Tidy up the toolbox?
Posted: Fri Aug 15, 2014 6:39 am
by Davek0974
I am using sheetcam on a small plasma table and already have 20+ tools in the default box.
Is there a way we could have maybe a tabbed toolbox that we can easily add tabs at will, give them a name and drop tools into??
That way we could group tools by metal thickness or torch tip type etc.
Posted: Fri Aug 15, 2014 10:20 am
That is an interesting idea. I'll look into it.
Posted: Fri Aug 15, 2014 2:17 pm
by Davek0974
Brilliant, I think it would be a worthwhile addition.
dave
Posted: Sat Aug 16, 2014 10:11 pm
by SeanP
Mine is't as tidy as it could be but I found it does help if you get the tool numbering spaced out more, ie: say I want to add another tool for 6mm I would number it 61 and that adds it in the right order.
Posted: Wed Apr 29, 2015 12:45 am
by aeviaanah
Sean P. How do you create a tool list like this?
Do you create a bunch of tools and save as a template? Load that template prior to starting a job?
Posted: Wed Apr 29, 2015 8:10 am
by SeanP
aeviaanah wrote:Sean P. How do you create a tool list like this?
It's only a screenshot from the tools table editor.
It's just made up from adding tools using that numbering order.
Sean
Posted: Wed Apr 29, 2015 11:16 am
You can save tool sets for later use using 'File->save toolset as'.
Posted: Tue May 05, 2015 4:51 pm
by Vmax549
I have been playing with Plugins and created a master tool set function. You can also sort by tool Number OR Diameter.
Posted: Tue May 05, 2015 6:08 pm
by ChrisAttebery
Vmax,
That sounds interesting. Care to share it with us?
Chris
Posted: Tue May 05, 2015 10:15 pm
by Vmax549
Not a problem BUT I need to wait for Les to fix a couple of things first in Scam. Hopefully next update.
(;-) TP
