Re: Second Flame profile question
PK
Post by PK » Tue May 12, 2015 10:22 am
Hi Steve,
I use the -c switch. Like this:
SheetCam TNG Development.exe -c plasma
This will create a directory "plasma" which holds it's own toolset and configuration file. Post processor file is still stored with all other post files, but the separate config file holds that info, too.
HTH
Paul
__._,_.___
Posted by: urbnsr@yahoo.com
Visit Your Group
__,_._,___
Les Newell les.newell@...
Post by Les Newell les.newell@... » Tue May 12, 2015 11:06 am
Yes, that is the correct way to do it. Here are some slightly more detailed instructions:
Make a copy of the shortcut to SheetCam and rename it. Right-click on the shortcut and select 'Properties'. In the 'Target' tab the Target should be something like this:
"C:\Program Files (x86)\SheetCam TNG\SheetCam TNG.exe"
To use a different profile change the target to:
"C:\Program Files (x86)\SheetCam TNG\SheetCam TNG.exe" -c myProfile
where myProfile is a name for the profile. The first time you use that shortcut it will copy your original SheetCam settings to the new profile. From then on any changes you make to that profile's settings will not affect any other profiles you have set up.
On 12/05/2015 11:22, urbnsr@yahoo.com (urbnsr@yahoo.com) [sheetcam] wrote:
Hi Steve,
HTH
Paul
__._,_.___
Visit Your Group
Unsubscribe ([email]sheetcam-unsubscribe@yahoogroups.com?subject=Unsubscribe[/email]) &bull; Terms of Use
__,_._,___
steve@adnaironworks.co...
Post by steve@adnaironworks.co... » Tue May 12, 2015 2:18 pm
Thank you for the prompt replies! I'll have a go at it today!!
__._,_.___
Posted by: steve@adnaironworks.com
Visit Your Group
__,_._,___
Post by steve@adnaironworks.co... » Tue May 12, 2015 3:57 pm
Thanks again Les! Works perfect!
__._,_.___
Visit Your Group
__,_._,___
