Post confusion
Post confusion
I am trying to figure out why my post is sprinkling THC on/off codes in my output.
Here's the code
N0070 M10 (THC off)
N0080 (Part: 65mm Square Circledxf)
N0090 (Operation: Inside Offset, Circle, T1: 2mm Steel, 25A, Std Tip)
N0100 G00 X32.5000 Y22.8750
N0110 G28.1 Z3.00 F250.0
N0120 G92 Z0.0
N0130 G00 Z4.6500
N0140 G92 Z0.0
N0150 G00 Z4.0000
N0160 M03
N0170 G04 P0.1
N0180 G01 Z1.0000 F800.0
N0190 M10 (THC Off)
N0200 M11 (THC on)
N0210 Y7.8750 F960.0
N0220 G03 I0.0000 J24.6250
N0230 M11 (THC On)
N0240 (Operation: Outside Offset, 0, T1: 2mm Steel, 25A, Std Tip)
N0250 M05
I have a post rule that says for small circles, slowdown, turn THC off and then on after.
It seems that its turning it off for probing g28.1 but then on for the circle??
Here's the code
N0070 M10 (THC off)
N0120 G92 Z0.0
N0130 G00 Z4.6500
N0140 G92 Z0.0
N0150 G00 Z4.0000
N0160 M03
N0170 G04 P0.1
N0190 M10 (THC Off)
N0200 M11 (THC on)
N0230 M11 (THC On)
N0250 M05
Job file attached and yes i get the codes if i disable the rule.
The rule say circles < 70mm dia reduce to 60% and THC off, at the end its THC on.
The square has loops on the corners.
Dave
Dave
- 65mm Square Circledxf.tap
- (1.19 KiB) Downloaded 130 times
- 65mm Square Circledxf.job
- (5.41 KiB) Downloaded 137 times
Still not quite right - line 190 shows THC off for the circle, but immediately after, line 200 switches it back on??
Also line 70 switches it off ?
Line 230 is correct IMHO.
N0010 (Filename: 65mm Square Circledxf.tap)
N0020 (Post processor: Mach3 THC with scriber-edited.scpost)
N0030 (Date: 16/04/2014)
N0040 G21 (Units: Metric)
N0050 F1
N0060 G53 G90 G40 G64
N0070 M10 (THC off)
N0120 G92 Z0.0
N0130 G00 Z3.9000
N0140 G92 Z0.0
N0150 G00 Z4.0000
N0160 M03
N0170 G04 P0.1
N0190 M10 (THC Off)
N0200 M11 (THC on)
N0210 Y7.8750 F1120.0
N0230 M11 (THC On)
N0250 M05
N0260 G00 Z10.0000
N0270 X68.5750 Y68.2000
N0280 G28.1 Z3.00 F250.0
N0290 G92 Z0.0
N0300 G00 Z3.9000
N0310 G92 Z0.0
N0320 G00 Z4.0000
N0330 M03
N0340 G04 P0.1
N0350 G01 Z1.0000 F800.0
N0360 G03 X65.3750 Y65.0000 I0.0000 J-3.2000 F1600.0
N0370 G01 Y-1.6331
N0380 G03 X66.6331 Y-0.3750 I1.2581 J0.0000
N0390 G01 X-1.6331
N0400 G03 X-0.3750 Y-1.6331 I0.0000 J-1.2581
N0410 G01 Y66.6331
N0420 G03 X-1.6331 Y65.3750 I-1.2581 J0.0000
N0430 G01 X65.0000
N0440 M05
N0450 G00 Z10.0000
N0460 X0.0000 Y0.0000
N0470 M05 M30
N0050 F1
N0070 M10 (THC off)
N0120 G92 Z0.0
N0130 G00 Z3.9000
N0140 G92 Z0.0
N0150 G00 Z4.0000
N0160 M03
N0170 G04 P0.1
N0190 M10 (THC Off)
N0200 M11 (THC on)
N0230 M11 (THC On)
N0250 M05
N0260 G00 Z10.0000
N0290 G92 Z0.0
N0300 G00 Z3.9000
N0310 G92 Z0.0
N0320 G00 Z4.0000
N0330 M03
N0340 G04 P0.1
N0370 G01 Y-1.6331
N0390 G01 X-1.6331
N0410 G01 Y66.6331
N0430 G01 X65.0000
N0440 M05
N0450 G00 Z10.0000
N0470 M05 M30
Is that with the job file you posted here? This is the code I get:
By the way, in the path rules editor turn on 'show rule names in g-code'. It helps you work out which rules are triggering.
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 17/04/2014)
N0040 G20 (Units: Inches)
N0050 F1
N0060 G53 G90 G40
N0070 (Part: 65mm Square Circledxf)
N0080 (Operation: Inside Offset, Circle, T1: Plasma, 0.75 mm kerf)
N0090 G00 X1.2795 Y0.9006
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z0.0591
N0130 G92 Z0.0
N0140 G00 Z0.1575
N0150 M03
N0160 G04 P0.1
N0170 G01 Z0.0394 F31.4961
N0180 M10 (THC Off) On small circles
N0190 Y0.3100 F37.7953
N0200 G03 I0.0000 J0.9695
N0210 M11 (THC On) On small circles
N0220 (Operation: Outside Offset, 0, T1: Plasma, 0.75 mm kerf)
N0230 M05
N0240 G00 Z0.3937
N0250 X2.6998 Y2.6850
N0260 Z0.1575
N0270 M03
N0280 G04 P0.1
N0290 G01 Z0.0394 F31.4961
N0300 G03 X2.5738 Y2.5591 I0.0000 J-0.1260 F25.1969
N0310 G01 Y-0.0643 F62.9921
N0320 G03 X2.6234 Y-0.0148 I0.0495 J0.0000 F25.1969
N0330 G01 X-0.0643 F62.9921
N0340 G03 X-0.0148 Y-0.0643 I0.0000 J-0.0495 F25.1969
N0350 G01 Y2.6234 F62.9921
N0360 G03 X-0.0643 Y2.5738 I-0.0495 J0.0000 F25.1969
N0370 G01 X2.5591 F62.9921
N0380 M05
N0390 G00 Z0.3937
N0400 X0.0000 Y0.0000
N0410 M05 M30
I used a new copy of the POST and now I get this result...
N0020 (Post processor: Mach3 THC with scriber 2.scpost)
N0030 (Date: 22/04/2014)
N0050 F1
N0060 G53 G90 G40
N0070 M11 (THC off)
N0090 (Operation: Inside Offset, Circle, T3: 6.35mm Steel, 30A, Std Tip, 112v)
N0100 G00 X32.5000 Y23.0000
N0110 G28.1 Z3.00 F800.0
N0120 G92 Z0.0
N0130 G00 Z3.9000
N0140 G92 Z0.0
N0150 G00 Z3.5000
N0160 M03
N0170 G04 P0.3
N0180 G01 Z1.0000
N0190 M10 (THC Off) (On small circles)
N0200 M10 (THC on)
N0210 Y8.0000 F490.0
N0220 G03 I0.0000 J24.5000
N0230 X33.9991 Y8.0459 I0.0000 J24.5000
N0240 M11 (THC On) (On small circles)
N0250 (Operation: Outside Offset, 0, T1: 2mm Steel, 30A, Std Tip, 106v)
N0260 M05
N0270 G00 Z10.0000
N0280 G00 X33.9991 Y8.0459
N0290 X68.5750 Y68.2000
N0300 G28.1 Z3.00 F800.0
N0310 G92 Z0.0
N0320 G00 Z3.9000
N0330 G92 Z0.0
N0340 G00 Z3.5000
N0350 M03
N0360 G04 P0.1
N0370 G01 Z1.0000
N0380 G03 X65.3750 Y65.0000 I0.0000 J-3.2000 F1600.0
N0390 G01 Y-1.6331
N0400 G03 X66.6331 Y-0.3750 I1.2581 J0.0000
N0410 G01 X-1.6331
N0420 G03 X-0.3750 Y-1.6331 I0.0000 J-1.2581
N0430 G01 Y66.6331
N0440 G03 X-1.6331 Y65.3750 I-1.2581 J0.0000
N0450 G01 X65.0000
N0460 M05
N0470 G00 Z10.0000
N0480 X0.0000 Y0.0000
N0490 M05 M30
Still not working
line 190 is kicking it off as per the rules but then line 200 is kicking it straight back on but not from the rule????
N0050 F1
N0060 G53 G90 G40
N0070 M11 (THC off)
N0120 G92 Z0.0
N0130 G00 Z3.9000
N0140 G92 Z0.0
N0150 G00 Z3.5000
N0160 M03
N0170 G04 P0.3
N0180 G01 Z1.0000
N0200 M10 (THC on)
N0260 M05
N0270 G00 Z10.0000
N0310 G92 Z0.0
N0320 G00 Z3.9000
N0330 G92 Z0.0
N0340 G00 Z3.5000
N0350 M03
N0360 G04 P0.1
N0370 G01 Z1.0000
N0390 G01 Y-1.6331
N0410 G01 X-1.6331
N0430 G01 Y66.6331
N0450 G01 X65.0000
N0460 M05
N0470 G00 Z10.0000
N0490 M05 M30
Still not working
