What all do i need to do to get a scribe up and going as far as in sheetcam? I have it hooked up to the Flood M8 Relay currently (may switch it to another output sometime) and can activate it in mach.
I see many say use the MP1000 scribe post, but i am currently using the THC300, do i need to do anything to "Merge" the 2, or copy and paste certain sections. I dont understand the post language very much.
The scribe is attached to my Plasma Z axis and when engaged, it will be 1/2" to 3/4"" lower than the plasma tip, and then I will use the z axis to raise it approx 1/4" - 1/2" between lines, leaving the scribe running, to make it faster, and instead of constantly turning the relay on and off, unless the engraving is far apart (any way to setup a distance for this automatically, like there is for floating head switch reference?), and the plan is when i need to scribe, it will go to the path start with the plasma torch at Z 1", and fire the relay and then lower the scribe to the plate, or .25" below, relying on the cylinder pressure. Which all may be fine tuned.
I need to add the scribe tool, 201 maybe?, and then figure out how to add it into the post, and make it fire the relay when that tool is selected and it needs to engage.
This may be a simple thing for you guys, and im hoping you can save me some grief.
Brian
Scribe Setup and Post with THC300
THC300 Post
Here is the Current THC300 Post, I would like some help determining the important settings that I would need to use in a different post, or understanding some things more.
function OnAbout(event)
ctrl = event:GetTextCtrl()
ctrl:AppendText("plasma THC300 post processor\n")
ctrl:AppendText("\n")
ctrl:AppendText("M03/M05 turn the torch on/off\n")
ctrl:AppendText("Incremental IJ\n")
ctrl:AppendText("The torch is referenced at cut start and every 500mm of movement thereafter\n")
ctrl:AppendText("Designed for use with Mach2 and Campbell Designs THC300\n")
ctrl:AppendText("Post variables:\n")
ctrl:AppendText("refdistance - set the distance between each reference\n")
-- revision 3/2/07
-- Removed final safety move. This is now done in SheetCam
-- revision 7/10/05
-- Added new arc handling
-- created 27/10/04
-- Based on plasma1.post
function OnInit()
if(scale == metric) then
else
post.Text (" G53 G90 G40\n F1\n S500\n")
dist = 9999999
refdistance = 500 * scale
switchoffset = .0511
function OnNewLine()
post.Text ("N")
lineNumber = lineNumber + 10
function OnFinish()
post.Text (" M05 M30\n")
function OnRapid()
if(endZ < currentZ) then return end
dist = dist + math.hypot(endX-currentX , endY-currentY)
post.ModalText (" G00")
post.Eol()
function OnMove()
post.ModalText (" G01")
post.ModalNumber (" F", feedRate * scale, "0.###")
post.Eol()
function OnArc()
if(arcAngle <0) then
post.ModalText (" G03")
else
post.ModalText (" G02")
post.NonModalNumber (" X", endX * scale, "0.0000")
post.NonModalNumber (" Y", endY * scale, "0.0000")
post.Text (" I")
post.Text (" J")
post.Eol()
function OnPenDown()
if(dist >= (refdistance/scale)) then
dist = 0
post.ModalText(" G28.1 Z")
post.Number(3 * scale, "0.00")
post.Eol()
post.ModalText(" G92 Z0.0\n")
post.ModalNumber(" Z", switchoffset, "0.0000")
post.Eol()
post.CancelModalNumbers()
post.Eol()
if (preheat > 0) then
post.Text ("\n G04 P")
post.Number (preheat,"0.###")
post.Eol()
post.Text ("\n M03\n")
if (pierceDelay > 0) then
post.Text (" G04 P")
post.Number (pierceDelay,"0.###")
post.Eol()
function OnPenUp()
post.Text (" M05\n")
if (endDelay > 0) then
post.Eol()
function OnNewOperation()
post.Text (" (Process: ", processname, ")\n")
if (plungeRate <= 0) then
post.Warning("WARNING: Plunge rate is zero")
if (feedRate <= 0) then
post.Warning("WARNING: Feed rate is zero")
function OnComment()
post.Text(" (",commentText,")\n")
function OnToolChange()
post.Text (" M06 T")
post.Number (tool, "0")
post.Text (" (", toolName, ")\n")
function OnNewPart()
post.Text(" (Part: ",partName,")\n");
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
-- revision 3/2/07
-- revision 7/10/05
-- created 27/10/04
function OnInit()
else
dist = 9999999
post.Text ("N")
function OnFinish()
function OnRapid()
post.Eol()
function OnMove()
post.Eol()
function OnArc()
else
post.Text (" I")
post.Text (" J")
post.Eol()
dist = 0
post.Eol()
post.Eol()
post.Eol()
post.Eol()
post.Eol()
function OnPenUp()
post.Eol()
function OnDrill()
OnRapid()
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
Mp1000 Scriber Post
Here is the scriber post to compare to the THC300
--*** Set these values up to suit your machine ***
--this is the distance between each torch reference in MILLIMETRES
refDistance = 250
--this is the reference feed rate in mm/min
refFeed = 500
--Put your switch offset value here in MILLIMETRES
switchOffset = 1.5
--Scriber X,Y,Z offsets in MILLIMETRES. Do not use inches here even if you want inch code
--Use the special code 'nil' on the Z axis to disable it.
--In that case no Z values will be output at all while scribing.
--e.g scriberZ = nil
scriberX = 110
scriberY = 220
scriberZ = 0
--scriber axis. Leave this as nil if the scriber is fixed to the same axis as the torch
--scriberAxis = "A"
scriberAxis = nil
--If this value is set to true then use G28 (home) for the Z reference
--Set it to false for G31 probe
refHome = true
--The cutter will slow down for corners and turn off THC below this radius
slowRadius = 10
--Minimum slow down speed.
--This is a scale factor. For instance 0.5 = 50% of the current feed rate
slowPercent = 0.4
--THC on and off codes. Use nil if you don't want THC control e.g:
-- thcOnCode = nil
-- thcOffCode = nil
--here is another example that use M667 and M666
--thcOnCode = " M667"
--thcOffCode = " M666"
thcOnCode = nil
thcOffCode = nil
--*** End of settings ***
ctrl:AppendText("plasma MP1000-THC post processor with engraver\n")
ctrl:AppendText("M08/M09 turn the engraver on/off\n")
ctrl:AppendText("Incremental IJ - set in mach2\n")
ctrl:AppendText("Designed for use with Mach3 and CandCNC MP1000-THC and Floating head Touch-n-Go\n")
ctrl:AppendText("refDistance - set the distance between each reference\n")
ctrl:AppendText("refFeed - set the feed rate when referencing\n")
ctrl:AppendText("switchOffset - set your net switch offset amount \n")
ctrl:AppendText("Scriber uses any tool number\n")
ctrl:AppendText("slowRadius - slow down below this radius\n")
ctrl:AppendText("slowPercent - minimum percentage to slow down\n")
-- created 1/1/06
-- Modified 21/6/2010
-- added option for 'nil' plate marker z
-- Added support for plate marker tool type as well as tool number based plate marker
-- Modified 4/11/2010
-- Added: Reference the torch on the first pen down if the plate marker is the first tool used.
post.DefineVariable("refDistance",sc.unitLINEAR,0,1e17)
post.DefineVariable("refFeed",sc.unitFEED,0,1e17)
post.DefineVariable("switchOffset",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowRadius",sc.unitLINEAR,-1e17,1e17)
post.DefineVariable("slowPercent",sc.unitPERCENT,-1e17,1e17)
function OnInit()
offX = 0
offY = 0
offZ = 0
else
post.Text (" F1\n G53 G90 G40\n")
minArcSize = 0.2 --arcs smaller than this are converted to moves
firstRef = true
currentZAxis = "Z"
dist = 9999999
lastz = 0
thcstate = 1
ThcOff()
post.Text ("N")
function OnFinish()
endZ = safeZ
OnRapid()
endX = 0
endY = 0
offX = 0
offY = 0
offZ = 0
OnRapid()
function OnRapid()
if(endX > 1e17 and endY > 1e17) then return end
local len = math.hypot((endX + offX)-currentX , (endY + offY)-currentY)
dist = dist + len
post.ModalNumber (" X", (endX + offX) * scale, "0.0000")
post.ModalNumber (" Y", (endY + offY) * scale, "0.0000")
if(offZ and firstRef == false and currentZ ~= safeZ) then
post.ModalNumber (" " .. currentZAxis, (endZ + offZ) * scale, "0.0000")
post.Eol()
function OnMove()
local len = math.hypot(endX - currentX , endY - currentY)
dist = dist + len
if(len > slowRadius) then
ThcOn()
if(offZ) then
post.Eol()
function OnArc()
local radius = math.hypot(currentX - arcCentreX, currentY - arcCentreY)
dist = dist + radius * math.abs(arcAngle)
if (radius < slowRadius) and (math.abs(arcAngle) > 0.5) then
feed = (radius / slowRadius)
if(feed < slowPercent) then
feed = slowPercent
feed = feed * feedRate
ThcOff()
else
feed = feedRate
ThcOn()
else
if(offZ) then
post.Text (" I")
post.Text (" J")
post.ModalNumber (" F", feed * scale, "0.0###")
post.Eol()
function ThcOff()
if(not thcOffCode) then return end
if(thcstate ==1) then
thcstate = 0
post.Text(thcOffCode)
post.Text(" (THC off)\n");
function ThcOn()
if(not thcOnCode) then return end
if(toolClass == "MarkerTool") or tool > 99 then return end
if(thcstate ==0) then
thcstate = 1
post.Text(thcOnCode)
post.Text(" (THC on)\n");
return
if(thcstate == 2) then
thcstate = 0
if (firstRef) then
Reference()
post.Text(" Z")
post.Number (safeZ * scale, "0.0000")
post.Eol()
offX = scriberX
offY = scriberY
offZ = scriberZ
post.ModalNumber (" X", (currentX + offX) * scale, "0.0000")
post.ModalNumber (" Y", (currentY + offY) * scale, "0.0000")
post.Eol()
if (offZ) then
post.ModalNumber (" " .. currentZAxis, (currentZ + offZ) * scale, "0.0000")
post.Eol()
post.Text(" M08\n")
else
if(dist >= refDistance) then
dist = 0
Reference();
post.Text(" Z")
post.Number (pierceHeight * scale, "0.0000")
post.Eol()
post.Eol()
post.Eol()
-- thcstate = 2 --leave THC off for plunge move
function Reference()
firstRef = false
if (refHome) then
else
post.ModalText(" G31 Z -100")
post.ModalNumber (" F", refFeed * scale, "0.0###")
post.Eol()
post.Text(" Z")
post.Number (switchOffset * scale, "0.0000")
post.Eol()
function OnPenUp()
if(tool > 99) then
post.Text(" M09\n")
else
post.Eol()
post.Text (" (Operation: ", operationName, ")\n")
if (toolClass == "MarkerTool" or tool > 99 ) then
ThcOff()
if(scriberAxis and scriberAxis ~= currentZAxis) then
endZ = safeZ
OnRapid()
currentZAxis = scriberAxis
if(firstRef ~= true) then
offX = scriberX
offY = scriberY
offZ = scriberZ
else
if(scriberAxis and scriberAxis == currentZAxis) then
endZ = safeZ
OnRapid()
currentZAxis = "Z"
offX = 0
offY = 0
offZ = 0
function OnDrill()
OnRapid()
currentX = endX
currentY = endY
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
refDistance = 250
refFeed = 500
switchOffset = 1.5
scriberX = 110
scriberY = 220
scriberZ = 0
--scriberAxis = "A"
scriberAxis = nil
refHome = true
slowRadius = 10
slowPercent = 0.4
-- thcOnCode = nil
-- thcOffCode = nil
thcOnCode = nil
thcOffCode = nil
-- created 1/1/06
function OnInit()
offX = 0
offY = 0
offZ = 0
else
firstRef = true
currentZAxis = "Z"
dist = 9999999
lastz = 0
thcstate = 1
ThcOff()
post.Text ("N")
function OnFinish()
endZ = safeZ
OnRapid()
endX = 0
endY = 0
offX = 0
offY = 0
offZ = 0
OnRapid()
function OnRapid()
dist = dist + len
post.Eol()
function OnMove()
dist = dist + len
ThcOn()
if(offZ) then
post.Eol()
function OnArc()
feed = slowPercent
ThcOff()
else
feed = feedRate
ThcOn()
else
if(offZ) then
post.Text (" I")
post.Text (" J")
post.Eol()
function ThcOff()
thcstate = 0
function ThcOn()
thcstate = 1
return
thcstate = 0
if (firstRef) then
Reference()
post.Text(" Z")
post.Eol()
offX = scriberX
offY = scriberY
offZ = scriberZ
post.Eol()
if (offZ) then
post.Eol()
post.Text(" M08\n")
else
dist = 0
Reference();
post.Text(" Z")
post.Eol()
post.Eol()
post.Eol()
firstRef = false
if (refHome) then
else
post.Eol()
post.Text(" Z")
post.Eol()
function OnPenUp()
if(tool > 99) then
post.Text(" M09\n")
else
post.Eol()
ThcOff()
endZ = safeZ
OnRapid()
offX = scriberX
offY = scriberY
offZ = scriberZ
else
endZ = safeZ
OnRapid()
currentZAxis = "Z"
offX = 0
offY = 0
offZ = 0
function OnDrill()
OnRapid()
currentX = endX
currentY = endY
OnPenDown()
endZ = drillZ
OnMove()
OnPenUp()
endZ = safeZ
OnRapid()
Ok, i will try that. Is the MP1000 newly updated to use the new rules and settings that are in sheetcam now instead of being in the post (like on small arcs, do etc or will any of them contradict each other? Also, can the MP1000 Scriber post be changed to mm were it says mm only, by adding the * scale code, and any other corresponding areas?
I will probably have a few more questions, but I will try it and google what i can before posting more. I wondered if i could just switch, but i was unsure if there was something important in the THC300 post for the THC301d that i am using that i needed to be sure to merge into it.
Thanks Les, much appreciated.
Brian
Brian
Just leave the THC on and off codes set to nil and set slowRadus to 0. That will disable the post's slowdown stuff.Wolfes Metal Fab wrote:Ok, i will try that. Is the MP1000 newly updated to use the new rules and settings that are in sheetcam now instead of being in the post (like on small arcs, do etc or will any of them contradict each other?
All posts use mm internally. The g-code units are set in Options->machine->post processor.Also, can the MP1000 Scriber post be changed to mm were it says mm only, by adding the * scale code, and any other corresponding areas?
Yes, i am aware of the g-code inch settings, my THC300 post actually used the *scale feature to use inch input for switch offsets, etc. Its not a big deal, as i can convert them, but its nice to look at a sheet of information and be able to change it quickly and easily notice any errors, say if you wanted to change the z reference distance to every cut just for a certain sheet, and then every 12" for another and so on. I was debating trying to copy the THC300 posts *scale part of the post to add inch input for the mp1000, but i will probably just try to make sure everything is working first, if i attempt that. But if its a pain, like I said, no big deal.Les Newell wrote:All posts use mm internally. The g-code units are set in Options->machine->post processor.
Brian
