Hi Les, Check these files please. Sheetcam TNG imports them wrongly. I use Autocad2006. I had this problem many times, and decide to write you. Attachments: http://www.forum.sheetcam.com//files/dxf2000_120.rar (http://www.forum.sheetcam.com//files/dxf2000_120.rar) -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0586#10586 (http://www.forum.sheetcam.com/viewtopic ... 0586#10586) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0602#10602 (http://www.forum.sheetcam.com/viewtopic ... 0602#10602) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0603#10603 (http://www.forum.sheetcam.com/viewtopic ... 0603#10603) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0604#10604 (http://www.forum.sheetcam.com/viewtopic ... 0604#10604) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0605#10605 (http://www.forum.sheetcam.com/viewtopic ... 0605#10605) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0606#10606 (http://www.forum.sheetcam.com/viewtopic ... 0606#10606) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0607#10607 (http://www.forum.sheetcam.com/viewtopic ... 0607#10607) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0837#10837
Need to Fix in TNG
Need to Fix in TNG
I normally recommend that you use R12 format where possible. I see the
problem in the other drawings and I'll try to fix it for the next release.
http://www.forum.sheetcam.com/viewtopic ... 0838#10838
Need to Fix in TNG
I use Autocad2006.
http://www.forum.sheetcam.com/viewtopic ... 0840#10840
I use Autocad2006.
Need to Fix in TNG
I analyze this problem myself, and open that when Lwpolyline group codes (230 == -1) TNG sometimes recognize DXF wrongly. Correct DXF plugin please -------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0567#10567 (http://www.forum.sheetcam.com/viewtopic ... 0567#10567) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0583#10583 (http://www.forum.sheetcam.com/viewtopic ... 0583#10583) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0584#10584 (http://www.forum.sheetcam.com/viewtopic ... 0584#10584) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0585#10585 (http://www.forum.sheetcam.com/viewtopic ... 0585#10585) -------------------- m2f --------------------
-------------------- m2f -------------------- Reply to this post simply by hitting reply in your email client or you can read this topic online here: http://www.forum.sheetcam.com/viewtopic ... 0587#10587 (http://www.forum.sheetcam.com/viewtopic ... 0587#10587) -------------------- m2f --------------------
http://www.forum.sheetcam.com/viewtopic ... 0846#10846
Need to Fix in TNG
Thanks. I'll try to fix it for the next release.
http://www.forum.sheetcam.com/viewtopic ... 0847#10847
Need to Fix in TNG
Thanks. I'll look into it. Hopefully I should be able to fix it fro th next release.
http://www.forum.sheetcam.com/viewtopic ... 0848#10848
