Hello!
For some reason sheetcam does not set the RPM setting right for the V carve module.
for some reason it is always S1000 instead of the S24000 that I want to work with.
See attachments for the problem.
another V carve problem:
When I array a part with normal operations (pocket, drill etc) everything is fine, when I array a part with a V-carve operation the V carve is not copied to the array.
Hoping to hear from somebody for the solution! See attachment for more info and G code. My settings wrong or just a error in sheetcam?
Jacala.
V carve RPM and array error
link to gcode file:
http://speedy.sh/TZPjG/no-V-carve-in-ar ... pindle.tap
link to setting screenshot±
http://speedy.sh/s56bR/settings.png
Very good news
2014-10-21 9:36 GMT-03:00 Les Newell <forumadmin@forum.sheetcam.com (forumadmin@forum.sheetcam.com)>:
I found the problem. I'll release an update shortly.
