SheetCam TNG development V6.1.4 released for Windows and Lin
Posted: Tue May 06, 2014 6:40 pm
Hi all,
I have just uploaded Dev V6.1.4 to www.sheetcam.com. This release has
teh following changes:
Fixed: Lua editor not opening files correctly when a Lua script throws
an error
Fixed: Path rules sometimes not outputting a acrriage return at the end
of the line
Changed: lots of changes for Linux compatibility
Fixed: Sometimes need to click twice on part check box to enable/disable
the part
Changed: On start path rule text was ambiguous
Fixed: Multiple duplicate would place a part if you click middle-mouse
key or <shift>+left mouse key
Fixed: post editor tried saving to program files
Fixed: Perpendicular and tangent leadouts on open contours incorrect.
Fixed: A number of intermittent crashes
Fixed: Missing pipe wall thickness graphic
Fixed: Arc leadin/leaouts sometimes not being generated when they should be.
Fixed: Editing a post causes the post processor to stop working or thow
odd errors.
Fixed: Sim whowing incorrrect Z height when the post is set to 'top of
table' or 'top of spoil board'
Added: Compression in text plugin
Added: In tab edit mode the delete key deletes tabs
The Linux version is available in both 32 bit and 64 bit versions and
should run on most Linux distros.
Yahoo Groups Links
<*> Your email settings:
(Yahoo! ID required)
an error
of the line
the part
odd errors.
Yahoo Groups Links
