V4.1.13 released
New releases and important announcements will be posted here. This is for announcements only. Please use the new features or problems forums to discuss new releases.
V4.1.13 released
Post by Les Newell » Fri Feb 02, 2007 3:48 pm
Hi all,
I have just uploaded V4.1.13 to www.sheetcam.com. This release has the following changes:
Fixed: Drill depth warning ignores start depth
Fixed: Arc leadin not always working on inside offset triangles
Fixed: cancelmodalnumbers function causing SheetCam to crash
Changed: If 'auto send' selected, the DNC tool will always be shown when you run the post processor
Fixed: In multi-part mode, clicking on any of the 'mode' buttons(tabs, contour properties etc) causes the first part in the list to be selected
Added: 'Loop corners' option for plasma cutting.
The loop corners function doesn't yet perform any collision detection. If you have a complicated drawing, check it doesn't gouge anywhere.
