Hello All, New to Sheetcam and plasma cutting. Have a few questions
1.Reverseing direction keeping same offset ? I'm guessing something simple but just missing it.
2. Modifing art in mastercam 9 then exporting as DXF, when it comes into sheetcam changes are a different layer ? Is there a easy way to change everything to one layer some art has a lot of changes.
Thanks Ray
New Member Few ?'s
Re: New Member Few ?'s
Use the 'Reverse cut direction' box in the basic tab of your cut operation.Ray Phelps wrote:1.Reverseing direction keeping same offset ? I'm guessing something simple but just missing it.
That is fairly easy. Zoom out so you can see the whole drawing. Switch to edit contours mode (the button with a C and an arrow). Move your mouse to one corner of the drawing then hold the left mouse button and drag a box to select the whole drawing. Now right-click and select 'move to layer'2. Modifing art in mastercam 9 then exporting as DXF, when it comes into sheetcam changes are a different layer ? Is there a easy way to change everything to one layer some art has a lot of changes.
