Here is a Plugin that does calculations for speeds and feeds. A chart is provided to give you the base info needed. To use UNZIP it inot yuour plugins directory and then restart SheetCam. Then from the plugins menu select Feeds and speeds.
Fill in the values and it does the calculations.
The top 2 tables are for milling and drilling they are used in the Calculate RPM column (RHside)
The bottom table is for Calculate feedrate (LHside) it is the Chipload values. Not the best layout but it works as a proof of concept.
(;-) TP
Scam Feeds and Speeds
OK here is the Feeds and speeds plugin(;-)
- ScamS&F.jpg (80.34 KiB) Viewed 5404 times
- Feeds & Speeds.zip
- (291.44 KiB) Downloaded 346 times
