Scrap cut
Posted: Wed Apr 29, 2015 1:09 am
by aeviaanah
Ive used nesting software in the past that incorporates a programmed scrap cut. It is usually applied after nesting is complete. You would manually draw a line from outside of the sheet to the nearest part and using preset clearances a cut line is generated with those clearances applied. This is extremely useful for fitting scrap in the scrap bin. No wasted time manually scrap cutting when it can be programmed.
Ive used the remnant cutoff but does not quit behave as I am describing
Posted: Wed Apr 29, 2015 11:18 am
I have tried to keep away from adding drawing tools to SheetCam but I may have to rethink this in the future.
Posted: Wed Apr 29, 2015 4:26 pm
by Vmax549
Resist the force Obewon.
If using Mach3 you can use a button code to setup a cut function. Move to the start point press button then move to end point press the button and it creates its own Gcode to do the cut.
BUT now conversational Sheetcam I would buy (:-)
SheetCad now that is a slippery sloap. I would rather have SheetCamTurn.
Just a thought, (;-) TP
Posted: Tue May 05, 2015 2:54 am
by aeviaanah
Happy May the 4th be with you!
Les, how about adding a scrap cut from XY values? Can be an added option in remnant cutoff.
Posted: Thu May 14, 2015 3:01 am
by aeviaanah
bump
