No Gcode
No Gcode
I am trying to run the post processor and Sheetcam says the code is saved, I can see the file but it's empty. I tried to open it in a code editor and there's nothing there. What's going on? Worked perfect yesterday. I didn't change any settings. Using version 6.1.4.
Brian's iPhone
Posted by: Brian Martin <bmm@agapemail.com>
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
Brian's iPhone
Yahoo Groups Links
No Gcode
Hi Brian,
Did you get any error messages? In SheetCam make sure View->code editor
is turned on then run the post. Do you see any code in the code editor?
On 24/05/2014 18:48, Brian Martin bmm@agapemail.com [sheetcam] wrote:
Yahoo Groups Links
Brian's iPhone
Yahoo Groups Links
No Gcode
Thanks Les, I just tried it with Post Editor turned on (I've never had this on in the past either) and get the same results. I load the file in Mach3 or "Predator CNC Editor"and both show a blank page, the file is completely empty as far as I can tell.
Brian's iPhone
On May 24, 2014, at 2:01 PM, "Les Newell les.newell@fastmail.co.uk (les.newell@fastmail.co.uk) [sheetcam]" <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Hi Brian,
On 24/05/2014 18:48, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:I am trying to run the post processor and Sheetcam says the code is saved, I can see the file but it's empty. I tried to open it in a code editor and there's nothing there. What's going on? Worked perfect yesterday. I didn't change any settings. Using version 6.1.4.
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
Also not showing any errors!
Brian's iPhone
On May 24, 2014, at 2:15 PM, "Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam]" <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Brian's iPhone
Hi Brian,
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
What post processor are you using? Do you have any cuts set up? What happens if you run the simulator?
On 24/05/14 19:15, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:
__._,_.___
Visit Your Group
__,_._,___
Thanks Les, I just tried it with Post Editor turned on (I've never had this on in the past either) and get the same results. I load the file in Mach3 or "Predator CNC Editor"and both show a blank page, the file is completely empty as far as I can tell.Â
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
Ok I looked at it some more and it has the code in the Sheetcam code editor. Simulation works as expected. It just doesn't post the code when I run the processor.
Brian's iPhone
On May 24, 2014, at 4:28 PM, "Les Newell les.newell@fastmail.co.uk (les.newell@fastmail.co.uk) [sheetcam]" <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
I'm using the "Mach3 THC with scriber" post.
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
If you are seeing the code in the code editor then SheetCam is creating the G-code file. The code editor reads the file after SheetCam has saved it. Are you sure you are looking at the right file?
On 24/05/14 22:04, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:
__._,_.___
Visit Your Group
__,_._,___
Ok I looked at it some more and it has the code in the Sheetcam code editor. Simulation works as expected. It just doesn't post the code when I run the processor.Â
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
I can see the code inside Sheetcam in the editor. But after I actually post the code and try to see it in another code editor or M3 it's blank. It's just not posting it up. I've tried several different parts and jobs and get the same results. I've been using this for 3 months and never had a problem with Sheetcam. Did you put out an update yesterday? I haven't used it since noon Friday.
Brian's iPhone
On May 24, 2014, at 5:31 PM, "Les Newell les.newell@fastmail.co.uk (les.newell@fastmail.co.uk) [sheetcam]" <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
I don't understand this. The editor is pretty much independent from the rest of SheetCam. After running the post SheetCam tells the editor to load the file that has just been saved. If you can see the code in the editor the file must be ok.
On 24/05/14 22:59, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:
__._,_.___
Visit Your Group
__,_._,___
I can see the code inside Sheetcam in the editor. But after I actually post the code and try to see it in another code editor or M3 it's blank. It's just not posting it up. I've tried several different parts and jobs and get the same results. I've been using this for 3 months and never had a problem with Sheetcam. Did you put out an update yesterday? I haven't used it since noon Friday.Â
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
No Gcode
I have been following this thread and out of curiosity, are you really saving the file to the location that your opening the file from???
Sounds like your opening a file in path "x" when the file is actually saved in path "Y"?
Just a thought
Art
Country Bubba
At 07:09 PM 5/24/2014, you wrote:
__._,_.___
Posted by: Art Eckstein <art.eckstein@gmail.com>
Visit Your Group
__,_._,___
Just a thought
Art
Country Bubba
On 24/05/14 22:59, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:I can see the code inside Sheetcam in the editor. But after I actually post the code and try to see it in another code editor or M3 it's blank. It's just not posting it up. I've tried several different parts and jobs and get the same results. I've been using this for 3 months and never had a problem with Sheetcam. Did you put out an update yesterday? I haven't used it since noon Friday.Â
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
- !3a-)_Happy.png (776 Bytes) Viewed 6555 times
Country Bubba
No Gcode
Problem solved! Sheetcam was misinterpreting my part names and when it posted the code it was inserting a dash(-) in the comment line. Mach3 and Predator will not recognize the - symbol in a comment/ job name line, so I just got a blank page then. Lesson learned.
Brian's iPhone
On May 24, 2014, at 7:13 PM, "Art Eckstein art.eckstein@gmail.com (art.eckstein@gmail.com) [sheetcam]" <sheetcam@yahoogroups.com (sheetcam@yahoogroups.com)> wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
Just a thought
Art
Country Bubba
Brian's iPhone <!3a-) Happy.png>
__._,_.___
Visit Your Group
__,_._,___
No Gcode
That's different. Could you send me one of the problem job files or g-code files. I'll take a look and see if I can work around the problemm.
On 25/05/14 02:36, Brian Martin bmm@agapemail.com (bmm@agapemail.com) [sheetcam] wrote:
__._,_.___
Visit Your Group
__,_._,___
Brian's iPhone
__._,_.___
Visit Your Group
__,_._,___
