used.
The Mach3 plugin does this automatically. I am working on a way to add functionality similar to the Mach3 plugin for LinuxCNC, EdingCNC etc but it's a fairly low priority at the moment.
Thank you. Did you make many changes to de.po?
hans
Post by hans »
Les Newell wrote: Fri Jan 22, 2021 8:02 pm You define the thread size in the threading operation, not the tool.
Ah yes I missed that, Thanks.
Me neither. The question is where you got the german translation from where my translation is based on ;-)
Only a few to de.po. But maybe there are diff tools for po files...
hans
Post by hans »
Some more optimization...
messages.po.zip
(48.29 KiB) Downloaded 243 times
Thanks.
hans
Post by hans »
I put the translation files to Github. So if you want to make a new release Les, just grab them from there: https://github.com/hansu/sheetcam-german-translation
