i've been using an electric scriber and the ''plasma MP1000-THC post processor with engraver'' post aka mach3 thc with scriber post. it has been working fine with the exception of i need to manually enter M09 in the gcode to turn it off. i have since bought an air scriber and modified the air scribe mount.
i edited the scribe offsets in the post for the new air scribe mount, that is all i edited in the post. now when i scribe the torch comes down, touches off, moves to z offset, moves to the new xy offset and scribe turns on. scribe on also lowers the air slide mount. that is all good, but now the z axis moves up, maybe a half inch scribing a 3/8'' hole. so i scribe air now.
anyone have an idea of what went wrong? all i modified in the post was the scribe offsets.
__._,_.___
Posted by: K Ohlgren <kohlgren@gmail.com>
Visit Your Group
__,_._,___
scriber post
I have much the same thing happening. What is going on is the scriber will go to it's height, then the Z axis is moving to it's safe z height (slowly). Why it's doing that I don't know. If you make the safe z travel height the same as your scriber z height, then everything is cool. I'm using a different scriber post than you, but it's in the same family of posts.
Hopefully Les or somebody will have an explanation for us.
scriber post
i figured my scriber post had been corrupted, i reloaded the MP1000-THC - with scriber post renamed it MP1000-THC - scriberKJO.scpost put in my switch and axis offsets. i processed a simple 2 - 2'' (.5'' apart) line drawing and here is the gcode with my notes in [] nothing changed
N0010 (Filename: junk12.tap)
N0020 (Post processor: MP1000-THC - scriberKJO.scpost) [renamed scriber post shows as [edited] in sheetcam]
N0030 (Date: 13/12/2014)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 (Part: scribe test)
N0080 (Process: No Offset, LINE, T100: Plate marker) [scriber is tool 100]
N0090 G00 X0.0000 Y0.5000
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z1.3200 [switch offset]
N0130 G92 Z0.0
N0140 G00 Z0.3937 [z axis has always gone to .3937 scribing but i don't know why]
N0150 Y3.4134
N0160 Z0.7031 [.9'' plasma rapid minus 5mm z axis offset]
N0170 M08 [plate marker on]
N0180 G04 P1
N0190 G01 X2.0000 F50
N0200 M09 [plate marker off]
N0210 G04 P0.5
N0220 G00 X0.0000 Y2.9134
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0260 G00 Z0.1968 [z axis dives here, no idea why. scribe is still on, i manually put 0.9 here and enter M09 to turn off scribe]
N0270 X0.0000 Y0.0000 Z0.3937
N0280 M05 M30
(z offset -5)
if i enter over -14mm in z axis offset line N0260 goes negative and torch crashes
i currently have -16.73 mm z offset with the scribe, i edit gcode line N0260 G00 Z0.9 M09
still don't understand why line N0140 and N0270 are set at Z0.3937
__._,_.___
Visit Your Group
__,_._,___
N0050 G53 G90 G40
N0060 F1
N0110 G92 Z0.0
N0130 G92 Z0.0
N0150 Y3.4134
N0180 G04 P1
N0210 G04 P0.5
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0280 M05 M30
(z offset -5)
__._,_.___
Visit Your Group
__,_._,___
scriber post
Could you send me the job file so I can test this with all of the same settings you are using.
On 15/12/2014 22:28, K Ohlgren kohlgren@gmail.com (kohlgren@gmail.com) [sheetcam] wrote:
__._,_.___
Visit Your Group
__,_._,___
N0050 G53 G90 G40
N0060 F1
N0110 G92 Z0.0
N0130 G92 Z0.0
N0150 Y3.4134
N0180 G04 P1
N0210 G04 P0.5
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0280 M05 M30
(z offset -5)
__._,_.___
Visit Your Group
__,_._,___
scriber post
les; when you said send the job file i decided to see what was in the job file. in the job options the rapid clearance was set to .3937 this was causing the -z travel. color me embarrassed and thank you for your help
__._,_.___
Visit Your Group
__,_._,___
__._,_.___
Visit Your Group
__,_._,___
