I would like to set my cut paths manually as i am V cutting and don't want the parts too fall out if i cut a little too deep.
Even with the cut bias all the way horizontal sheetcam is still cutting each square out separately. I would like it to cut all the horizontal lines first then cut the vertical lines, is there a way to achieve this?
that's easier said than done as they are each individual squares, it would mean i have to effectively re draw each time and i have several different ones to do so not possible.
There is nothing that you can do if they are all separate squares. If you run these a lot, I'd make the effort to just lay out the lines. They don't even need to be on separate layers, just a crosshatch pattern of lines.
