Hi.
I am new to sheetcam.
I have imported a dwg and set up tools, choosen layers and so on. When i import gcode in mach3 all pieces of my drawing are spread from eachother on the z axis.
Is there some way i can align all lines to 0 on z in sheetcam?
If i use lazycam the pieces of my drawing are aligned on the z axis. But in sheetcam z jumps up and down like crazy. It also results in a very very long g-code. I just don't understand why lazycam can make a short code with z aligned while sheetcam can't...
Thanks!
Problem with Z-axis
Code
Here is the job from sheetcam. When i open the code after processing i can see that z is all over the place. Could it be the postprocessor?
- body - bottom.job
- (82.33 KiB) Downloaded 530 times
I think the problem is the tool length offset. Set it to zero and try again.
By the way, I think your first two operations should probably be inside offsets, not outside. If that is the case you could also just stick the whole lot on one layer and tell SheetCam to do an outside offset. It would automatically reverse the cut side and cut the inside shapes first.
z-axis
Hi again, and thanks for the reply.
I tried to set the tool length offset to zero but it gives me the same result. I have attached the g-code, where you can see that z goes crazy.
I simply can't figure this out...
And about the first to operations, i know they're supposed to be inside cut's, but i just generated a job quick for you to see
