Rotary milling, like rotarty plazma
Posted: Sun Nov 30, 2014 1:42 pm
by 80gus
Rotary milling is something i want to get into, is it possible to do if i buy the rotary plugin, if done a bit or research and come up with nothing.
Posted: Sun Nov 30, 2014 1:52 pm
I can't think of any real reason why you can't do this. I don't currently have a rotary milling post but it wouldn't be a major job to write one. Do you want to just mill round tube or rectangular as well?
Posted: Sun Nov 30, 2014 1:54 pm
by 80gus
Les Newell wrote:I can't think of any real reason why you can't do this. I don't currently have a rotary milling post but it wouldn't be a major job to write one. Do you want to just mill round tube or rectangular as well?
Both, mainly for engraving at this stage or splining axles, i just was hesitant on buying it with out seeing it work first
Posted: Sun Nov 30, 2014 1:57 pm
I can send you a free 30 day license for the plugin. I'll also look into making a post for you. I won't be back in the office until Tuesday but I should be able to look into it then.
Posted: Sun Nov 30, 2014 2:23 pm
by 80gus
Les Newell wrote:I can send you a free 30 day license for the plugin. I'll also look into making a post for you. I won't be back in the office until Tuesday but I should be able to look into it then.
Thanks Les i sent you a PM
Posted: Sun Nov 30, 2014 2:50 pm
by ArchieF
Hi Les ,
asked you some time ago :
http://forum.sheetcam.com/viewtopic.php?t=6448
Would you sent me a free 30 day license for the plugin,too ?:D
Richard
Posted: Sun Nov 30, 2014 7:20 pm
Hi Richard,
So you did. I'll PM you with a license.
Posted: Mon Dec 01, 2014 4:15 am
by ArchieF
Les I get this message :
Plugin failed to load : Plugin is unlicensed
Richard
Posted: Mon Dec 01, 2014 10:44 am
Hmm, I'll try sending you another.
Posted: Mon Dec 01, 2014 5:15 pm
by ArchieF
This one works fine (has one letter more)
Thanks Les
Posted: Wed Dec 03, 2014 12:51 pm
I have attached a post for milling with a rotary 4th axis using the rotary plasma plugin. It should work with both round and rectangular tube.
In RotaryPlasma simulation mode click on the setup button then select the 'mill' machine type.
Posted: Wed Dec 03, 2014 6:19 pm
by ArchieF
Works fine here !
Thanks Les
Richard
Posted: Thu Dec 11, 2014 8:05 am
by whirlwind17
So does it mean, already solved?
_______________
Any idea concerning illegal nunchucks
Posted: Sun Sep 13, 2015 10:11 am
by jacala
Hello Les,
this is probably a good start for my 4th axis milling.
Could you send me a test license for rotary plugin so I can test if it works for my usage?
I've already posted a new topic about it before I saw this and I think that it would work but ofcourse: lets test it!
First post asking about it:
http://forum.sheetcam.com/viewtopic.php?t=6716
thanks!
Jacala
