Is there a way I can do something in sheetcam that will cause Mach3 Plasma to stop and wait for user input - pressing the cycle start button again?
Would be useful to insert pauses into my cutting G-code if needed.
Mach is set to stop on tool change and wait for cycle start, but I don't know how to issue a tool change from sheetcam.
Need a pause...
First create a g-code snippet. Click on the G button in the tools window. For the code enter:
M0
Give it a name such as 'wait'
To insert teh wait between operations use the G button in the operations window and select your 'wait' code snippet.
You can also use that snippet on individual start points if you need to.
M0
