Newbie to Sheet cam
Newbie to Sheet cam
Ok, I'm new to this. I got my machine going today, but is does not seem to be calibrated correctly. I laid out a 60" x 120" sheet on my plasma table, pulled up my part in mach 3, told it to cut, it is at least 6" from where it should be. I put my torch at the lower left corner, zeroed everything, told it to cut, and it is off about 6" from where it should be. SO? my question is: is that something I can fix? and is it in Sheet cam or Mach 3?
Is your part at 0,0 in Sheetcam? Quite often when I load a dxf file into Sheetcam, it is nowhere close to 0,0. You can easily move the part around in Sheetcam by using the nesting button. I draw my parts in Coreldraw, and if I forget to put it at 0,0 there, then that causes it to not be at 0,0 in Sheetcam.
If that's not the problem, you might look at your machine and job options to see where you have you origin set to.
Hope this helps some, Steve
