Post processor for Deckel FPxNC mill with Dialog (4)?
Does anyone happen to have a post processor for a Deckel mill with Dialog controller?
/Torleif.
http://www.forum.sheetcam.com/viewtopic.php?p=8537#8537
/Torleif.
/Torleif.
/Torleif.
Can you supply a sample of code? I can probably match it to one of the existing posts.
http://www.forum.sheetcam.com/viewtopic.php?p=8538#8538
Thanks Les.
The mill is completely new to me, so I'll have to see what I can find. And I'll do some tests when time permits.
As I understand it, the file needs a certain header and footer to be accepted by the controller. I had hoped that somebody had done this already, so that I would get the file correct from the beginning.
I'll be back.
I'll be back.
Thanks Les.
I'll be back.
http://www.forum.sheetcam.com/viewtopic.php?p=8539#8539
I'll be back.
1) This can get a little complicated. The easy way is to get rid of all line numbers. To do that, simply delete function newline(). If you want line numbers, have a look at the Gerber Sabre post to get an idea how to do it.
2) I'm afraid you can't insert the tool table. The tool details are only available when they are selected.
3) Yes, add a + to the format string. For example "+0.###"
http://www.forum.sheetcam.com/viewtopic.php?p=8559#8559
Thanks Les.
I have split newline() in newline() and linenumber(). Works fine.
I'll either let sheetcam do the tool length compensation then, or append the code to a fixed tool table.
http://www.forum.sheetcam.com/viewtopic.php?p=8560#8560
Hmm. Why is this:
For simplicity, I have generated the below using the unmodified non modal post. I have based my Deckel Dialog post on the non modal, so it does the same. As can bee seen, the first move after a tool change is modal. The Deckel will not accept modal G0's so I'm stuck.
Am I missing something?
N0000 G21
N0010 M6 T5
N0020 M03
N0030 G00 Z4.0000
N0040 G00 X48.5000 Y25.0000 Z4.0000
N0050 G00 X48.5000 Y25.0000 Z0.5000
N0000 G21
N0010 M6 T5
N0020 M03
N0030 G00 Z4.0000
Hmm. Why is this:
N0000 G21
N0010 M6 T5
N0020 M03
N0030 G00 Z4.0000
http://www.forum.sheetcam.com/viewtopic.php?p=8561#8561
N0000 G21
N0010 M6 T5
N0020 M03
N0030 G00 Z4.0000
You have hit an interesting quirk in the posts. The very first move is always Z only. In most cases this is correct as the post has no way of knowing where the machine is so it needs to get Z to a safe height first. This is done by making the first endx and endy variables unfeasibly large. The number functions know they should ignore these values.
In your case it causes a problem. Try adding this line to the beginning of function rapid():
if (endx > 100000) then return end
I think that is correct. If it doesn't work, try using -100000 instead.
This will completely ignore the first Z safety move.
http://www.forum.sheetcam.com/viewtopic.php?p=8562#8562
