Thanks Les, I will do that.
Regards
Marius
http://www.cnccontrol.co.za
http://www.mastercut.co.za
On Sunday, June 8, 2014 12:32 PM, "Les Newell
les.newell@fastmail.co.uk [sheetcam]" <
sheetcam@yahoogroups.com> wrote:
Hi Marius, Start with a normal milling/routing post. For example if you are using Mach3, use the Mach3 post. Edit the post and look for lines like this: post.ModalNumber (" X", endX * scale, "0.0000") Immediately after those lines add this: post.ModalNumber (" A", endX * scale, "0.0000") Do the same for the B axis and Y. You can't use arcs with A and B axes so look for function OnArc(). Delete the whole function and replace it with: function OnArc() post.ArcAsMoves(0.1) end This will break arcs into short line segments. In the longer term I would like to extend the wire cutting plugin to handle dual axes and tapers but that involves some significant internal changes to SheetCam and I'm not sure how to implement them at the moment. Les On 07/06/14 12:04, Marius Liebenberg
marius.liebenberg@yahoo.com (
marius.liebenberg@yahoo.com) [sheetcam] wrote:
#yiv7470114652 #yiv7470114652 -- #yiv7470114652ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #yiv7470114652 #yiv7470114652ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv7470114652 #yiv7470114652ygrp-mkp #yiv7470114652hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv7470114652 #yiv7470114652ygrp-mkp #yiv7470114652ads { margin-bottom:10px;} #yiv7470114652 #yiv7470114652ygrp-mkp .yiv7470114652ad { padding:0 0;} #yiv7470114652 #yiv7470114652ygrp-mkp .yiv7470114652ad p { margin:0;} #yiv7470114652 #yiv7470114652ygrp-mkp .yiv7470114652ad a { color:#0000ff;text-decoration:none;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ygrp-lc { font-family:Arial;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ygrp-lc #yiv7470114652hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ygrp-lc .yiv7470114652ad { margin-bottom:10px;padding:0 0;} #yiv7470114652 #yiv7470114652actions { font-family:Verdana;font-size:11px;padding:10px 0;} #yiv7470114652 #yiv7470114652activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #yiv7470114652 #yiv7470114652activity span { font-weight:700;} #yiv7470114652 #yiv7470114652activity span:first-child { text-transform:uppercase;} #yiv7470114652 #yiv7470114652activity span a { color:#5085b6;text-decoration:none;} #yiv7470114652 #yiv7470114652activity span span { color:#ff7900;} #yiv7470114652 #yiv7470114652activity span .yiv7470114652underline { text-decoration:underline;} #yiv7470114652 .yiv7470114652attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #yiv7470114652 .yiv7470114652attach div a { text-decoration:none;} #yiv7470114652 .yiv7470114652attach img { border:none;padding-right:5px;} #yiv7470114652 .yiv7470114652attach label { display:block;margin-bottom:5px;} #yiv7470114652 .yiv7470114652attach label a { text-decoration:none;} #yiv7470114652 blockquote { margin:0 0 0 4px;} #yiv7470114652 .yiv7470114652bold { font-family:Arial;font-size:13px;font-weight:700;} #yiv7470114652 .yiv7470114652bold a { text-decoration:none;} #yiv7470114652 dd.yiv7470114652last p a { font-family:Verdana;font-weight:700;} #yiv7470114652 dd.yiv7470114652last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #yiv7470114652 dd.yiv7470114652last p span.yiv7470114652yshortcuts { margin-right:0;} #yiv7470114652 div.yiv7470114652attach-table div div a { text-decoration:none;} #yiv7470114652 div.yiv7470114652attach-table { width:400px;} #yiv7470114652 div.yiv7470114652file-title a, #yiv7470114652 div.yiv7470114652file-title a:active, #yiv7470114652 div.yiv7470114652file-title a:hover, #yiv7470114652 div.yiv7470114652file-title a:visited { text-decoration:none;} #yiv7470114652 div.yiv7470114652photo-title a, #yiv7470114652 div.yiv7470114652photo-title a:active, #yiv7470114652 div.yiv7470114652photo-title a:hover, #yiv7470114652 div.yiv7470114652photo-title a:visited { text-decoration:none;} #yiv7470114652 div#yiv7470114652ygrp-mlmsg #yiv7470114652ygrp-msg p a span.yiv7470114652yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #yiv7470114652 .yiv7470114652green { color:#628c2a;} #yiv7470114652 .yiv7470114652MsoNormal { margin:0 0 0 0;} #yiv7470114652 o { font-size:0;} #yiv7470114652 #yiv7470114652photos div { float:left;width:72px;} #yiv7470114652 #yiv7470114652photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv7470114652 #yiv7470114652photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv7470114652 #yiv7470114652reco-category { font-size:77%;} #yiv7470114652 #yiv7470114652reco-desc { font-size:77%;} #yiv7470114652 .yiv7470114652replbq { margin:4px;} #yiv7470114652 #yiv7470114652ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv7470114652 #yiv7470114652ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #yiv7470114652 #yiv7470114652ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv7470114652 #yiv7470114652ygrp-mlmsg select, #yiv7470114652 input, #yiv7470114652 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #yiv7470114652 #yiv7470114652ygrp-mlmsg pre, #yiv7470114652 code { font:115% monospace;} #yiv7470114652 #yiv7470114652ygrp-mlmsg * { line-height:1.22em;} #yiv7470114652 #yiv7470114652ygrp-mlmsg #yiv7470114652logo { padding-bottom:10px;} #yiv7470114652 #yiv7470114652ygrp-msg p a { font-family:Verdana;} #yiv7470114652 #yiv7470114652ygrp-msg p#yiv7470114652attach-count span { color:#1E66AE;font-weight:700;} #yiv7470114652 #yiv7470114652ygrp-reco #yiv7470114652reco-head { color:#ff7900;font-weight:700;} #yiv7470114652 #yiv7470114652ygrp-reco { margin-bottom:20px;padding:0px;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ov li a { font-size:130%;text-decoration:none;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv7470114652 #yiv7470114652ygrp-sponsor #yiv7470114652ov ul { margin:0;padding:0 0 0 8px;} #yiv7470114652 #yiv7470114652ygrp-text { font-family:Georgia;} #yiv7470114652 #yiv7470114652ygrp-text p { margin:0 0 1em 0;} #yiv7470114652 #yiv7470114652ygrp-text tt { font-size:120%;} #yiv7470114652 #yiv7470114652ygrp-vital ul li:last-child { border-right:none !important; } #yiv7470114652
__._,_.___
Posted by: Marius Liebenberg <
marius.liebenberg@yahoo.com>
Visit Your Group
Unsubscribe ([email]
sheetcam-unsubscribe@yahoogroups.com?subject=Unsubscribe[/email]) •
Terms of Use
__,_._,___
