relocate origin...
Posted: Mon Apr 27, 2015 8:25 pm
by Les Newell les.newell@...
Hi Tim,
The file type warning is a bug but I'm not sure of the best way to fix
it. The problem is that files with the 'tap' extension could be Excellon
or G-code and SheetCam doesn't really know which is correct.
The g-code import filter is not the best. Can't Vectric export in dxf or
SVG? If you have to use g-code, could you send me a sample file so I can
try to figure out what is going on.
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
relocate origin...
Posted: Mon Apr 27, 2015 11:30 pm
by Anthony Leske riverlan...
relocate origin...
Posted: Tue Apr 28, 2015 8:32 am
Hi Tim,
I tried loading that tap file and it came in as a complete circle.  If you have problems with dxf and still need to use g-code let me know and I'll dig a bit deeper into this.
By the way when you import a drawing a box appears with a number of options.  On the right hand side of that box are various options for the drawing origin. You can also move your part in SheetCam using the coordinate boxes at the bottom of teh main SheetCam window. You can also move parts uing the nesting function (Mode->Nesting).
On 27/04/2015 23:07, Tim Gray timothymgray@yahoo.com (timothymgray@yahoo.com) [sheetcam] wrote:
Thank you very much for your reply Les,
Attached is that G-Code  (.tap) file... I looked through and couldn't find any dxf or SVG post processors in Aspire.
Thank you again!   -Tim Gray
__._,_.___
Visit Your Group
__,_._,___
relocate origin...
Posted: Tue Apr 28, 2015 6:37 pm
by Tim Gray timothymgray@...
Surprisingly enough, I just loaded it up, designated the origin as you described and it worked great.
Don't know why it wouldn't work before? But thank you for you your help Les... I really appreciate your input. Tim
From: "Les Newell les.newell@fastmail.co.uk [sheetcam]" <sheetcam@yahoogroups.com>
To: sheetcam@yahoogroups.com
Sent: Tuesday, April 28, 2015 3:32 AM
Subject: Re: [sheetcam] relocate origin...
Hi Tim, I tried loading that tap file and it came in as a complete circle. If you have problems with dxf and still need to use g-code let me know and I'll dig a bit deeper into this. By the way when you import a drawing a box appears with a number of options. On the right hand side of that box are various options for the drawing origin. You can also move your part in SheetCam using the coordinate boxes at the bottom of teh main SheetCam window. You can also move parts uing the nesting function (Mode->Nesting). Les On 27/04/2015 23:07, Tim Gray timothymgray@yahoo.com (timothymgray@yahoo.com) [sheetcam] wrote:
#yiv1595632413 #yiv1595632413 -- #yiv1595632413ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #yiv1595632413 #yiv1595632413ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv1595632413 #yiv1595632413ygrp-mkp #yiv1595632413hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv1595632413 #yiv1595632413ygrp-mkp #yiv1595632413ads { margin-bottom:10px;} #yiv1595632413 #yiv1595632413ygrp-mkp .yiv1595632413ad { padding:0 0;} #yiv1595632413 #yiv1595632413ygrp-mkp .yiv1595632413ad p { margin:0;} #yiv1595632413 #yiv1595632413ygrp-mkp .yiv1595632413ad a { color:#0000ff;text-decoration:none;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ygrp-lc { font-family:Arial;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ygrp-lc #yiv1595632413hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ygrp-lc .yiv1595632413ad { margin-bottom:10px;padding:0 0;} #yiv1595632413 #yiv1595632413actions { font-family:Verdana;font-size:11px;padding:10px 0;} #yiv1595632413 #yiv1595632413activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #yiv1595632413 #yiv1595632413activity span { font-weight:700;} #yiv1595632413 #yiv1595632413activity span:first-child { text-transform:uppercase;} #yiv1595632413 #yiv1595632413activity span a { color:#5085b6;text-decoration:none;} #yiv1595632413 #yiv1595632413activity span span { color:#ff7900;} #yiv1595632413 #yiv1595632413activity span .yiv1595632413underline { text-decoration:underline;} #yiv1595632413 .yiv1595632413attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #yiv1595632413 .yiv1595632413attach div a { text-decoration:none;} #yiv1595632413 .yiv1595632413attach img { border:none;padding-right:5px;} #yiv1595632413 .yiv1595632413attach label { display:block;margin-bottom:5px;} #yiv1595632413 .yiv1595632413attach label a { text-decoration:none;} #yiv1595632413 blockquote { margin:0 0 0 4px;} #yiv1595632413 .yiv1595632413bold { font-family:Arial;font-size:13px;font-weight:700;} #yiv1595632413 .yiv1595632413bold a { text-decoration:none;} #yiv1595632413 dd.yiv1595632413last p a { font-family:Verdana;font-weight:700;} #yiv1595632413 dd.yiv1595632413last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #yiv1595632413 dd.yiv1595632413last p span.yiv1595632413yshortcuts { margin-right:0;} #yiv1595632413 div.yiv1595632413attach-table div div a { text-decoration:none;} #yiv1595632413 div.yiv1595632413attach-table { width:400px;} #yiv1595632413 div.yiv1595632413file-title a, #yiv1595632413 div.yiv1595632413file-title a:active, #yiv1595632413 div.yiv1595632413file-title a:hover, #yiv1595632413 div.yiv1595632413file-title a:visited { text-decoration:none;} #yiv1595632413 div.yiv1595632413photo-title a, #yiv1595632413 div.yiv1595632413photo-title a:active, #yiv1595632413 div.yiv1595632413photo-title a:hover, #yiv1595632413 div.yiv1595632413photo-title a:visited { text-decoration:none;} #yiv1595632413 div#yiv1595632413ygrp-mlmsg #yiv1595632413ygrp-msg p a span.yiv1595632413yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #yiv1595632413 .yiv1595632413green { color:#628c2a;} #yiv1595632413 .yiv1595632413MsoNormal { margin:0 0 0 0;} #yiv1595632413 o { font-size:0;} #yiv1595632413 #yiv1595632413photos div { float:left;width:72px;} #yiv1595632413 #yiv1595632413photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv1595632413 #yiv1595632413photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv1595632413 #yiv1595632413reco-category { font-size:77%;} #yiv1595632413 #yiv1595632413reco-desc { font-size:77%;} #yiv1595632413 .yiv1595632413replbq { margin:4px;} #yiv1595632413 #yiv1595632413ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv1595632413 #yiv1595632413ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #yiv1595632413 #yiv1595632413ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv1595632413 #yiv1595632413ygrp-mlmsg select, #yiv1595632413 input, #yiv1595632413 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #yiv1595632413 #yiv1595632413ygrp-mlmsg pre, #yiv1595632413 code { font:115% monospace;} #yiv1595632413 #yiv1595632413ygrp-mlmsg * { line-height:1.22em;} #yiv1595632413 #yiv1595632413ygrp-mlmsg #yiv1595632413logo { padding-bottom:10px;} #yiv1595632413 #yiv1595632413ygrp-msg p a { font-family:Verdana;} #yiv1595632413 #yiv1595632413ygrp-msg p#yiv1595632413attach-count span { color:#1E66AE;font-weight:700;} #yiv1595632413 #yiv1595632413ygrp-reco #yiv1595632413reco-head { color:#ff7900;font-weight:700;} #yiv1595632413 #yiv1595632413ygrp-reco { margin-bottom:20px;padding:0px;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ov li a { font-size:130%;text-decoration:none;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv1595632413 #yiv1595632413ygrp-sponsor #yiv1595632413ov ul { margin:0;padding:0 0 0 8px;} #yiv1595632413 #yiv1595632413ygrp-text { font-family:Georgia;} #yiv1595632413 #yiv1595632413ygrp-text p { margin:0 0 1em 0;} #yiv1595632413 #yiv1595632413ygrp-text tt { font-size:120%;} #yiv1595632413 #yiv1595632413ygrp-vital ul li:last-child { border-right:none !important; } #yiv1595632413
__._,_.___
Posted by: Tim Gray <timothymgray@yahoo.com>
Visit Your Group
__,_._,___
relocate origin...
Posted: Tue Apr 28, 2015 8:46 pm
