Corel outputs everything as splines. G-code cannot use splines so they have to be broken into line segments. When SheetCam imports the splines it breaks them up automatically. How small was the wheel? The smaller the shape, the fewer line segments are used. From you rdescription it is possible you loaded an inch drawing as metric. This would make the drawing very small and result in only a few line segments. -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0583#10583 (http://www.forum.sheetcam.com/viewtopic ... 0583#10583) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0619#10619 (http://www.forum.sheetcam.com/viewtopic ... 0619#10619) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0795#10795
Got my Vista to work with TNG, here\'s how I did it.
