V carve module for sheetcam
I'm a happy sheetcam user and quite impressed with the help I got earlier when I had questions.
I've bought a chinese cnc router with a dsp and I can use sheetcam to make 2.5d parts with it. (machine is still in transport btw)
Now i want to extend my possibilities and play around with v carve.
I've noticed the v carving module but i would like a bit of information how it works,
Can I carve stuff like photos etc?
what file format does the v carve module need to work with?
I have cad experience but very little cam experience.
Anyone that could give some user experience or manual is much appreciated.
The v carve module doesn't handle bitmap pictures. It varies the depth depending on the width of the shape being cut. This video demonstrates how V carving works, though I don't think it is using SheetCam to generate the tool paths. http://www.youtube.com/watch?v=Vy3jepTR6Kk
Hello Les,
Thanks for the information! Sounds like a easy to use piece of software. Just to check: https://www.youtube.com/watch?v=o6-W54jUdFA This is possible with your v carve tool?
When the machine arrives I'll start playing around with it and then buy the v carve tool. Can I find a manual or something to learn a bit about it?
Are there other users working with the RZNC-0501 DSP controller and sheetcam? It is a simple router so it should be not that difficult to control but I'm no expert.
There is more information about this DSP controller and the G code it uses:
http://www.cnczone.com/forums/chinese-m ... c0501.html
Are most routers controlled by a generic post processor? That sounds logical to me: basically they all have yxz and spindle on/off.
Of course I'm not hindered by any knowledge so I would love to learn
MMM,
Nobody using V-Carve? I can't find a good topic about the v carve plug in. I know 30 dollar is cheap and sheetcam is really good but when i can't find something like a manual or more information about the plug in than i'm not sure wat the best option is.
What I can find about the V carve plug in is that there is some difficulty with following the right line.
Are these problems solved since it is added as a optional plug-in that you must buy?
hoping to hear some info from a user. Thanks!
Hello!
https://www.youtube.com/watch?v=0_RAio8 ... e=youtu.be
Short video when i'm using the V carve plugin for the second time.
Looks good, now wait for my cnc router
