Re: Z move before X and Y after tool change
Posted: Mon Feb 09, 2015 3:11 am
One missing piece of information on my part. I'm using Mach Standard Mill and it has its own tool change routines. When you call for a tool change it goes to a designated x,y,z and measures the tool if necessary.
I figured out the problem. In the Tool Change tab under Job Options there's a check box for "No move to safe Z after tool change". When it is checked there's no Z move before the spindle is started. The output looks like this:
N0010 (Filename: Angle Plate Plate.tap)
N0020 (Post processor: Mach3.scpost)
N0030 (Date:08/02/2015 Time:19:09:02)
N0040 G20 (Units: Inches)
N0050 G40 G90 G91.1
N0060 F1
N0070 (Part: Angle Plate Plate)
N0080 (Operation: Drill, .250 Holes, T101: 90 Degree Spotting Drill, 0.375 in diameter, 0.135 in Deep)
N0090 S4500 (90 Degree Spotting Drill, 0.375 in diameter)
N0100 T101 M06
N0110 G43 H101
N0120 M07 (Mist coolant on)
N0130 S4500 M03
N0140 G00 X4.0000 Y0.5000
N0150 Z0.0300
Chris
__._,_.___
Posted by: chris.attebery@verizon.net
Visit Your Group
__,_._,___
N0050 G40 G90 G91.1
N0060 F1
N0100 T101 M06
N0110 G43 H101
N0130 S4500 M03
N0150 Z0.0300
Chris
__._,_.___
Visit Your Group
- New Members 4
- New Links 1
__,_._,___
