In SC 5.0.0 there is a new function called "Edit action points". What happens when such a action point is done?
I can't find any help for this.
Best regards, Dietmar
Edit action points
The help file isn't done yet. Action points allow you to specify a different feed rate over a section of the cut path. Action points are placed like tabs but you can drag the ends of the action points around to set the size. As well as changing the feed rate you can output g-code snippets at the start and end of the action points.
